can i set a dynamic icon so it changes when an entity becomes unavailable?
That’s what I use when an entity is unavailable (only relevant parts of the config are shown):
I display an icon in the top right corner which is blinking and the icon and name are greyed out.
- type: custom:button-card
styles:
grid:
- position: relative
custom_fields:
status:
- display: none
- position: absolute
- right: 5%
- top: 5%
custom_fields:
status: >
return `<ha-icon icon="mdi:lan-disconnect" style="width: 16px; height: 16px"/>`
state:
- value: unavailable
styles:
icon:
- color: '#666666'
name:
- color: '#666666'
custom_fields:
status:
- display:
- color: red
- animation: blink 2s ease infinite
Hi Rom,
i want to add percent number when lights is on, how can i do it?
This is my button template:
Button2:
card:
type: 'custom:button-card'
color: auto
icon: '[[icon]]'
entity: '[[entity]]'
show_last_changed: true
aspect_ratio: 1/1
show_state: true
show_label: true
tap_action:
action: toggle
haptic: light
hold_action:
action: more-info
haptic: success
styles:
card:
- padding-left: 10px
# - background-color: 'rgba(255,255,240,0.9)'
- background-color: '#fff5bc'
- border-radius: 15px
name:
- justify-self: start
- font-weight: bold
- font-size: 13px
label:
- font-size: 11px
- font-family: Helvetica
- padding: 0px 10px
state:
- font-size: 11px
- padding: 1px 10px
- text-transform: capitalize
- font-weight: bold
grid:
- grid-template-areas: '"i" "n" "s" "l"'
- grid-template-columns: 1fr
- grid-template-rows: 1fr min-content min-content
img_cell:
- justify-content: start
- align-items: start
state:
- value: 'on'
styles:
card:
- box-shadow: 0px 0px 3px 2px var
name:
- color: black
state:
- color: gray
label:
- color: black
- value: 'off'
styles:
card:
# - opacity: 0.3
label:
- color: black
icon:
- color: 'black'
name:
- color: black
state:
- color: 'black'
styles:
card:
- opacity: 0.2
- color: grey
- '--paper-item-icon-color': grey
label:
- color: 'rgba(0, 0, 0, 0.0)'
in lovelace:
- type: horizontal-stack
cards:
- type: custom:decluttering-card
template: Button2
variables:
- name: Bedroom Lights
- entity: light.bedroom_lights
- icon: mdi:ceiling-light
Thank you!
I really like your frontend about lights, as i am a beginner using the button card, will you help me sharing that code?
Please look at my post above yours, i shared the the template for the card.
Yes, i read it, i was meaning the whole lovelace yaml regarding all the lights…
EDIT: Ah, sorry, maybe i understand… when configuring a template, then you must only put in the lovelace.yaml the name of the entities… Is it correct?
yes, correct
No reply’s but i already figured it out myself.
Is it possible to template multiple lines?
Or more specifically, can I template this doubletap-action
I have a decluttering template that uses browser_mod
in the dbltap_action
which I would like to reuse for entities that do not have a dbltap_action
or use something completely different.
For example…
default:
- tap_action: none
- dbltap_action: none
card:
tap_action:
action: '[[tap_action]]'
dbltap_action:
action: call-service
service: browser_mod.command
service_data:
command: popup
title: >
[[[ return entity.attributes.friendly_name ]]]
card:
type: entities
entities:
- entity: >
[[[ return 'input_select.manually_set_' + entity.entity_id.split('.')[1]; ]]]
deviceID:
- this
Hi.
I am trying to get my lights to start from a brightness level from a input_number but I cant get it to work.
If I write 40, 60 , 200 after brightness it takes that value but not with this code
tap_action:
service: light.toggle
service_data:
entity_id: light.balcony_light
brightness: >
states['input_number.light_test'].state
Is it something with int or something? I have tried everything now
EDIT: of course 5 minutes after posting, I noticed the note in the docs that says it supports html formatting so the below works, so I’m answering my own question here for the question I ask below if anyone needs to know how to put a newline in their button label.
name: SWISS <br> CLASSIC
Original post below:
Hey, does anyone know how I can span the label for the button over 2 lines rather than just one? I have some small and simple text-only buttons for playlists but would like to span the name over 2 lines so that I can distinguish between them. For example, in the below I would like to have SWISS CLASSIC be shown as
SWISS
CLASSIC
Rather than SWISS CL… Because it gets truncated. Any idea how to do this?
- type: "custom:button-card"
styles:
card:
- padding: 12px 0px
- font-size: 14px
tap_action:
service: media_player.play_media
service_data:
entity_id: "media_player.itunes"
media_content_id: "radio-swiss-classic"
media_content_type: "playlist"
Yea, I tried that but unfortunately it’s still a no go. I event thought it wasn’t rendering because of templates but I set a view without them with no luck.
That won’t work. Light.toggle does not accept data.
It does for me just not this:
tap_action:
service_data:
brightness: >
But if I turn on the light and set the light to max in brightness and uses this instead:
tap_action:
service_data:
brightness: 20
the light turns off on first press and on second it turns on with 20 in brightness…
I turn it off, change the brightness to 100 and press the toggle it starts with 100.
So I guess it supports data I cant just get it to get the data from input_number.light_test
If that’s the case you need to terminate the line and add the word return before the states object. This of course is if that field even accepts templates
return states['input_number.light_test'].state;
Is there a way to minimize each header, i mean when i click on living room it wall maximize.
all the living room entities will fold under the living room header.
instead of scrolling.
I get the return that it needs an int for data…
I have tried
return (int)states['input_number.light_test'].state;
and also
int test = (int)states['input_number.light_test'].state;
return test;
But nothing change…
That’s not how it works in javascript.
return Number(states['input_number.light_test'].state);
Haha! You are a life saver as always!
Thx again man!
