at the end of the typical startup log, the “OCI runtime exec failed…” message blinks a few times, I never get the typical CLI welcome screen/logo and end up with a blank screen.
I then use CTL-ALT-F2 to login manually with the result above
Any clue what could be wrong and how to regain access ?
Or some guidance on how to troubleshoot this.
thanks. yes definitely something wrong in there… but would need expert eyes on the root cause.
Mar 23 22:54:58 homeassistant systemd[1]: [email protected]: Consumed 1.321s CPU time.
Mar 23 22:54:58 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 327.
Mar 23 22:54:58 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:54:58 homeassistant systemd[1]: Started Home Assistant CLI.
Mar 23 22:54:59 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95-runc.NmsVkT.mount: Deactivated successfully.
Mar 23 22:55:00 homeassistant dockerd[493]: time="2024-03-23T22:55:00.558044459Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:00 homeassistant dockerd[493]: time="2024-03-23T22:55:00.993029364Z" level=error msg="Error running exec c99ad1d0f40b176bf83dcecb28defbb1edcde3954bbd4478fc7e9ff6a8d93a02 in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:01 homeassistant dockerd[493]: time="2024-03-23T22:55:01.025239219Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist c99ad1d0f40b176bf83dcecb28defbb1edcde3954bbd4478fc7e9ff6a8d93a02: not found" module=libcontainerd namespace=moby
Mar 23 22:55:01 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Mar 23 22:55:01 homeassistant systemd[1]: [email protected]: Consumed 1.161s CPU time.
Mar 23 22:55:01 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 328.
Mar 23 22:55:01 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:55:02 homeassistant systemd[1]: Started Home Assistant CLI.
Mar 23 22:55:07 homeassistant dockerd[493]: time="2024-03-23T22:55:07.078973665Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:07 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-4867f2b1de43c6bc1d492b88c70ad370426084eca2f414a17a0038324a14e1ef-runc.NT6Uwn.mount: Deactivated successfully.
Mar 23 22:55:07 homeassistant dockerd[493]: time="2024-03-23T22:55:07.529607446Z" level=error msg="Error running exec 88966e767a19778e1b4b08d23caaca0702e8eb148996e7b7302fcf91c3334987 in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:07 homeassistant dockerd[493]: time="2024-03-23T22:55:07.589283994Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist 88966e767a19778e1b4b08d23caaca0702e8eb148996e7b7302fcf91c3334987: not found" module=libcontainerd namespace=moby
Mar 23 22:55:08 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Mar 23 22:55:08 homeassistant systemd[1]: [email protected]: Consumed 2.446s CPU time.
Mar 23 22:55:08 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 329.
Mar 23 22:55:08 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:55:08 homeassistant systemd[1]: Started Home Assistant CLI.
Mar 23 22:55:12 homeassistant dockerd[493]: time="2024-03-23T22:55:12.198359470Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:12 homeassistant dockerd[493]: time="2024-03-23T22:55:12.321461559Z" level=error msg="Error running exec c864f6adc8cc7f5e980dfeb964bfa922dfc9a6a732fe355e8f2353d2011e518b in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:12 homeassistant dockerd[493]: time="2024-03-23T22:55:12.366059718Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist c864f6adc8cc7f5e980dfeb964bfa922dfc9a6a732fe355e8f2353d2011e518b: not found" module=libcontainerd namespace=moby
Mar 23 22:55:12 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Mar 23 22:55:12 homeassistant systemd[1]: [email protected]: Consumed 1.647s CPU time.
Mar 23 22:55:12 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 330.
Mar 23 22:55:12 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:55:13 homeassistant systemd[1]: Started Home Assistant CLI.
Mar 23 22:55:17 homeassistant dockerd[493]: time="2024-03-23T22:55:17.619967527Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:17 homeassistant dockerd[493]: time="2024-03-23T22:55:17.858034365Z" level=error msg="Error running exec 5623db6b7ac2a8ed37ebba240995199f9c56e179a181cee4d4115d1bc007a502 in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:18 homeassistant dockerd[493]: time="2024-03-23T22:55:18.058872048Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist 5623db6b7ac2a8ed37ebba240995199f9c56e179a181cee4d4115d1bc007a502: not found" module=libcontainerd namespace=moby
Mar 23 22:55:18 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Mar 23 22:55:18 homeassistant systemd[1]: [email protected]: Consumed 4.489s CPU time.
Mar 23 22:55:18 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 331.
Mar 23 22:55:18 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:55:18 homeassistant systemd[1]: Started Home Assistant CLI.
Mar 23 22:55:21 homeassistant dockerd[493]: time="2024-03-23T22:55:21.046469140Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:21 homeassistant dockerd[493]: time="2024-03-23T22:55:21.209565483Z" level=error msg="Error running exec a7479ab5a60dbcb7b841e09c0ddc37e461e56178d6e6d04488e39ead3c7c53a2 in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:21 homeassistant dockerd[493]: time="2024-03-23T22:55:21.238033712Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist a7479ab5a60dbcb7b841e09c0ddc37e461e56178d6e6d04488e39ead3c7c53a2: not found" module=libcontainerd namespace=moby
Mar 23 22:55:21 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Mar 23 22:55:21 homeassistant systemd[1]: [email protected]: Consumed 1.850s CPU time.
Mar 23 22:55:21 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 332.
Mar 23 22:55:21 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:55:21 homeassistant systemd[1]: Started Home Assistant CLI.
Mar 23 22:55:24 homeassistant dockerd[493]: time="2024-03-23T22:55:24.075396482Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:24 homeassistant dockerd[493]: time="2024-03-23T22:55:24.355175455Z" level=error msg="Error running exec 9329e0f5b15c933f021ad7e4a52eda035622fbcd10ef3ae1a0dc7e8c27049ea0 in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:24 homeassistant dockerd[493]: time="2024-03-23T22:55:24.428763490Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist 9329e0f5b15c933f021ad7e4a52eda035622fbcd10ef3ae1a0dc7e8c27049ea0: not found" module=libcontainerd namespace=moby
Mar 23 22:55:24 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Mar 23 22:55:24 homeassistant systemd[1]: [email protected]: Consumed 1.693s CPU time.
Mar 23 22:55:24 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 333.
Mar 23 22:55:24 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:55:24 homeassistant systemd[1]: Started Home Assistant CLI.
Mar 23 22:55:27 homeassistant dockerd[493]: time="2024-03-23T22:55:27.248787294Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:27 homeassistant dockerd[493]: time="2024-03-23T22:55:27.428300983Z" level=error msg="Error running exec a472def4e4a3ac03687e3eff8182ba23688aed3d03fa7ab013f4d6cb9682d5bf in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:27 homeassistant dockerd[493]: time="2024-03-23T22:55:27.488178831Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist a472def4e4a3ac03687e3eff8182ba23688aed3d03fa7ab013f4d6cb9682d5bf: not found" module=libcontainerd namespace=moby
Mar 23 22:55:27 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Mar 23 22:55:27 homeassistant systemd[1]: [email protected]: Consumed 1.394s CPU time.
Mar 23 22:55:27 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 334.
Mar 23 22:55:27 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:55:27 homeassistant systemd[1]: Started Home Assistant CLI.
Mar 23 22:55:28 homeassistant dockerd[493]: time="2024-03-23T22:55:28.687684736Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:28 homeassistant dockerd[493]: time="2024-03-23T22:55:28.929427831Z" level=error msg="Error running exec 3c8209653f9299591cd80f7311c47a6aaaa29b3db1c21dda2bfbb77f161b847d in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:29 homeassistant dockerd[493]: time="2024-03-23T22:55:29.027198287Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist 3c8209653f9299591cd80f7311c47a6aaaa29b3db1c21dda2bfbb77f161b847d: not found" module=libcontainerd namespace=moby
Mar 23 22:55:29 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Mar 23 22:55:29 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 335.
Mar 23 22:55:29 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:55:29 homeassistant systemd[1]: Started Home Assistant CLI.
Mar 23 22:55:29 homeassistant dockerd[493]: time="2024-03-23T22:55:29.816804536Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:29 homeassistant dockerd[493]: time="2024-03-23T22:55:29.870406647Z" level=error msg="Error running exec a096be40d1ca563270ced5e40fb443152d8258c31c5b01d23e4ae4d5e7e0766a in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:29 homeassistant dockerd[493]: time="2024-03-23T22:55:29.907978286Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist a096be40d1ca563270ced5e40fb443152d8258c31c5b01d23e4ae4d5e7e0766a: not found" module=libcontainerd namespace=moby
Mar 23 22:55:29 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 336.
Mar 23 22:55:31 homeassistant dockerd[493]: time="2024-03-23T22:55:31.164295335Z" level=error msg="stream copy error: reading from a closed fifo"
Mar 23 22:55:31 homeassistant dockerd[493]: time="2024-03-23T22:55:31.169364606Z" level=error msg="Error running exec a2ed247c093c99472a7668c2ca037537debc4138d5e0169be3caca97a152aab3 in container: OCI runtime exec failed: exec failed: unable to start container process: exec /usr/bin/cli.sh: exec format error: unknown"
Mar 23 22:55:31 homeassistant dockerd[493]: time="2024-03-23T22:55:31.197763056Z" level=error msg="failed to close container stdin" container=f846d1a04f0bba3c2f9e5fdd8a44161b5621cfd6eb2f5929a7d3ca776735de95 error="process does not exist a2ed247c093c99472a7668c2ca037537debc4138d5e0169be3caca97a152aab3: not found" module=libcontainerd namespace=moby
Mar 23 22:55:31 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Mar 23 22:55:31 homeassistant systemd[1]: [email protected]: Scheduled restart job, restart counter is at 337.
Mar 23 22:55:31 homeassistant systemd[1]: Stopped Home Assistant CLI.
Mar 23 22:55:31 homeassistant systemd[1]: [email protected]: Start request repeated too quickly.
Mar 23 22:55:31 homeassistant systemd[1]: [email protected]: Failed with result 'start-limit-hit'.
Mar 23 22:55:31 homeassistant systemd[1]: Failed to start Home Assistant CLI.
Mar 23 22:56:10 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-4867f2b1de43c6bc1d492b88c70ad370426084eca2f414a17a0038324a14e1ef-runc.qbv7np.mount: Deactivated successfully.
Mar 23 22:56:16 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-4e524cfe97213543eda452daed7e6cf4c468e2ef3118ec797daf6cd3a99e394a-runc.UyoKao.mount: Deactivated successfully.
Mar 23 22:56:28 homeassistant kernel: audit: type=1334 audit(1711234588.920:624): prog-id=143 op=LOAD
Mar 23 22:56:28 homeassistant systemd-timesyncd[467]: Network configuration changed, trying to establish connection.
Mar 23 22:56:28 homeassistant systemd-timesyncd[467]: Contacted time server 162.159.200.123:123 (time.cloudflare.com).
Mar 23 22:56:29 homeassistant systemd[1]: Started Journal Gateway Service.
Mar 23 22:56:30 homeassistant systemd-journal-gatewayd[29387]: microhttpd: MHD_OPTION_EXTERNAL_LOGGER is not the first option specified for the daemon. Some messages may be printed by the standard MHD logger.
Mar 23 22:56:42 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-4867f2b1de43c6bc1d492b88c70ad370426084eca2f414a17a0038324a14e1ef-runc.ASvOqg.mount: Deactivated successfully.
hmmm weird , yeah seems not related to the Add-Ons, yes i was also started to thinking about something corrupt.
Unfortunately there are no specific backup-files for the OS upgrades( nor Supervisor ) … Not even a full-backup backups the OS etc, only what under /Homeassistant
I would try to Rollback to a previous Core, or a FullBackup ( Not that i think it would help in this case)
You can change default-Logger-level in config.yaml, but i don’t think that counts for the OS, but you could try to change default to DEBUG, and reboot, maybe it reveals more
Im Running VMWare in Windows10, so occasionally( when i anyway have to shutdown HA to reboot Windows ) i even copy the whole VM folder (which is on a separate disk, than Windows)
