you could at least take out the icon: ‘mdi:arrow-up’…
i did, doesn´t fix it.
I might not using decluttering-templates though, and trying to set it in the card config or template is uses for now.
maybe tell us what it does do?
isnt very meaningful yet
but I dont think you need the state:part for that, if you use the entity directly.
try to use the
icon: >
if (entity.attributes.current_position == 100) return "mdi:arrow-left"; return "mdi:arrow-right";
in the toplevel section of the button?
Yes me too. I’ll watch your conversation…
And copy what you discover ;-)
ye sure, sorry!
so if i remove it and use this code it just shows a standart cover icon.
type: 'custom:button-card'
entity: cover.balkon
state:
- operator: template
icon: >
tap_action:
action: call-service
haptic: success
service: cover.set_cover_position
service_data:
position: 100
updated my response above. It works…
that one worked. thanks alot!
This would be the way to keep a leading 0
var d = new Date(entity.last_changed);
return `${("0" + d.getHours()).slice(-2)}:${("0" + d.getMinutes()).slice(-2)}`
Action field should support templates.
action: >
[[[ if (['automation','light','switch'].includes(entity.entity_id.split('.')[0])) return 'call-service'; return 'more-info']]]
That’s the 3 templates I use to display the 3 buttons on top:
cover_up:
template: cover_button
icon: mdi:arrow-up-thick
tap_action:
service: cover.open_cover
service_data:
entity_id: entity
state:
value: >
[[[ return entity.attributes.current_position == 100 ]]]
styles:
icon:
- opacity: 0.3
cover_stop:
icon: mdi:stop
tap_action:
service: cover.stop_cover
service_data:
entity_id: entity
cover_down:
icon: mdi:arrow-down-thick
tap_action:
service: cover.close_cover
service_data:
entity_id: entity
state:
value: >
[[[ return entity.attributes.current_position == 0 ]]]
styles:
icon:
- opacity: 0.3
This should give you some inspiration.
cool! thanks a bunch again!
Just to be sure, we can’t use the ‘domain’ in the JS templates, like we can in jinja? entity.domain
I checked and I can’t see the domain
attribute in the object (not something I can change), so apparently not
and yes, this works:
now only need to show it was yesterday (or more) when time > current time… and then show ‘(number of day) days ago’
this is magic of another level can template quite a few template cards away now… so glad I asked
Hi, I asked in declutering template forum, but not answers there
im trying to migrate my cards from anchors and after a few changes,i have this problem with this one:
This my template:
tracker:
card:
type: custom:button-card
show_entity_picture: true
entity: '[[entity]]'
entity_picture: '[[entity-picture]]'
label: >
{{ return states['[[entity_id]]'].attributes.battery + '% de bateria' }}
tap_action:
action: more-info
color: auto
show_state: true
show_name: false
show_label: true
state:
- value: "not_home"
styles:
card:
- border: 5px outset red
- value: "home"
styles:
card:
- border: 5px outset green
styles:
name:
- padding: 0px 10px
- font-size: 13px
- font-family: Helvetica
- justify-self: start
- font-weight: bold
label:
- color: gray
- font-size: 10px
- padding: 0px 10px
- text-transform: capitalize
state:
- font-size: 11px
- padding: 0px 10px
- font-weight: bold
card:
- padding: 0px
I tried several options in label option but similar results
and the card:
- type: custom:decluttering-card
template: tracker
variables:
- entity: person.jorge
- entity-picture: /local/jorge.png
- label: >
Some help please and thanks
Templates are created with [[[ ]]]
not with {{ }}
in button-card:
tracker:
card:
label: >
[[[ return states['[[entity_id]]'].attributes.battery + '% de bateria' ]]]
tap_action:
action: more-info
color: auto
show_state: true
show_name: false
show_label: true
state:
- value: "not_home"
styles:
card:
- value: "home"
styles:
card:
styles:
name:
- padding: 0px 10px
- font-size: 13px
- font-weight: bold
label:
- color: gray
- font-size: 10px
- padding: 0px 10px
state:
- font-size: 11px
- padding: 0px 10px
- font-weight: bold
card:
- padding: 0px
I have two questions about this wonderfull card.
- Templates are saved in ui-lovelace.yaml beginning from position 0 or are indented beginning from position 3?
- Is there a way, using the tap_action, to call a specified card. I mean if i have a card using the mini-media-graph custom card, may i call that card when tapping over the button ?
Thanks.
thanks for answer,I had tried it that way too ,but when i do the card disappears
maybe is this not possible with decluttering templates?
regards and thaks again
Actually the error is that [[entity_id]]
doesn’t exist. Replace that bit with [[entity]]
since your variable is called entity
thanks,you are my hero,but my problem now is that the entity i use is a person type(person.jorge) but the battery atribute is from another entity (device_tracker)
Just provide another variable (name it how you want) with the value being your device_tracker and replace entity
in the label with the new variable name.
