i have 2 Mitsubishi units to control heating and cold air for my house , i never use the remotes i use broadlink to control it all at the moment
whats best way to have it so i can adjust temp, fan speed and show what its set to
and whats best way to control it as it seems to send a packet to set fan speed setting and direction of fan in 1 packet
what does yours look like ? and best way ?
thanks i really need guidance as fully redoing my server to hassio from my unraid server
amirandap
(Amirandap)
2
Have checked Tado AC, it has a component for hass and works “most” of the time
stanvx
(Trent)
3
You should checkout the Broadlink IR Climate Component. Broadlink IR Climate Component
As an alternative from that I manually setup the commands using my Logitech Harmony Remote, same would work for if you adjust the code. AC Split System integration via Harmony Remote
£150 for each unit i have aint really the best option i might just have ir codes for bunch of settings and test it that way
