Lovelace access KO but API access OK
Over the last few weeks, my HA (running on a debian VM, hassio installed using the generic linux installation) stops working properly.
The API access continue to work (eg https//hassio:8123/api/config is OK).
However, trying to access lovelace web ui gives this :
with the spinning wheel in the middle and I never gets the normal UI…
I have another instance of HA running on a RPI on my LAN. In order to troubleshoot this as soon as it happens, I would like to run some nodered flow on the RPI, accessing the web ui and warn me when something is wrong.
The problem is that I can’t make the difference using nodered between the web ui working and the spinning wheel. Both are giving on “200 OK” as HTTP response. I would need to do something more clever to distinguish between the “normal” UI and this wheel.
Any suggestion on a way to achieve that?
The next step will be to understand why my hassio instance is doing this… But that will be for later :slight_smile:
Thanks,
GV
Since this post, it happened to me twice. Same symptoms. Is there a way to distinguish between the “normal” UI and this wheel programmatically? Any clue?
Thanks,
GV
edit: try wiping browsercache first
It probably means frontant cant communicate with homeassistant
here’s a good start:
#configuration.yaml
logger:
  default: debug
tail -f /config/home-assistant.log
when you found it specify your logger to something like:
#configuration.yaml
logger:
  default: info
  logs:
    homeassistant.components.frontend: debug
    homeassistant.core: fatal
afterwards build an automation for that kindof event:
#automation.yaml
  - alias: notification for "frontend" errors
      platform: event
      event_type: system_log_event
    condition:
      condition: template
      value_template: '{{ "frontend" in trigger.event.data.message }}'
      service: notify.pushover
      data_template:
        title: The wheel! It's spinning!
        message: '{{ trigger.event.data.message }}'
Thanks for the tip. I have done that. Now, I’ll just have to wait some time…
GV
