svkowalski
(Steve Kowalski)
September 16, 2018, 7:41pm
246
Thanks for the suggestion. I followed through on it, and I now have a new use for buttons on my Harmony hub that enable me to turn lights on/off. I stumbled through the same confusion as others on where to place the Python code & getting the HH configured to see the new device.
A very useful add-on to HA.
Can Harmony Hub read the current on/off state of an old-and-not-really-smart-TV (which has only a power-toggle button)?
Harmony doesn’t actually ‘know’ the state of anything, it ‘assumes’ based on what activity you’ve triggered, ie if it sent a power on command to a device when you pressed ‘watch a movie’ it assumes it’s on until it sends an off command at the end of that activity.
Makes sense. Thanks for your reply.
Kitser
January 10, 2019, 2:58pm
250
Is it possible to install this on Hassio on a rpi3? Because in Hassio i can’t use the commandline to use wget for downloading this component. What sould I do?
Edit:
I didn’t see this post Logitech Harmony Integration with @iandday's component . So it is auto discovered but only need some extra configuration. Thanks anyway
Jokerigno
(Jokerigno)
March 4, 2019, 2:33pm
251
Hi all,
I added this integration months ago and since few months i noticed that at HA reboot all script are triggered from imput select. I’m the only one facing this issue?
petro
(Petro)
March 4, 2019, 2:40pm
252
You added this over the built in component which uses used this library?
Jokerigno
(Jokerigno)
March 4, 2019, 2:42pm
253
no, the default component.
petro
(Petro)
March 4, 2019, 2:43pm
254
Ok, so what scripts are executing on startup. Do you have an example of the script that’s executing?
Jokerigno
(Jokerigno)
March 4, 2019, 2:51pm
255
any script. I have different script for different harmony activities.
Are similar to this:
plex:
sequence:
- service: remote.turn_on
entity_id: remote.harmony_hub
activity: "27269375"
12:55
tvoff started
12:55
|TV turned off from HASS has been triggered|
12:55
|Harmony Soggiorno changed to Spenta|
12:55
|Powered off from Harmony Hub has been triggered|
12:55
|TV Soggiorno turned off|
12:55
|Prime Video turned off|
12:55
|BluRay turned off|
12:55
|VHS turned off|
12:55
|Netflix turned off|
12:55
|Plex turned off|
this time tvoff was the last so nothing happened. But for example sometimes the last is tvon so the script is executed and is quite annoying if someone is watching tv.
petro
(Petro)
March 4, 2019, 2:53pm
256
You want to look at any automation that would run those. What automations are those scripts in?
Jokerigno
(Jokerigno)
March 4, 2019, 2:55pm
257
as you can see is the same code as the original post
- alias: "Plex started from HASS"
hide_entity: true
initial_state: 'on'
platform: state
entity_id: input_select.harmony_soggiorno
to: 'Plex'
service: script.turn_on
entity_id: script.plex
- alias: "Plex started from Harmony Hub"
hide_entity: true
initial_state: 'on'
platform: state
condition:
condition: template
value_template: '{{ trigger.to_state.attributes.current_activity == "Guarda Plex" }}'
service: input_select.select_option
option: "Plex"
petro
(Petro)
March 4, 2019, 3:02pm
258
So, during startup your current_activity must be changing something to whatever activity you are on. Which would cause that to trigger.
Do your input_selects have initial set to anything? If so, remove that and it should restore the last state.
Jokerigno
(Jokerigno)
March 4, 2019, 3:07pm
259
yes. Inital state was set. I just removed it. Let’s test if something changed. In the meantime thank you!
Jokerigno
(Jokerigno)
March 6, 2019, 10:21pm
260
No changes. At HA boot all is triggered.
FankiMonki
(Fanki Monki)
March 19, 2019, 5:23pm
261
Hi Guys also hustling with this stuff…
everything is working but only get feedback from harmony when activating radiologisch, for apple tv and poweroff the input select card isnt changing…
Somebody an idea?
#Harmony-controls
- alias: "Harmony Controls"
initial_state: true
hide_entity: true
- platform: state
entity_id: input_select.harmony_hub
data_template:
activity: >-
{% if is_state("input_select.harmony_hub", "AppleTV") %}38823668
{% elif is_state("input_select.harmony_hub", "Radiologisch") %}38554559
{% elif is_state("input_select.harmony_hub", "PowerOff") %}-1
{% endif %}
- service: input_select.select_option
data_template:
option: "Select Activity"
#started from harmony
- alias: "AppleTV from Harmony Hub"
platform: state
condition:
condition: template
value_template: '{{ trigger.to_state.attributes.current_activity == "AppleTV" }}'
option: "AppleTV"
- alias: "Radiologisch from Harmony Hub"
platform: state
condition:
condition: template
value_template: '{{ trigger.to_state.attributes.current_activity == "Radiologisch" }}'
option: "Radiologisch"
- alias: "PowerOff from Harmony Hub"
platform: state
condition:
condition: template
value_template: '{{ trigger.to_state.attributes.current_activity == "PowerOff" }}'
option: "PowerOff"
jan.mob
(Jan Mob)
March 22, 2020, 5:29pm
262
Can any one help me?
I made this but if i put this “input_select.kamerr” in groups.yaml
i get this error "Invalid config for [group]: expected a dictionary for dictionary value @ data[‘group’]. Got ‘input_select.kamerr’ "
What i try i cant get this to work ok.
If i run the scripts it works.
But not when i select a input from the dropbox.
What is wrong?
here are my configs.
configuration.yaml
remote:
- platform: harmony
host: 192.*********
activity: "TV kijken"
input_select:
kamerr:
options:
- select input
- power_off
- tv_kijken
- shield_tv
- muziek
- netflix
- pc_kijken
initial: power_off
icon: mdi:monitor
automatition.yaml
- alias: "Powered off from Harmony Hub"
platform: state
entity_id: remote.harmony_barts_remote
condition:
condition: template
option: "Powered Off"
- alias: "tv_kijken started from Harmony Hub"
platform: state
condition:
condition: template
value_template: '{{ trigger.to_state.attributes.current_activity == "tv_kijken" }}'
entity_id: input_select.harmony_barts_remote
option: "tv_kijken"
- alias: "shield_tv started from Harmony Hub"
platform: state
condition:
condition: template
scripts.yaml
tv_kijken:
sequence:
activity: "42835954"
shield_tv:
sequence:
activity: "42836070"
muziek:
sequence:
activity: "42838635"
netflix:
sequence:
activity: "42839038"
pc_kijken:
sequence:
activity: "43153329"
power_off:
sequence:
activity: "-1"
input_select.yaml
kamerr:
options:
- select input
- power_off
- tv_kijken
- shield_tv
- muziek
- netflix
- pc_kijken
initial: power_off
icon: mdi:monitor
petro
(Petro)
March 22, 2020, 6:27pm
263
well yeah, you need to correctly configure a group. Just putting an entity_id inside the group section is not how group is supposed to look.
jan.mob
(Jan Mob)
March 22, 2020, 7:17pm
264
How do you mean?
do i have to put some thing like this?
options:
- select input
- power_off
- tv_kijken
- shield_tv
- muziek
- netflix
- pc_kijken
initial: power_off
icon: mdi:monitor
petro
(Petro)
March 22, 2020, 9:21pm
265
No, follow the group documentation and add your group. Do you know what you are trying to do or are you just copying what other people had?
What are you trying to do with this ‘group’?
