Hello, I tried to install bar card today and the UI config is totally broken, I can not configure anything, add entities, etc… What is wrong?
Thanks.
That I was trying before. Not working. Seems really something wrong in this line. It will cause the hole graph is not shown. Really weird.
I’m sorry, I wasn’t clear. Make a card using just the code that I posted above (the nuclear option). This is just a bare bones test card to figure out where the trouble is. It’s not intended to be your final pretty card. If it works, then the problem is somewhere in the rest of your code. If it doesn’t, then there’s something wrong behind the scenes.
Nope is not working. The HACS resources are correctly installed ‘custom-template-card’. I even uninstalled and reinstalled it again to be sure that the card is available.
Alright. There’s something programmatically wrong with the install. I’m not saying you did something wrong. But something isn’t playing nice in the background. And that’s way outside my league.
hi, when can i override the border radius theme (ios dark theme) inside of the card?
i can try whith the follow code, but it’s wrong. i can modify the border but not the radius of bar.
card_mod:
style: >
bar-card-currentbar, bar-card-card, bar-card-contentbar,
bar-card-backgroundbar, bar-card-background, bar-card-current {
margin-left: 10px !important;
margin-right: 20px !important;
margin-bottom: 10px;
border-radius: 0px;
bar-card-currentbar, bar-card-backgroundbar {
border-radius: 0px;
or
style: |
border-radius: 0px;
i would to find the border squared, but the ios dark blue theme.
i can try since 5 hours, but i wrong.
Hi guys,
short question: Is it possible to map the value or to show another value (like a helper entity)? I would like to use a string variant instead of the number. Like number 0-66 = ‘Good’.
Hi all,
Struggling to get the animation to work, eventually want it triggered based on binary sensor, but even the basic ‘on’ is not working for me at the moment… Any hints?
- type: custom:config-template-card
variables:
charge_target: states['sensor.i5_m60_xdrive_charging_target'].state
entities:
- ${charge_target}
card:
type: custom:bar-card
column: 1
animation:
state: 'on'
speed: 2
entities:
- entity: sensor.i5_m60_xdrive_remaining_battery_percent
icon: mdi:ev-plug-ccs2
height: 40px
min: 0
max: 100
target: ${charge_target}
severity:
- color: Red
to: 25
- color: Orange
to: 49
- color: Green
to: 100
card_mod:
style: |-
border-radius: 12px;
border: 0px solid;
Thanks for the very useful work! Tried to implement this card in a mushroom style dashboard, after some css tweaking this seems to work on a basic level. The standard mushroom collection doesn’t have a counter/gauge/severity tile, so I hope this tweak can be useful to some.
For anyone interested, my code for this card:
entities:
- entity: counter.regenwater_filter
icon: mdi:water-check
positions:
icon: outside
indicator: 'off'
minmax: 'off'
value: 'off'
min: 0
max: 365
target: 180
height: 8
severity:
- color: rgb(76,175,80)
to: 179
- color: rgb(255,152,0)
to: 239
- color: rgb(244,67,54)
to: 365
card_mod:
style: >
{% set entity = {
"state": states('counter.regenwater_filter') | int(9999999999),
"name": "Levensduur",
"unit": " d"
%} {% set severity = {
"green": 0,
"orange": 180,
"red": 240
%} {% set colors = {
"green": "76,175,80",
"orange": "255,152,0",
"red": "244,67,54"
ha-card .card-content {
padding: 10px!important;
cursor: pointer;
ha-card {
transition-duration: 0.05s;
ha-card:hover {
{% if entity.state == 9999999999 %}
background-color: rgba(200,200,200, 0.02);
{% elif entity.state < severity.orange %}
background-color: rgba({{colors.green}}, 0.02);
{% elif entity.state < severity.red %}
background-color: rgba({{colors.orange}}, 0.02);
{%- else -%}
background-color: rgba({{colors.red}}, 0.02);
{%- endif %}
bar-card-background {
margin-left: 13px !important;
bar-card-backgroundbar, bar-card-currentbar, bar-card-contentbar,
bar-card-targetbar {
border-radius: 8px;
bar-card-currentbar, bar-card-backgroundbar, bar-card-contentbar,
bar-card-targetbar, bar-card-animationbar {
left: 1.5em !important;
width: calc(100% - 1.5em);
{% else %}
{% set state_width = 1 + (entity.state|string|count + entity.unit|count) * 0.4 %}
left: {{state_width}}em !important;
width: calc(100% - {{state_width}}em);
{%- endif %}
bar-card-markerbar {
display: none;
bar-card-background::before {
content: "{{ entity.name }}";
display: flex;
font-family: Roboto, sans-serif;
font-size: 14px;
font-weight: 500;
height: 20px;
letter-spacing: 0.1px;
line-height: 20px;
margin-bottom: 6px;
bar-card-background::after {
content: "N/A"
{%- else %}
content: "{{ entity.state }}{{ entity.unit}}";
{%- endif %}
font-family: Roboto, Noto, sans-serif;
font-size: 12px;
font-weight: 400;
height: 16px;
letter-spacing: 0.4px;
line-height: 16px;
display: inline-block;
position: absolute;
margin-top: -4px;
width: fit-content;
bar-card-iconbar {
color: rgba(200,200,200, 1);
background-color: rgba(200,200,200, 0.2);
color: rgba({{colors.green}}, 1);
background-color: rgba({{colors.green}}, 0.2);
color: rgba({{colors.orange}}, 1);
background-color: rgba({{colors.orange}}, 0.2);
{%- else -%}
color: rgba({{colors.red}}, 1);
background-color: rgba({{colors.red}}, 0.2);
{%- endif %}
border-radius: 50%;
max-height: 36px;
max-width: 36px;
Update 13/01/2025: some minor css changes to reflect the new design guidelines of the mushroom cards.
Hello folks,
currently I am trying to build something like this (taken from Huawei Solar Dashboard)
Focus is at the bar graph itself.
Since ApexCharts for HA does - as far as I know - not support stacked bar graph like this I am currently using bar-card with card-mod and config-template-card [Actually the template card is in this state unnecessary, but it is still in for testing purpose]
However I am facing some issues.
This is what I currently have achieved (bottom 2 bars), using 2 templates to calculate the %-values.
Is there any way I can replace the displayed value for Min/Max (in this case 11% and 89 or 90%), without it affecting the bar length?
Because if I replace the MIN with config-template-card there is never a bar shown since the Min-value equals thecurrent value.
variables:
- states['sensor.pv_energy_daily'].state
entities:
- ${vars[0].entity_id}
card:
title: Version 3
decimal: 2
positions:
icon: 'off'
entities:
- entity: sensor.pv_energy_daily
- entity: sensor.grid_export_energy_daily
complementary: false
- entity: sensor.home_selfuse_energy_daily
max: ${vars[0] }
- entity: sensor.percent_selfuse_vs_export
unit_of_measurement: '%'
positions:
icon: 'off'
indicator: 'off'
minmax: inside
value: inside
title: inside
- entity: sensor.percent_export_vs_selfuse
positions:
icon: 'off'
indicator: 'off'
minmax: inside
value: inside
title: inside
card_mod:
style: |
.contentbar-direction-right {
flex-direction: column;
.min-direction-right {
margin: 0px;
margin-left: 4px;
margin-right: auto;
margin-bottom: -20px;
bottom: 10px;
bar-card-value {
margin: -11px;
margin-left:
bar-card-name {
margin: 0px;
bar-card-max {
margin: 0px;
margin-left: auto;
margin-top: 0px;
top: 10px;
font-size: 15px
bar-card-min {
margin: auto;
margin-left: auto;
margin-top: auto;
top: 10px;
font-size: 15px
bar-card-divider {
display: none;
Any help would be appreciated.
Is it possible to change the name within the Bar Card depending on the value of the Entity.
If negative then name ‘To Grid’ and if Positive then change the name to 'From Grid
Hi folks, I’m sharing a retro LED look for batteries level, all done in CSS.
edited : made it simpler thanks to @edwardtich for sharing is mask code which it’s based on.
Here’s the code:
###### Add those variables in your Theme
alert-color: 178, 34, 34
green-color: 34, 139, 34
orange-color: 207, 91, 0
yellow-color: 230, 187, 0
battery-gradient-vertical: linear-gradient(360deg, rgba(var(--alert-color),1) 0%, rgba(var(--alert-color),1) 35%, rgba(var(--orange-color),1) 50%, rgba(var(--yellow-color),1) 65%, rgba(var(--green-color),1) 100%)
battery-gradient-horizontal: linear-gradient(90deg, rgba(var(--alert-color),1) 0%, rgba(var(--alert-color),1) 35%, rgba(var(--orange-color),1) 50%, rgba(var(--yellow-color),1) 65%, rgba(var(--green-color),1) 100%)
battery-mask-horizontal: repeating-linear-gradient( 90deg, rgba(0, 0, 0, 0.3) 0%, black 2%, rgba(0, 0, 0, 0.3) 4%, transparent 4%, transparent 5%)
battery-mask-vertical: repeating-linear-gradient( 360deg, rgba(0, 0, 0, 0.3) 0%, black 2%, rgba(0, 0, 0, 0.3) 4%, transparent 4%, transparent 5%)
###### Vertical Bar
type: custom:stack-in-card
cards:
- type: custom:bar-card
columns: 4
decimal: 0
entity_row: false
positions:
icon: outside
minmax: 'off'
indicator: 'off'
direction: up
height: 200px
entities:
- entity: sensor.energie_victron_chalet_state_of_charge
- entity: sensor.energie_victron_chalet_battery_voltage
decimal: 1
min: 20
max: 28
- entity: sensor.energie_victron_chalet_amperage_restant_sur_416
max: 416
- entity: sensor.energie_victron_chalet_wattage_restant_416
icon: mdi:lightning-bolt
max: 9984
card_mod:
style: |
ha-card {
background: black !important;
background: var(--battery-gradient-vertical);
mask-image: var(--battery-mask-vertical);
border-radius: 0px;
filter: brightness(0.65);
opacity: 0.35;
bar-card-currentbar {
clip-path: polygon(0 100%, 100% 100%, 100% calc(100% - var(--bar-percent)), 0 calc(100% - var(--bar-percent)));
border-radius: 0px;
bar-card-value {
margin: 20px;
font-size: 1.25rem;
font-weight: 800;
ha-icon {
color: var(--primary-text-color);
###### Horizontal Bar
cards:
columns: 1
decimal: 0
entity_row: false
positions:
icon: outside
minmax: 'off'
indicator: 'off'
direction: right
height: 60px
entities:
decimal: 1
min: 20
max: 28
max: 416
max: 9984
card_mod:
style: |
ha-card {
background: var(--battery-gradient-horizontal);
mask-image: var(--battery-mask-horizontal);
border-radius: 0px;
opacity: 0.35;
clip-path: polygon(0 0, var(--bar-percent) 0, var(--bar-percent) 100%, 0 100%);
border-radius: 0px;
bar-card-value {
margin: 20px;
font-size: 1.25rem;
font-weight: 800;
ha-icon {
Hi all,
Is there a way to round the number shown in bar-card? I am using it for air quality and I’d like the numbers be a whole number.
Thank you!
- entity: sensor.solaredge_ac_power
name: Solar Productie
indicator: inside
icon: mdi:solar-power-variant
decimal: ''
really like the card from you. I tried to create a bar from 100 to 0 (%) from right to left but i dont get this working. Do you have a example code for this?
Glad you like it. It seems the bar Card isn’t able to show a right tot left bar, but i got it working by changing one css parameter, pretty much just flipping the bar horizontally.
Just add the following lines to the css selector already in the code:
border-radius: 8px;
-webkit-transform: scaleX(-1);
-moz-transform: scaleX(-1);
-o-transform: scaleX(-1);
Also if you want to create a bar from right to left, just use
min: 100
max: 0
I finally got it working.
So I had to use Config-template-card to alter the values for Min, Max and Target.
When altering Min, Max the bar would never display, therefore I calculate a new value for the target value to indicate the percentage, in this case it was around 42 I think. So the target has to be set at 42 (from the 100-0 scale) to represent 71% length.
Here is the code for the sensor that I use as target value:
l is the left value, r the right.
the sensors I use for l and r are complementary, that means the always add up to 100. You probably can also do it with just one sensor and then just substract 100 for the other.
- name: percent_calculated_bar
unique_id: percent_calculated_bar
state: >
{% set l = states('sensor.percent_selfuse_vs_export')|float(0) %}
{% set r = states('sensor.percent_export_vs_selfuse')|float(0) %}
{% set m = ( ( states('sensor.percent_export_vs_selfuse')|float(0) - states('sensor.percent_selfuse_vs_export')|float(0))|abs)|round(0) %}
{% if l > r %}
{{ ( l - ( l * m / 100 ) )|round(0) }}
{% endif %}
{% if r >= l %}
{{ ( l + ( l * m / 100 ) )|round(0) }}
{% endif %}
The code of the card is as follows (did not mess with coloring yet):
Used cards apart from bar card are config-template-card and card-mod
mode: vertical
cards:
- type: custom:mushroom-entity-card
entity: sensor.solar_yield_energy_daily
layout: vertical
icon_type: none
title: Custom Stack in
card_mod:
style: |
:host {
--stack-card-margin: 0px;
--ha-card-border-radius: 0px;
--ha-card-border-width: 0px;
--ha-card-border-color: green
} ha-card {
margin: -10px
variables:
- states['sensor.percent_export_vs_selfuse'].state
- states['sensor.percent_selfuse_vs_export'].state
- states['sensor.percent_calculated_bar'].state
entities:
- ${vars[1].entity_id}
- ${vars[2].entity_id}
card:
decimal: 2
entity_row: 3
positions:
icon: 'off'
entities:
max: ${vars[0] }
min: ${vars[1] }
target: ${vars[2] }
positions:
icon: 'off'
indicator: 'off'
minmax: inside
value: 'off'
title: inside
color: green
card_mod:
style: |
ha-card {
border-top: 0px;
border-bottom: 0px;
border-width: 10px;
border-color: transparent;
border-radius: 5px;
:host {
margin: 0px;
margin-left: 4px;
margin-right: auto;
bottom: 10px;
bar-card-value {
margin: -11px;
margin-left:
bar-card-name {
margin: 0px;
display: none;
bar-card-max {
margin: 0px;
margin-left: auto;
margin-top: 0px;
top: 10px;
font-size: 15px;
color: black;
bar-card-min {
margin: auto;
margin-left: auto;
margin-top: auto;
top: 10px;
font-size: 15px;
color: black
background: lightgreen;
bar-card-divider {
display: none;
- type: custom:stack-in-card
mode: horizontal
cards:
icon_type: none
icon_type: none
alignment: end
layout: vertical
card_mod:
style:
mushroom-state-info$: |
.container {
align-items: end;
card_mod:
style: |
:host {
--ha-card-border-color: purple;
} ha-card {
border: true;
border-width: 0px;
border-color: blue;
margin: -10px 0px -10px 0px
card_mod:
style: |
:host {
} ha-card {
border: true;
border-width: 0px;
stack-card-margin: px;
border-color: red;
box-shadow: none;
padding-top: 0px;
padding-bottm: 0px;
margin:
Found one issue though. If both values are 50% the bar looks like this…
Does anyone know how I can display a currency symbol $ in front an entity being used in the bar card, or even just display a different entity’s value? I have another entity which contains the exact value I want to display, i.e. “$5.9 USD”
I’ve tried card-mod, card-templater without much success.
I was able to get this working on a forked version of the gauge card, where the author added an configuration item called: “valueEntity”:
If this is not currently possible, I can open a feature request.
Please show your card-mod try, I may point at possible error.
