Lovelace: Bar Card
It does mention number but I only see example for a fixed value.
Or is there another way around this?
It does clearly say ā€œnumberā€ in a table of properties - which is ā€œ123ā€.
Your workaround is either using a forked version of this card supporting entities for this property (if this fork exists) or using a custom card supporting templates like config-template-card etc.
Ok, I think I got it working now using config-card thanks to this post
Only issue I have now is the bar exceed the column itā€™s in
Anyway I can edit this so it stays inside?
Also how do I reduce the numbers (remove .0 or %) display so each bar width is smaller?
type: custom:config-template-card
variables:
  - states['number.mmwave_g0_still_threshold_2']
  - states['number.mmwave_g1_still_threshold_2']
  - states['number.mmwave_g2_still_threshold_2']
  - states['number.mmwave_g3_still_threshold_2']
  - states['number.mmwave_g4_still_threshold_2']
  - states['number.mmwave_g5_still_threshold_2']
  - states['number.mmwave_g6_still_threshold_2']
  - states['number.mmwave_g7_still_threshold_2']
  - states['number.mmwave_g8_still_threshold_2']
entities:
  - sensor.mmwave_g2_still_energy_2
card:
  type: custom:bar-card
  title: Still Energy
  icon: "no"
  height: 100px
  width: 100%
  direction: up
  positions:
    indicator: inside
    value: inside
  columns: 9
  entities:
    - entity: sensor.mmwave_g0_still_energy_2
      target: ${vars[0].state}
      severity:
        - color: Blue
          to: ${vars[0].state}
        - color: Red
          to: 100
    - entity: sensor.mmwave_g1_still_energy_2
      target: ${vars[1].state}
      severity:
        - color: Blue
          to: ${vars[1].state}
        - color: Red
          to: 100
    - entity: sensor.mmwave_g2_still_energy_2
      target: ${vars[2].state}
      severity:
        - color: Blue
          to: ${vars[2].state}
        - color: Red
          to: 100
    - entity: sensor.mmwave_g3_still_energy_2
      target: ${vars[3].state}
      severity:
        - color: Blue
          to: ${vars[3].state}
        - color: Red
          to: 100
    - entity: sensor.mmwave_g4_still_energy_2
      target: ${vars[4].state}
      severity:
        - color: Blue
          to: ${vars[4].state}
        - color: Red
          to: 100
    - entity: sensor.mmwave_g5_still_energy_2
      target: ${vars[5].state}
      severity:
        - color: Blue
          to: ${vars[5].state}
        - color: Red
          to: 100
    - entity: sensor.mmwave_g6_still_energy_2
      target: ${vars[6].state}
      severity:
        - color: Blue
          to: ${vars[6].state}
        - color: Red
          to: 100
    - entity: sensor.mmwave_g7_still_energy_2
      target: ${vars[7].state}
      severity:
        - color: Blue
          to: ${vars[7].state}
        - color: Red
          to: 100
    - entity: sensor.mmwave_g8_still_energy_2
      target: ${vars[8].state}
      severity:
        - color: Blue
          to: ${vars[8].state}
        - color: Red
          to: 100
  1. Never ever post an unformatted code. Place a code into triple backquotes.
  2. Your card-mod code missing a ā€œcard_modā€ keyword. Check docs for card-mod.
Iā€™m sorry. Iā€™ve never posted on the forum. I can do it, my card is great. How do I post codes?
custom:bar-card
title: ProduĆ§Ć£o Solar
entities:
  - entity: sensor.sonoff_1000916c58_power
    color: rgba(33, 150, 243, 0.6)
    max: 3450
    show_state: true
    show_icon: false
  - entity: sensor.sonoff_1000916c58_energy
    max: 24
    show_state: true
    show_icon: false
  - entity: input_number.producao_mensal_total
    max: 650
    show_state: true
    show_icon: false
direction: up
height: 200px
stack: horizontal
width: 100%
style: |
  ha-card {
    background: none;
    border: none;
card_mod:
  style: |
    bar-card-backgroundbar {
      background-image: url('/local/PainelHoy3.png'); /* Imagem do painel solar */
      background-size: cover;
      background-position: center center;
      background-repeat: no-repeat;
      border-radius: 0px; /* Sem bordas arredondadas */
    bar-card-currentbar {
      background: rgba(33, 150, 243, 0.6); /* Cor atual da barra */
      clip-path: polygon(0 100%, 100% 100%, 100% calc(100% - var(--bar-percent)), 0 calc(100% - var(--bar-percent))); /* Ajusta o preenchimento da barra */
    bar-card-name, bar-card-value {
      text-shadow: 1px 1px black;
Just like to share my Barcard LCARS Template Navigation
entities:
  - entity: sensor.aktuelle_temperatur_waschekeller_mittelwert
    tap_action:
      action: navigate
      navigation_path: /dashboard-lcars/waschekeller
  - entity: sensor.hk_ug_bad_temperatur
    tap_action:
      action: navigate
      navigation_path: /dashboard-lcars/bad-keller
  - entity: sensor.hk_ug_werkkeller_temperatur
    tap_action:
      action: navigate
      navigation_path: /dashboard-lcars/werkkeller
unit_of_measurement: Ā°C
attribute: false
background_style: false
card_style: false
charge_entity: false
decimal: 0
direction: up
show_icon: true
animation:
  state: "on"
severity:
    to: "10"
    color: navy
    to: "15"
    color: mediumslateblue
    to: "18.9"
    color: skyblue
    to: "21"
    color: seagreen
    to: "22.9"
    color: tomato
    to: "40"
    color: crimson
positions:
  icon: inside
  indicator: "off"
  minmax: "off"
  value: inside
min: 0
max: 40
target: 21
stack: horizontal
card_mod:
  style: |
    bar-card-value, bar-card-name {
      font-weight: bold;
      margin-left: auto;
      margin-right: auto;
      text-shadow: 1px 1px 2px #0009;
      bar-card-name {
      font-size: 1rem;
      line-height:1.5rem;
      margin-top: 1.85rem;
      text-transform:uppercase;
    bar-card-value {
      font-size: 1.25rem;
      line-height:.1.3rem;
      margin-bottom: 0.75rem;
    .card-content { text-align: start; padding: 0px; margin: 0px; margin-bottom:
    0px; }
    ha-card { box-shadow: none;}
    ha-icon {
      width: auto;
      height: auto;
      margin-top:2rem;
      margin-left:auto;
      margin-right:auto;
    bar-card-row {
        --primary-text-color: white;
        font-size: 1rem;
        border-radius:30px;
    ha-card {
      --card-mod-icon-color: white;
      --mdc-icon-size: 4rem;
  class: middle-right
grid_options:
  columns: 12
  rows: 2
Hi! Loving this card, thanks! I set up another for my UPS last night. How can I close up the gaps between the bars? Iā€™ve tried a number of style options shown elsewhere and none work.
  1. There is an option (cannot name it exactly) in bar-card to remove some paddings.
  2. Card-mod can be also used for styling.
Can card-mod be used? The docs Iā€™ve read say it canā€™t work on a grid card. If anyone can find the option I need to add Iā€™ll be grateful, as I canā€™t.
There is a bar-card on your screenshot.
Wrong, card-mod definitely works for a stock Grid card (if you mean this card), there is nothing about a Grid card in Docs for card-mod. (it is only mentioned that cards w/o ā€œha-cardā€ should be styled by using mod-card - and it is related to Grid card)
I donā€™t recall where I got the example from, but it was nested inside a grid card. Clearly wrong. Iā€™ve cut down my card to just two sensors and tried to style it. Any idea what Iā€™m doing wrong, please? If I go into Inspect mode, add ā€˜height: 22px;ā€™ to the bar-card-card:last-child{} style, the results look great. I just canā€™t get the style to work via config.
height: 25px
style: |
  bar-card-card:last-child {
      margin-right: 0px;
      height: 22px;
entities:
  - type: sensor
    entity: sensor.office_ups_ups_battery_charge
    name: UPS Battery Charge
    severity:
        to: "33"
        color: Red
        to: "66"
        color: Amber
        to: "100"
        color: Green
  - type: sensor
    entity: sensor.office_ups_ups_battery_runtime
    name: UPS Battery Runtime
    max: 30
    severity:
        to: "10"
        color: Red
        to: "20"
        color: Orange
        to: "30"
        color: Green
square: false
columns: 1
You copy-pasted this card. You can clearly see a card-mod code. Have you read docs for card-mod?
If not - this is wrong absolutely. Using HA needs reading docs. In short - card-mod code is wrong since it lacks a ā€œcard_modā€ keyword.
I had. I have the entry for it in configuration.yaml, restarted everything. I tried this at one point and it didnā€™t work either.
card_mod:
  style: |
      margin-right: 0px;
      height: 22px;
I looked at other examples which didnā€™t show the card_mod: so I tried that. Thatā€™s one annoying thing about using the Internet, thereā€™s plenty wrong examples to muddy the waters.
As for absence of ā€œcard_modā€ keyword - could be another case: this keyword became mandatory on 2022 (or 2021?).
Cannot test it myself now. Try asking in the main card-mod thread.
Doh! This works, after a while away from it and a chance for the cache to clear.
So, what was a reason of a failure, why it did not work?
I honestly have no idea, other than maybe something being stuck in a cache? Iā€™d saved the YAML, didnā€™t see the results I wanted, so got on with some home DIY. A good while later I unlocked my phone to do something unrelated and saw the card had changed. Frustrating!
Do you have the latest version of card-mod installed?
Love these, they look fab.
