Lovelace: Button card
iPadOS :wink:
Oke. I will do some more testing tonight. Maybe it’s just a cache issue like you said. Thx for the research ! :slightly_smiling_face:
Did some more testing. Clearing cache didn’t solve the problem. Only switching to mobile view solves the problem. Safari will remember the mobile view for the specific url so luckily the “fix” is permanent.
made a simple button-card for my covers. is there any way to show in what state they are (highlight it for exmaple)?
  - cards:
      - icon: 'mdi:arrow-up-box'
        tap_action:
          action: call-service
          haptic: success
          service: cover.set_cover_position
          service_data:
            entity_id: group.all_covers
            position: 100
        type: 'custom:button-card'
      - icon: 'mdi:arrow-right-box'
        tap_action:
          haptic: success
          service_data:
            position: 50
      - icon: 'mdi:arrow-down-box'
        tap_action:
          haptic: success
          service_data:
            position: 0
    type: horizontal-stack
If you know the states of your covers, you can show it with the state operator.
I use this:
Cover fully open:
20190926_17%3A28%3A56_001
Cover moving:
20190926_17%3A28%3A23_001
Sun protect position:
20190926_17%3A29%3A47_001
with these templates:
button_card_templates:
  ## Cover Buttons ##
  cover_up:
    show_name: false
    icon: mdi:arrow-up-thick
    tap_action:
      service: cover.open_cover
      service_data:
        entity_id: entity
    styles:
      card:
        - background-color: rgba(0, 0, 0, 0.0)
    state:
      - operator: template
        value: >
          [[[ return entity.attributes.current_position == 100 ]]]
        color: var(--my-icon-off)
      - value: 'on'
        color: var(--my-green)
      - operator: default
        color: white
  cover_down:
    template: cover_up
    icon: mdi:arrow-down-thick
    tap_action:
      service: cover.close_cover
      service_data:
        entity_id: entity
    state:
        value: >
          [[[ return entity.attributes.current_position == 0 ]]]
  cover_stop:
    show_name: false
    icon: mdi:stop
    tap_action:
      service: cover.stop_cover
      service_data:
        entity_id: entity
    hold_action:
      service_data:
        entity_id: entity
        position: 25
    styles:
      card:
    state:
        value: >
          [[[ return entity.attributes.current_position >= 23
          && entity.attributes.current_position <= 27 ]]]
        color: var(--my-yellow)
        icon: mdi:sunglasses
        value: >
          [[[ return states['script.cover_' + entity.entity_id.split('.')[1] + '_open'].state == 'on'
          || states['script.cover_' + entity.entity_id.split('.')[1] + '_close'].state == 'on' ]]]
        color: var(--my-red)
      - operator: default
        color: white
and the card:
          ## Cover Test 1 #################
          - type: entities
            title: TEST Cover 1
            show_header_toggle: false
            entities:
              - type: custom:hui-horizontal-stack-card
                cards:
                  - type: custom:button-card
                    template: cover_up
                    entity: cover.test_1
                    template: cover_stop
                    show_entity_picture: true
                    hold_action:
                      service_data:
                        entity_id: entity
                        position: 28
                    state:
                        value: >
                            return entity.attributes.current_position >= (28-2)
                            && entity.attributes.current_position <= (28+2)
                        #color: var(--my-yellow)
                        #icon: mdi:sunglasses
                        entity_picture: /local/esunglass.png
                    template: cover_down
              - type: custom:fold-entity-row
                head:
                  type: custom:slider-entity-row
                  full_row: true
                entities:
                  - entity: input_number.cov_test_1_duration
                  - entity: input_number.cov_test_1_offset
                  - entity: input_number.cov_test_1_counter
The slider at the bottom is from here:
I have a question if anybody can answer it.
Im using home assistant cast, Im trying to get my buttons to display on my TV but most of the cards will not render properly. Is there something I can do to get these to show or is it something in the code that would make this card render properly. It does show up fine if I cast from a tab on my laptop but not by calling the service.
Thanks in advance!
Check the last item: https://cast.home-assistant.io/faq.html#browser
I want to change the style of the state based on the current date. I have a sensor which shows the date the carbage is collected. It would be nice if i could make the text color change to another color when the date ius equal to the current date. So something like this :
state:
  - value: 'current date variable ??'
    styles:
      state:
        - color: green
Is it possible somehow to make this work?
i.e. Set the icon based on a battery’s state value and also set other things if it is below a specific value?
      - value: '[[[ if (entity.entity_id.includes("battery")) return 40 ]]]'
        operator: <
        styles:
          card:
            - opacity: 1.0
            - box-shadow: '[[box_shadow]] [[box_shadow_color]]'
            - color: var(--secondary-text-color)
          icon:
            - color: red
            - animation: blink 2s ease infinite
      - value: '[[[
                    if (entity.entity_id.includes("battery")) return 0;
                    else return 101;
        operator: '>='
        icon: >
            if (entity.state < 20) return "mdi:battery-10";
            if (entity.state < 30) return "mdi:battery-20";
            if (entity.state < 40) return "mdi:battery-30";
            if (entity.state < 50) return "mdi:battery-40";
            if (entity.state < 60) return "mdi:battery-50";
            if (entity.state < 70) return "mdi:battery-60";
            if (entity.state < 80) return "mdi:battery-70";
            if (entity.state < 90) return "mdi:battery-80";
            if (entity.state < 100) return "mdi:battery-90";
            if (entity.state = 100) return "mdi:battery";
you could at least set the device_class to battery on those sensors, so they automatically adjust the icon. The button will use that icon, so you don’t need t set the template here.
Wow! Thank you. I never knew you could set the device_class in customize.
But then since Lovelace I have not used customize for anything
yes, I see that all over.
Was just examining some of my own button cards configs, which became loaded with templates like that, thus overloading the frontend with it.
Simply moving a template to a dedicated template sensor, and use the state of that sensor in the button-card config makes it all so much easier to configure, and lighter on the system.
Its too bad the buttons cant take the already set icon_color too. Coming form the pre Lovelace age (
) I had all my entities already customized via customize, including colors using the custom-ui. This is not imported by the buttons. Luckily it is used by regular Lovelace cards, to all is not in vein :wink:
This didn’t seem to change the icon based on the state
homeassistant:
  customize:
    sensor.kitchen_battery_level:
      device_class: battery
well what can I say
45
I take it you did restart
 using the same
sensor.hallway_frontdoor_bewegingssensor:
sensor.hallway_dresser_bewegingssensor:
I did do a restart, yes. You can see the new device_class in the states page screenshot
More HA weirdness
 :thinking:
Remove the icon configuration. device_class sets its own icons.
are these handmade template sensors, or system generated ones?
Yes I did that but it didn’t work. I haven’t had time today to look any further but will do.
System generated. They are created by ESPHome. Does that make a difference?
not sure, but I had issues customizing Python made entities, and ended up customizing those in the python scripts
also there have been 1 or sensors I couldn’t get to change according to completely valid customizations.
I don’t use ESPHome, so wouldn’t know if that already sets some customizations.
Well to be honest I’m happy as it is.
I have my first template set the icon to red with an alert battery symbol and my fancy animation and border.
If that doesn’t evaluate because the charge is too high it then goes on to template the icons for different charge levels.
It’s all just fancy fluff anyway!! :rofl::rofl::rofl::rofl:
