Thank you very much! I will see if this is what i could use
@gambit2552 That looks good and could work but i guess its not possible to change the state of this boolean within this automation (instead of sending L003):
Found the issue… you cant control a zwave device when the template is sends a command…it needs to be entity_id instead of command…at least thats what i think
Ive setup the harmony remote and home assistant to react if one or the other is used.
But im from sweden and we use the word “Stäng av” insted of “power off”.
And when i press my remote to turn off the harmony. To make homeassistant react to whats happening. i use this code:¨
Automasation were the problem is:
- alias: "Powered off from Harmony Hub"
platform: state
entity_id: remote.vardagsrum
condition:
condition: template
value_template: '{{ trigger.to_state.attributes.current_activity == "PowerOff" }}'
service: input_select.select_option
entity_id: input_select.living_room_tv
option: "Stäng av"
But sadly when i use that i get errors in the logg cause the option “Stäng av” is not “PowerOff” in input_select. Invalid option: PowerOff (possible options: Välj Aktivitet, Tv, Htpc, Apple tv, Raspberry Pi, Stäng av)
Is there anyway to make it understand that i want it to use “Stäng av” when it see that remote is powered off?
Do mind that everything is working besides that i get the error in the logg.
seemed to be this that did it.
- alias: Harmony Set Input Select On Start
hide_entity: true
platform: event
event_type: homeassistant_start
- delay:
seconds: 30
- service: input_select.select_option
data_template:
option: ‘{{ states.remote.vardagsrum.attributes.current_activity }}’
I’m really interested in utilizing this component but I have no clue how to start the installation process. I’ve downloaded the zip file on my desktop but I have no clue how to upload/install this on my Hass.io.
Please advice. I am an absolutely clueless about python tbh.
If you have the Discovery Component active, Home Assistant will automatically find your Harmony hubs. You can check out the Harmony Hub Remote component page to find some information to get you started.
Discovery Component is active. And there is a harmony_harmony_hub.conf file in my Config folder, however there is no way to select the activities or execute individual commands through Hass.io. I’d like to be able to select, for example, my tv (device) then power on/off toggle and input (actions) and my A/C (device) then Power On/Off Toggle and Timer (Action). Will this component enable me to do so with some modifications?
Yes, but you’ll need to supply all of the information manually. The config files mention the device ID’s you’ll need to control your devices, then you need to set up automations or scripts to send the individual commands to your hubs.
A popular method for control is using Input Select to select your activities. Variations of something like this.
This gives you a drop down menu in your front end to select your activities. To send individual commands to your devices, you’ll also need to set up automations that will issue the commands to your hub. I’ve seen automations that use input sliders for volume adjustments, toggle switches, data input boxes, etc…
Edit: I forgot to add that you’ll need to add your Input Select info in your config file. Something like this.
input_select:
#Harmony
tv_room:
options:
- Select Activity
- Watch TV
- Watch Fire TV
- Watch a Movie
- Listen to Music
- Play Xbox
- PowerOff
initial: Select Activity
Thanks for heading me in the right direction, after reading the instructions a few times over and analyzing the code you quoted, I’ll try to figure out some way to make it work. Thanks everyone for your help. I really appreciate it!
Thank you for posting your HA project. I was able to work out many of the problems I was having with my Harmony Hub after carefully reviewing your config/automation/script files.
