So I setup a new install of HASS on a Raspberry Pi 4 last night (latest image, followed instructions from HASS). I installed SSH & Web Terminal add-on and went in, created a new directory under /mnt and an fstab entry to mount an NSF4 share from my NAS. I manually run the mount and it works (with a command line configuration and basing it on fstab).
When I reboot the Pi (through either a reboot command or restart from the Supervisor section), all the changes I made are gone. The /mnt/homeassistant directory is gone and the changes to fstab are missing.
I thought maybe I had a bad image write to the SD card so I wiped it and flashed it again but I’m having the same issue. Has anyone seen this before? The SD card is brand new and came with the RPI4 I bought (which is a Canakit setup).
