Update 2.3.2 is expanding the calendar again.
Works ok on 2.3.1
thanks
Hi Guys,
can anyone help me please.
In lovelace i have this Information:
The calendar can’t be loaded from Home Assistant component
- type: 'custom:atomic-calendar-revive'
entities:
- entity: sensor.familie_event_1
style:
top: 36.5%
left: 68.31%
width: 50%
The card will only work with calendar.xxxx
ok thank you
Since update to HA Core 0.116 and Atomic calendar revive 2.5 I get “The calendar can’t be loaded from Home Assistant component” Any idea where to look for the source of the issue?
Does this work with a non-Google calendar? I’m using the iCal integration to create a calendar which displays ok with the built-in Lovelace calendar card, but I get no events displayed with your card…
(The built-in lovelace card had almost no config options hence wanting to use yours…)
I have tested with Google calendar and caldav. I haven’t with any other types.
Hi Great work.
I get the calendar, but cant get it to show icons for the events on the calendar as icons.
Can someone guide me?
My code is:
- type: "custom:atomic-calendar-revive"
enableModeChange: true
defaultMode: Calendar
dateFormat: L
maxDaysToShow: 30
firstDayOfWeek: 1
sortByStartTime: true
showDescription: true
showNoEventsForToday: true
entities:
- entity: calendar.xxxxxx
entity.icon: "mdi:flag-variant"
entity.color: red
entity.icon: "mdi:circle-edit-outline"
entity.color: green
- entity: calendar.helligdage_i_danmark
entity.icon: "mdi:home"
entity.color: orange
Hey,
Remove the entity.
From before icon, it’s like that in the docs to show the icon is a child of entity.
So it should just be:
icon: 'mdi:blah'
Color: blue
Ahh so
entity.icon
and entity.color
in docs (2.0.0) is the same as
- entity:
icon:
color:
thx marksie1988 it works now.
But how can I changes the calendar layout/colors, what do i need to add in my main code?
Personally I would recommend using card-mod and then amending the CSS in the styles that you want.
the options in the calendar card are limited and I’ve seen people get better results using card mod.
Yes that’s the one
Hi, aleady found this component and it works good for me except one thing:
Does anybody have an idea to get rid of these until… information?
By the way: what does it mean? The event comes from my garbage collection calendar and is an all day event
Good morning. Calendar is being used in Dwains Dashboard. I’m trying to determine why the Day of the Week isn’t showing, e.g., Tue, Wed, Thu. Is there an option that I’m missing in the documentation to turn this on. Code is the following in page.yaml in my Dwains Dashbaord config:
- type: custom:dwains-heading-card
title: {{ name }}
- type: custom:atomic-calendar-revive
style: |
ha-card {
border-radius: 5px;
background-color: var(--dwains-theme-primary);
.cal-titleContainer {
display: none;
showProgressBar: false
eventBarColor: 'var(--dwains-theme-grey)'
dayWrapperLineColor: 'var(--dwains-theme-grey)'
timeColor: 'var(--dwains-theme-grey)'
entities:
{{ (data | fromjson)['calendars'] }}
maxDaysToShow: 30
showColors: true
showMonth: true
Hi all,
I’m new to this but i got most up and running.
Now i’m trying to add the atomic-calendar-revive card and get this error when configuring/adding the calendar card:
No card type configured.
- type: ‘custom:atomic-calendar-revive’
entities:- entity: calendar.brynas_matcher
any ideas or pointers?
Installed with hacs.
Google calendar card works.
regards
// Hans
did you find an answer to this? Latest release reintroduced this and I haven’t found the configuration parameter to remove it.
Hey, this usually happens if the card isn’t loaded correctly, best way to check is to see if you have an entry in the browser console for atomic-calendar-revive with the version number.
If you don’t have this then there is an issue with loading the js file, check in the browser debugger that the aromic-calendar-revive.js file is present.
I’ll check when I get a chance. For now, I dropped back a version and the “until information” went away.
The from/to dates had been changed and now, ‘until:’ shows the right information. So I kept the information. No idea how to switch it off.
