Hello guys I want to share with you my firs Project . All files for ordering printed circuit boards can be found on the Github page.
wow. that is some long range power from the 5th floor. My mailbox room is equipped with a system that courier can contact our unit if there is a package, but they don’t do it for regular envelope mail though. I will order one if you are selling it just to try it out.
No, I do not sell a ready-made sensor , you can try to do it yourself, If you have any questions about the assembly, I will try to answer as quickly and accurately as possible.
Can it be configured for US LoRa (915 MHz)?
Yea, that is a lot of soldering.
Ra-01 module is 433mhz , but i can make a board for another module .
The part for the US market is the Ra-01H:
https://fccid.io/2ATPO-RA-01H/User-Manual/15-Ra-01H-UserMan-US-r1-4753592.pdf
Can you verify if it is pin-for-pin compatible (w/ the appropriate antenna)?
Yes Ra-01H Its pin-to-pin compatible !
Will this LILYGO ESP32 LoRa work?
Your post actually made me aware of this project for the first time so thanks for that
I started digging into this a little bit. Since no one else has answered your question, I thought I would make an attempt at it.
I presume you are asking about this part regarding the “gateway” side (versus the sensor side). The OP is using OpenMQTTGateway for the gateway side. It was mentioned in the 2nd video which ones are compatible, and here is a reference link to the listed “compatible” types:
https://compatible.openmqttgateway.com/index.php/product-category/boards/lora/
Hi. So it looks like it will work?
If so,my other question is the frequency. I’m in Japan. Google says Japan uses this freq. I’m good?
AS920-923 (“AS1”)
You need to
match the frequency on the two devices (ie the device in the mailbox and the device in the openmqtt gateway)
Match both those to the frequency allowed in your country.
Wikipedia says LoRa uses " AS923 (915–928 MHz) in Asia" and references this document https://lora-alliance.org/wp-content/uploads/2021/05/RP-2-1.0.3.pdf
There is a 923MHz version of the LoRa device you pointed to on Aliexpress, and you’ll have to get a matching chip for @madman’s board (for the mailbox end).
From this table it looks like the RA-01H does the Japanese frequency Ai-Thinker LoRa series modules for sale | 安信可科技 see also https://cdn.ozdisan.com/ETicaret_Dosya/632831_134737.pdf
Yes it will work
From what I can tell, the RA-01H covers a broad range: 803-930MHz, so I presume for a particular region/country of interest, one would set the frequency using software. In the case of the mailbox sensor, the Arduino library provides a frequency setting. For the U.S. region, the range is 902-928MHz and commonly referred to as 915MHz. So I was trying to figure out what the frequency setting should be. Is it as simple as setting it to 915MHz?
Look in the code
Ah yes, that is the Arduino library frequency setting I was referring to, but didn’t make note of the code comments. Thanks
It’s great to see commented code!
