Hello Community,
I have several LED strip lights controlled with the LotusLamp X app and I would like to know if there is a method to integrate it into HA without having to change the controller?
The current controller is noted Smard Led Controller and LED type RGBIC purchased from Amazon
Hello Community,
I have several LED light strips controlled with the LotusLamp X app and I would like to know if there is a method to integrate it into HA without having to change the controller?
Just figured it out. As long as you have HACS installed you can download the integration elkbledom. Once installed, it will automatically pick them up. I hope this helps!
sorry I’m very new to home assistant but I already have HACS and the elkbledom integration and when i go to add a new device it asks for bluetooth MAC address and Name, would you be able to assist me on how to find those? Thanks
Just got a set myself and they work great… to find the MAC and name, go into the Lotus app and select the “hamburger” (3 lines in the top left corner) There you should see my devices. in the case my name was BLEDXXXX and the Mac would be BE:67:XX:XX:XX
I had a Led Ble strip that came with a headboard i purchased from amazon, after scanning the QR code brought me to the Lotus Lantern App after google searching ways to connect it HA the AI overview said to download this Repo elkbledom- Lotus Lantern / Lotus Lantern X after using the app to discover the controller and MAC, i added it to my HA instance
" AI Overview
[image]
To use a Bluetooth LED strip with Home Assistant using the Lotus Lantern app, you’ll need the elkbledom custom integration within Home Assistant. This allows you to control your LED strip via Bluetooth using the Lotus Lamp X app (or other compatible apps) and integrate it with your Home Assistant setup."
