You can try setting the title
attribute:
- type: custom:button-card
return `<span title="Calendar">Cal</span>`
attribute:
well not sure anymore, I have tried a lot of things, up to this:
template: button_shortcut_menu
extra_styles: |
/* Tooltip container */
.tooltip {
position: relative;
display: inline-block;
/* Tooltip text */
.tooltip .tooltiptext {
visibility: hidden;
width: 120px;
background-color: blue;
color: red;
text-align: center;
padding: 5px 0;
border-radius: 6px;
/* Position the tooltip text - see examples below! */
position: absolute;
z-index: 1;
/* Show the tooltip text when you mouse over the tooltip container */
.tooltip:hover .tooltiptext {
visibility: visible;
[[[ return `<div class='tooltip'><ha-icon icon='mdi:calendar'</ha-icon>
<span class='tooltiptext'>Tooltip text</span>
</div>` ]]]
tap_action:
action: navigate
navigation_path: /lovelace/tijd_agenda
which does give me the icon,
(which if course is a trick, but using the icon: field doesn’t show an icon…)
You might need to put your mouse there for longer. Try out:
[[[ return `<ha-icon icon='mdi:calendar' title='Calendar'></ha-icon>` ]]]
tap_action:
action: navigate
dont understand this really, where’s the tooltip text in your example? You seem to be mixing name, icon and tooltip in 1 go ?
in all examples online, the tooltip is immediate…
The tooltip text is the title='Calendar'
part.
well I be d…
immediately tried this:
icon: >
but the field icon still doesnt show an icon.;-(
now, next challenge, how to get the tooltip to show in the button:
icon: mdi:light-switch
tap_action:
action: navigate
navigation_path: /lovelace/lights
variables:
path: lights
styles:
icon:
- color: >
return (states['group.all_inside_lights'].state == 'on')
? 'gold': 'grey';
[[[ return variables.path.replace('_',' ').toUppercase() ]]]
as tooltip
Try removing any other icon declarations. Try this:
icon: >
[[[ return `<ha-icon icon='${entity.attributes.icon}' title='${variables.path.replace('_',' ').toUppercase()}'></ha-icon>` ]]]
my buttons don’t have an entity… so I cant use entity.attributes.icon
I am afraid. Hence the icon declaration in my current buttons.
maybe use the
[[[ return<ha-icon icon='mdi:light-switch' title=’${variables.path.replace(’_’,’ ‘).toUppercase()}’></ha-icon> ]]]
What about
variables:
path: lights
icon: >
[[[ return `<ha-icon icon='${variables.icon}' title='${variables.path.replace('_',' ').toUppercase()}'></ha-icon>` ]]]
I have the following template for a transparent label card and it works fine for most the groups except for lights. When one of the entities in the group turns on, then the label fades out. This happens only on light theme backgrounds. How do I fix this?
transparent_header_card:
color_type: label-card
color: transparent
show_icon: false
styles:
card:
- background-color: transparent
- box-shadow: none
name:
- font-size: 20px
- text-align: center
- letter-spacing: '-0.01em'
- font-weight: bold
- type: 'custom:button-card'
template: transparent_header_card
entity: group.lights
tap_action:
action: toggle
confirmation:
text: '[[[ return `Are you sure you want to turn on or off all ${entity.attributes.friendly_name}?` ]]]'
Hi Petro,
thank you for help!
i copy an paste your Code with my entities:
type: picture-elements
image: /local/images/transparent_1to1.png
style: |
ha-card {
border-radius: 15px;
elements:
- type: custom:mini-graph-card
style:
top: 40%
left: 50%
width: 100%
height: 80%
translate: translate(-50%, -50%)
'--paper-card-background-color': 'rgba(0, 0, 0, 0.0)'
'--ha-card-background': "rgba(0, 0, 0, 0.0)"
'--ha-card-box-shadow': 'none'
z-index: 3
pointer-events: none
entities:
- sensor.owm_temperature
group: true
points_per_hour: 1
hour24: true
line_color: var(--paper-item-icon-active-color)
line_width: 10
hours_to_show: 24
update_interval: 600
show:
icon: false
state: false
points: false
legend: false
average: false
extrema: false
labels: false
fill: false
labels_secondary: false
name_adaptive_color: false
icon_adaptive_color: false
style:
top: 50%
left: 50%
width: 100%
aspect_ratio: 1/1
entity: sensor.owm_temperature
color: var(--paper-item-icon-color)
show_name: true
show_label: true
show_icon: true
show_last_changed: true
tap_action:
action: more-info
haptic: light
styles:
icon:
- opacity: 0.3
- width: 100%
img_cell:
- top: 0%
- left: 30%
- position: absolute
- z-index: 2
grid:
- grid-template-areas: '"info info" "n n" "l l"'
- grid-template-columns: 40% 1fr
- grid-template-rows: 1fr min-content min-content
- position: relative
card:
- padding: 10px
- z-index: 1
name:
- justify-self: start
- align-self: end
- font-weight: bold
- font-family: Helvetica
- font-size: 12px
- text-align: start
- background-image: linear-gradient(to right, white 0%, white 80%, rgba(0,0,0,0))
- -webkit-background-clip: text
- -webkit-text-fill-color: transparent
- display: inline-block
- width: 100%
- align-content: start
- text-align: start
- text-overflow: unset
- z-index: 5
label:
- align-self: end
- font-weight: bold
- font-size: 12px
- text-align: start
- background-image: linear-gradient(to right, var(--paper-item-icon-color) 0%, var(--paper-item-icon-color) 80%, rgba(0,0,0,0))
- width: 100%
- text-align: start
- z-index: 5
custom_fields:
info:
- align-self: start
- width: 40%
- z-index: 5
custom_fields:
info: >
var entity_id = (entity === undefined) ? 'Invalid Entity' : entity.entity_id;
var statestr = (entity === undefined || entity.state === undefined) ? null : entity.state;
var units = (statestr && entity.attributes.unit_of_measurement) ? entity.attributes.unit_of_measurement : null;
var date = (statestr && entity.attributes.device_class === 'timestamp') ? new Date(statestr) : null;
var value;
if (statestr && date === null) {
if (statestr.split('.').length - 1 <= 1){
var test = parseFloat(parseFloat(statestr).toFixed(2));
value = (isNaN(test)) ? null : test;
// test if units are in the state because some sensors are stupid. Looking
// at you synology.
const expr = /[^-.0-9]+/;
var has_units = expr.test(statestr.trim());
// console.log(`${entity_id}: "${statestr}" ${matches}`);
if (value && has_units)
units = statestr.replace(/[.0-9]+/, '');
// console.log(`${entity_id}: ${statestr}, ${units}, ${date}, ${value}`);
const length = 50;
const width = 3;
var radius = length / 2;
if (date){
let now = new Date();
var tdelta = Math.floor((now - date)/1000);
// console.log(`${entity_id}: ${tdelta}`);
function plural(descriptor, divisor){
var ret = Math.floor(tdelta/divisor);
return (ret == 1) ? [ret, descriptor] : [ret, `${descriptor}s`];
var values;
if (tdelta < 60)
values = plural('second', 1);
else if (tdelta < 60 * 60)
values = plural('minute', 60);
else if (tdelta < 60 * 60 * 24)
values = plural('hour', 60 * 60);
else if (tdelta < 7 * 60 * 60 * 24)
values = plural('day', 60 * 60 * 24);
else
values = plural('week', 7 * 60 * 60 * 24);
return `
<svg viewBox="0 0 50 50">
<circle cx="25" cy="25" r="${radius}" fill="var(--paper-item-icon-active-color)" />
<text x="50%" y="43%" fill="var(--paper-card-background-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${values[0]}<tspan x="50%" dy="1.2em" font-size="10" font-weight="normal" >${values[1]}</tspan>
</text>
</svg>
else if (value && units && units === '%') {
radius = (length - 3) / 2;
const circumference = radius * 2 * Math.PI;
return `
<circle cx="25" cy="25" r="${radius}" fill="none" stroke="var(--paper-item-icon-color)" opacity="0.5" stroke-width="${width}" />
<circle style="
transform: rotate(-90deg);
transform-origin: 50% 50%;
stroke-dasharray: ${circumference};
stroke-dashoffset: ${circumference - value / 100 * circumference};
id="c_brightness" cx="25" cy="25" r="${radius}" stroke="var(--paper-item-icon-active-color)" stroke-width="${width}" fill="none" stroke-linecap="round" />
<text x="50%" y="54%" fill="var(--primary-text-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${value}<tspan font-size="10" font-weight="normal" >%</tspan>
</text>
</svg>
else if (value && units && units.includes('°')) {
return `
<text x="50%" y="54%" fill="var(--paper-card-background-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${value}<tspan font-size="10" font-weight="normal" >${units}</tspan>
</text>
</svg>
else if (value && units && units.length > 1) {
var y = (String(value).length > units.length) ? "50%" : "43%";
return `
<text x="50%" y="${y}" fill="var(--paper-card-background-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${value}<tspan x="50%" dy="1.2em" font-size="10" font-weight="normal" >${units}</tspan>
</text>
</svg>
else if (value) {
return `
</text>
</svg>
return `
<text x="50%" y="54%" fill="var(--paper-card-background-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${statestr}
</text>
</svg>
but it doesn’t show me anything and I have no error in the log or anything.
nope, sorry. as long as I use the icon: field, no icon is displayed using the templates we tried.
also, it doesnt like the template, so above I took that out for testing purposes, trying to take it one step at a time…
button-card.js?v=3.3.6:1643 ButtonCardJSTemplateError: TypeError: variables.path.replace(...).toUppercase is not a function in 'return `<ha-icon icon='mdi:light-switch' title='${variables.path.replace('_',' ').toUppercase()}'>...
all in all, it seems this is either not possible, or we need the hand of the author to make it possible. Hope Rom is having a look anytime soon…
I guess, what would be easiest is a dedicated tooltip variable, set that in the button_card template as follows:
button_shortcut_menu:
variables:
dashboard: >
[[[ return window.location.pathname.split('/')[1] ]]]
view: >
[[[ return window.location.pathname.split('/').slice(-1) ]]]
styles:
icon:
- color: var(--secondary-text-color)
# add a new styles field for the tooltip here
- tooltip: >
[[[ return variables.tooltip ]]]
card:
- box-shadow: none
- background: >
[[[ return variables.view == variables.path
? 'var(--secondary-background-color)' : 'var(--card-background-color)';
extra_styles: |
.tooltip {
position: relative;
border-bottom: 1px dotted black; /* If you want dots under the hoverable text */
/* Tooltip text */
visibility: hidden;
width: 120px;
background-color: black;
color: red;
text-align: center;
padding: 5px 0;
border-radius: 6px;
position: absolute;
z-index: 1;
and then set the button card config like:
variables:
path: lights
tooltip: Light panel # <----
tap_action:
action: navigate
styles:
icon:
- color: >
? 'gold': 'grey';
for now I’m forced to go back to my tooltip-less shortcut menu bar
Capitialization:
variables:
path: lights
icon: >
[[[ return `<ha-icon icon='${variables.icon}' title='${variables.path.replace('_',' ').toUpperCase()}'></ha-icon>` ]]]
toUppercase
toUpperCase
Is there anyway I can get a camera view to take up the whole of the button space please? No matter what I do, I get a small snapshot in a larger button
entity: camera.front_door
show_entity_picture: 'true'
styles:
card:
- height: 300px
Nicely spotted. thanks.
doesnt work though, no icon using the icon field… (error has gone , so that’s good )
have a look:
button-card-template:
variables:
dashboard: >
view: >
icon: >
styles:
icon:
card:
- box-shadow: none
- background: >
extra_styles: |
.tooltip {
position: relative;
/* Tooltip text */
visibility: hidden;
width: 120px;
color: red;
text-align: center;
padding: 5px 0;
border-radius: 6px;
position: absolute;
z-index: 1;
and buttons like:
variables:
path: home
icon: mdi:home
tap_action:
action: navigate
navigation_path: /lovelace/home
styles:
icon:
- color: >
return (states['sensor.count_alerts_notifying'].state > 0)
? 'red': 'green';
state:
- operator: template
value: >
[[[ return (states['sensor.count_alerts_notifying'].state > 0) ]]]
spin: true
# icon: mdi:light-switch
variables:
path: lights
tap_action:
action: navigate
styles:
icon:
- color: >
? 'gold': 'grey';
this works ok for the icon to show
icon: >
[[[ return variables.icon ]]]
though somehow my background color gets killed…
styles:
card:
- height: 300px
should work I think
perfect thank you… it was that simple
Any idea how often the thumbnail refreshes please?
First of all, completely remove the extra_styles
. You don’t have to, but you should.
I think it might be that the way that button-card renders the icons ha-icon
won’t work. We’ll see what happens…
Probably as often as the entity_picture
refreshes and button-card
bothers to check…
