For more then 2 years now i am using a hardware modified xiaomi round buttons behind my Gira switches. I designed a special holder for this (see:https://www.thingiverse.com/thing:3508223 )
Currently i am using the xiaomi mija gateway and the older integration. That integration has support for a longpress event, which i am using in several automations.
I am now investigating moving my zigbee devices (Ikea lights and xiaomi stuff) to the new Sonoff Zigbee Gateway (modified so it can be used in homeassistant) with ZHA.
It appears that the ZHA integration only expose the raw events and doesnât have a longpress event implemented for the xiaomi round switch. (Lumi.sensor_switch in ZHA).
With the new release of core 0.115.x there is now a âwait_for_triggerâ available in the actions, that makes it much easier and nicer to implement this without âhelpersâ.
I therefore share my solution for those who are facing the same problems.
Replace the <device_ieee> with your id.
automation:
- id: '1600849795061'
alias: TranslateEvents
description: ''
- platform: event
event_type: zha_event
event_data:
device_ieee: 00:15:8d:00:02:93:04:11
command: attribute_updated
args:
attribute_id: 0
attribute_name: on_off
value: true
condition: []
- wait_for_trigger:
- platform: event
event_data:
args:
attribute_id: 0
value: false
continue_on_timeout: true
timeout: 00:00:01
- choose:
- conditions:
- condition: template
value_template: '{{ not wait.trigger }}'
sequence:
- event: Longpress
event_data: {}
default:
- event: Shortpress
event_data: {}
mode: single
