Lovelace: Button card
As do I, but haven’t observed any breaking changes.
Per @Mariusthvdb/@parautenbach, are you sure the states exist?
The fault is probably in this part, for debug try not to use the decluttering template, but use a clean template for button-card.
Here it is confusing that for decluttering template is used for variable [[ ]], and button card everything that is in [[[ ]]] is javascript, for some variables it can happen that it doesn’t return the correct value and therefore error occurs :man_shrugging:
This is quite normal with a button card within a decluttering card.
@tismondo The double quotes seems odd though. I would have:
(states['[[sensor1-2]]'].state == '[[state1-2]]')
                                  ^            ^ single quote here
here
please do as we’ve asked you twice now, test without the decluttering card
you need to eliminate the root cause, and can do by verifying the direct config works. I thats ok, then build the decluttering bit by bit
also, make life easy on yourself, and use better variable names, because the ones you use now are prone to mixup and confusion
For a test I tried a similar decluttering template with button card, it works with double quotes. Probably in his case the sensor will be unavailable.
my templates looks like this
test_template:
  card:
    type: custom:button-card
    entity: '[[sensor1-2]]'
    show_name: false
    show_state: false
    show_label: true
    show_icon: false
    label: >
        if (states['[[sensor1-2]]'].state == "[[state1-2]]") {
          return `<ha-icon icon="mdi:[[icon1-2]]"></ha-icon> Turn Off`;
        } else {
          return `<ha-icon icon="mdi:[[icon1-1]]"></ha-icon> Turn On`;
button-card
cards:
  - type: custom:decluttering-card
    template: test_template
    variables:
      - sensor1-2: light.ceiling_lights
      - state1-2: 'on'
      - icon1-2: lightbulb-on
      - icon1-1: lightbulb-off
2024-10-21 17.18.24
compound post I previously posted in card-mod.… since I have found no card-mod solution but do all in button-card now, Ill repost the set below:
this could be posted in a tile card or custom:button-card thread too, but since I am trying to find the right card-mod, I’ll start here…
I have this tile card mod
      type: tile
      icon: mdi:water
      vertical: true
      tap_action:
        action: more-info
      card_mod:
        style: |
          .icon-container {
            border-radius: 24px;
            background: radial-gradient(var(--card-background-color) 60%,transparent calc(60% + 1px)),
            conic-gradient(var(--tile-color) {{states(config.entity)}}% 0%,
            var(--card-background-color) 0% 100%);
which draws a perfect border according to the percentage of the entity:
I’d love to do the same with my light buttons, but cant find the right mod to do so:
I have some of these on a custom field:
  custom_fields:
    info: &info_light
        [[[ if (entity.state === 'on' && entity.attributes.brightness) {
            var brightness = Math.round(entity.attributes.brightness/2.54);
            const radius = 20.5;
            const circumference = radius * 2 * Math.PI;
            return `
              <svg viewBox="0 0 50 50">
                <circle cx="25" cy="25" r="${radius}"
                  stroke="var(--button-card-light-color,var(--active-color))" stroke-width="2" fill="none"
                  style="transform: rotate(-90deg);transform-origin: 50% 50%;
                  stroke-dasharray: ${circumference};
                  stroke-dashoffset: ${circumference - brightness / 100 * circumference};" />
                <text x="50%" y="54%" fill="black" font-size="16" font-weight= "bold"
                  text-anchor="middle" alignment-baseline="middle">
                  ${brightness}<tspan font-size="10">%</tspan>
                </text>
              </svg>
and that works fine:
Scherm­afbeelding 2024-10-23 om 17.44.58
. but in this case I want the border to be drawn on the img_cell of the button-card, or, checking the element in the dom, the .img-cell
so I copied that tile card mod over to
  card_mod:
    style: |
      .img-cell {
        conic-gradient(var(--button-card-light-color) {{states(config.entity)}}% 0%,
note I did change to the button-card-light-color, but nothing is happening…
this is the original button with a regular style section on the image_cell:
    img_cell:
      - justify-content: center
      - background: >
          [[[ var rgb = (entity.state === 'on')
                ? entity.attributes.rgb_color : '211,211,211';
              return 'rgba(' + rgb + ',0.2)'; ]]]
      - border-radius: 24px
      - place-self: start
      - width: 42px
      - height: 42px
Scherm­afbeelding 2024-10-23 om 17.39.29
but when I take that out, and change to the card-mod there is nothing:
tbh, I wouldn’t yet know how to write the background in styles syntax native to the custom:button-card, thats why I tried it with card-mod
please have a look what could be done to fix this?
Follow up
well there is progress:
      - background: >
              var rgba = 'rgba(' + rgb + ',0.2)';
              if (entity.state === 'on')
              return `radial-gradient(${rgba} 80%,transparent calc(60% + 1px)),
                      conic-gradient(var(--button-card-light-color) ${Math.round(entity.attributes.brightness/2.55)}% 0%,
                      var(--card-background-color) 0% 100%)`;
             return `${rgba}`; ]]]
and
  triggers_update:
    - entity
does a lot of good, thanks to @khaisilk1910 for helping me in Discord!
the final thing I need now is get rid of the actual conic, and have the background inside the img_cell only show that conic in the outer border…
just like in the print cartridge buttons…
I cant see it though
alternative since there is no apparent way to do as I hoped:
    img_cell:
      - background: >
          [[[ var rgb = entity.state === 'on'
              return entity.state === 'on'
              ? `radial-gradient(var(--card-background-color) 60%,transparent calc(60% + 1px)),
                 ${rgba} 0% 100%)`
              : `${rgba}`; ]]]
___ And finally at least 1 solution___
it has to do with the left over section of the overlay (but no, it didnt make any difference in solar I could find out)
I’ve found another solution now though:
I am using the same info custom field, and I overlay it exactly over the icon img_cell of the button-card. It feels a bit hacky, and ofc its not 100% linked to the img_cell itself (not all as a matter of fact, it’s just a custom field after all) but is is the best I could come up with for now.
CSS for the border percentage....
  custom_fields:
    info: >
          return `
                stroke="var(--button-card-light-color,var(--active-color))" stroke-width="2" fill="${rgba}"
            </svg>
  styles:
    custom_fields:
      info:
        - position: absolute
        - left: 2%
        - top: 4%
        - width: 48px
Scherm­afbeelding 2024-10-25 om 11.50.34
OMT:
I can omit the
triggers_update:
  - entity
after all. It was unexpected I needed it before, but now the templates are working, the card successfully triggers automatically
Love it! Great CSS work…
Brilliant - thanks for sharing!
small update, because there were some anomalies in the on state without rgb_color attribute (showing the 211,211,211 color…) and I added some unavailable/unknown colors.
  custom_fields:
    info: >
            var rgb = (entity.attributes.rgb_color)
                       ? entity.attributes.rgb_color : '254,181,13' ;
          if (entity.state === 'off') {
            var rgb = '211,211,211';
          if (entity.state in ['unknown','unavailable']) {
            var rgb = '189,189,189';
          return `
                stroke-width="3"
                fill="${rgba}"
            </svg>
  styles:
    custom_fields:
      info:
        - left: 1%
        - top: 4%
        - width: 50px
also notice the styling/position change… it had to be 50 because of the viewbox using 50px too…
next to that, you’ve got to be aware the button-card’s background still exists. So, when using a darker theme the color of the circle gets frustrated by that darker background color.
Ive tried background transparent, but obviously that doesnt help, as it makes the card background even more prominent :wink:
so for now I’ve settled to do something like:
    img_cell:
      - background: >
          [[[ if (entity.state === 'on') return 'ivory';]]]
but, that isnt optimal either (as it leaves the unused brightness area in that color. o well, its not simple at all
light theme is perfect though:
Other options to play with:
set the color of the img_cell background to the exact same color as the fill of the custom-field, not really any help
set
fill-opacity:1
fill-rule="nonzero"
to the svg view box, and play with that. doesn’t really help either.
Hey all, I’m trying to get colors represented on my button card when entity state changes and it seems to be ignoring the entire section where that is defined.
show_name: false
show_state: false
show_icon: true
show_entity_picture: true
entity: person.mark_ramos
tap_action:
  action: perform-action
  perform_action: icloud3.find_iphone_alert
    device_name: abcdef0123456
entity_id: device_tracker.mark_iphone
styles:
  card:
    - background-color: var(--contrast2)
    - padding: 10px 10px 10px 0px
  grid:
    - grid-template-areas: "\"icon name btn\" \"icon state btn\""
    - grid-template-columns: 60px 1fr min-content
    - grid-template-rows: min-content
  img_cell:
    - justify-content: start
    - width: 40px
    - height: 40px
    - left: 0
    - bottom: 0
    - margin: 0 0 8px 10px
    - border-radius: 50%
    - border: |
          if (entity.state == 'home') {
            return '1px solid var(--green)';
          } else {
            return 'none';
  entity_picture:
    - width: 40px
    - height: 40px
    - left: 0
    - bottom: 0
    - margin: 0 0 0 0
    - border-radius: 500px
  icon:
    - width: 50px
    - color: var(--contrast1)
  custom_fields:
    name:
      - align-self: start
      - justify-self: start
      - background: none
      - padding: 0
    state:
      - align-self: start
      - background: none
      - padding: 0
      - margin-top: "-5px"
    btn:
      - align-self: end
      - justify-self: end
    icon:
      - align-self: start
    badge:
      - left: 38px
      - top: 7px
custom_fields:
  name:
    card:
      styles:
        card:
          - color: var(--contrast20)
          - font-size: 14px
          - font-weight: 600
          - background: none
  state:
    card:
      entity: "[[[ return entity.entity_id ]]]"
      show_icon: false
          return states['person.mark_ramos'].state;
      state:
        - value: home
        - value: not_home
      styles:
        card:
          - font-size: 12px
          - background: none
          - opacity: "0.7"
  badge:
    card:
      show_icon: true
      show_name: false
      icon: mdi:home
      state:
        - value: home
          icon: mdi:home
          styles:
            card:
              - background: var(--green)
        - value: not_home
          icon: mdi:home-export-outline
          styles:
            card:
              - background: var(--red)
      styles:
        card:
          - width: 16px
          - height: 16px
          - background: none
        icon:
          - color: black
          - width: 12px
  btn:
    card:
      type: custom:mushroom-chips-card
      chips:
        - type: entity
          tap_action:
            action: more-info
          entity: sensor.mark_iphone_battery_3
          content_info: none
          card_mod:
            style: |
              ha-card {
                --chip-background: {{ 'var(--contrast4)' if states('sensor.mark_iphone_battery_3') | float > 10  else 'var(--red)' }};
                --color: {{ 'var(--contrast20)' if states('sensor.mark_iphone_battery_3') | float > 10  else 'var(--black)' }};
                padding: 0px!important;
                border-radius: 100px!impportant;
                --primary-text-color: var(--contrast20);
Didn’t you try to set a specific color for debug instead of css variables? Isn’t there a problem with them?
Thanks, that got me a bit further. I do think it’s related to an override somewhere in my dashboard, not within the card. I’m searching…
hey all,
super new to this but i want to do something simple, hopw to i format the date to a short date so it looks identical to the “start time” card? (i want to keep the time as is in am/pm)
my button-card styling is getting rusty…
Dec-04-2024 13-41-39
had this working with the html marquee tag before,
  [[[ return `<div style='display: flex;
                          padding: 0px 5px 0px 5px;
                         align-items: center;
                         background: transparent;'>
      <div></div>
      <marquee>
      <span style='color: var(--primary-color);align-items: center;'>${variables.cond}</span>
      </marquee>`; ]]]
Dec-04-2024 14-01-40
can even cut it short to
  [[[ return `<marquee> ${variables.cond} </marquee>`; ]]]
aspect_ratio: 1
styles:
  name:
    - display: flex;
    - padding: 0px 5px
    - font-size: 13px
    - font-weight: bold
    - color: var(--primary-color)
    - overflow: visible
and it still marquees nicely
but now want to replace that with the modern css translateX animation…
cant get the name to remain inside the padding of the card, not even if I set it explicitly with
    - display: flex;
    - padding: 0px 5px 0px 5px
the translateX ignores that and makes it overflow…
template:
  - styles_cf_notification
  - styles_cf_notification_left
variables:
  cond: >
    [[[ return states['sensor.buienradar_woensdrecht'].attributes.weatherdescription; ]]]
show_name: true
  [[[ return variables.cond; ]]]
aspect_ratio: 1
extra_styles: |
  @keyframes marquee {
    from {transform: translateX(20%);}
    to {transform: translateX(-50%);}
styles:
  name:
    - font-size: 13px
    - font-weight: bold
    - overflow: visible
    - animation: >
        [[[ return variables.cond.length > 20? 'marquee 3s linear infinite' : 'none' ; ]]]
could anyone help me out seeing what’s wrong?
How to limit the translateX to remain inside the cards padding.
it’s not the overflow property, I need to set that as visible, or it will be truncated with the ..... if longer than the available space
Here’s my recipe. This is a gif capture; the actual result is much smoother.
Kept the states/variables/styles/extras, you can trim down as needed.
You can play with speed depending on your string lenght.
Took me while to figure out how to get that continuous loop without breaks.
doubling the string + 50% transition does the trick.
Hope this helps, cheers.
Animation
  [[[return `<div class="wrapper">
    <div class="marquee">
      <p>
        🚨TEMPERATURE:
        ${states['sensor.ss_temperature'].state}°C /
        ENERGY:
        ${ parseFloat(states['sensor.energymon3_home_power_total_kw'].state).toFixed(2) } kWh
      </p>
      <p>
        🚨TEMPERATURE:
        ENERGY:
      </p>
      </div>
      </div>`]]]
extra_styles: |
  .wrapper {
    max-width: 100%;
    overflow: hidden;
  .marquee {
    white-space: nowrap;
    overflow: hidden;
    display: inline-block;
    animation: marquee 3s linear infinite;
  .marquee p {
    0% {
      transform: translatex(0);
    100% {
      transform: translatex(-50%);
  @keyframes glow {
    50% {box-shadow: 0 0 20px 10px red;}
styles:
  card:
    - height: 3rem
    - padding: 5rem
    - background: black
    - animation: glow 1s linear infinite
  name:
    - font-size: 3rem
    - font-weight: bold
    - white-space: normal
    - background: black
    - color: red
thanks, experimenting a bit, and struggling to get the positioning on the button correctly. and need to force it using
styles:  name:
    - top: 73%
    - left: 5%
    - right: 5%
otherwise the scroll box simply isnt wide enough
… but its scrolling alright :wink:
I want to conditionally scroll and had
    - animation: >
before as a test length. I really it should only scroll if the length of the string is longer than the available width, but for now I believe I can count the pixels :wink:
Andy thoughts how we can achieve conditional scrolling using the marquee class?
what exactly do you mean with:
I dont see you calculating the string length anywhere? or apply this in the styles?
fwiw, I now use this (left out all non relevant stuff):
variables:
  cond: >
show_name: true
               <div class="marquee"> <p> ${variables.cond}</p> </div>
             </div>`; ]]]
aspect_ratio: 1
extra_styles: |
    from {transform: translateX(100%);}
    to {transform: translateX(-100%);}
  .marquee {
styles:
  name:
    - top: 73%
    - left: 5%
    - right: 5%
to get this
Dec-06-2024 10-16-22
as you can see I forced the box for the wrapper, without the positioning it is
Dec-06-2024 10-17-46
What I wanted Is a continuous loop with no break. In your example above, the whole text has to be out of the frame before it starts again.
In my example, you will notice the text (“name” section) is duplicated once. So if you transition half of it left (-50%) and restart, you will get a continuous loop/no break.
right, I see what you mean now, thx.
I’ve moved some of that styling to the div and made it conditional (on a manual count of the max button width of 20…)
  [[[return variables.cond_length > 20
      ? `<div class="wrapper"
               style='margin: 0px 10px -15px 10px;'>
               <div class="marquee"> <p>${variables.cond}</p> </div>
             </div>`
       : variables.cond; ]]]
or, can also move it to the extra_styles for that element:
extra_styles: |
    to {transform: translateX(-150%);}
  .marquee {
    margin: -5px 10px -15px 10px;
that styling moves the scrolling name to the desired spot more or less. Still feels hacky.
Here’s a trimmed down version for reference; just need to ensure the text is repeated twice.
  [[[return `
        🚨ANY TEXT YOU WANT HERE🚨ANY TEXT YOU WANT HERE
      </div>
      </div>`]]]
extra_styles: |
  .marquee {
    0% {
    100% {
styles:
  card:
    - height: 5rem
    - padding: 2rem
    - background: black
  name:
    - font-size: 3rem
    - background: black
    - color: red
And you can use layout card to manage elements/locations/paddings/margins/etc:
Animation2
