Lovelace: Button card
Understandable, there’s a lot going on in this card
Just tried to download button.js and it says file not found from here:
Has it been removed?
The file is available in the releases part of the repository.
perfect found it!
Expect lots of questions coming soon, I really want to use this to operate my SkyQ component.
Initial gaps in my knowledge include how to use the button to call a service and can I call a service while having the entity of the button as the media player skyQ, or do I need to create entities for each service I want to call?
Will start having a play.
Love the look of your buttons!
Would you mind sharing the code for one of your light buttons (with slider).
Thanks!
I would be happy too, I’m at work now but I will post later when I’m at my computer.
New to this card and said I would have some questions. I was hoping to get my image to fill the card, its a bigish image so looks like it is being resized / squished within the image cell or grid but I cannot work out how to amend my code to fill out the button.
      - type: custom:button-card
        show_entity_picture: true
        entity: media_player.skyq
        entity_picture: /local/images/remote/bbc_one.png
        #show_state: true
        styles:
          card:
            - width: 100px
            - height: 100px
          grid:
         #   - grid-template-areas: '"i" "n" "s"'
            - grid-template-columns: 99px
            - grid-template-rows: 99px
          img_cell:
            - align-self: start
            - text-align: start
        show_name: false
        #size: 100px
        #aspect_ratio: 2/1
        #tap_action:
        color: auto
        #size: 90%
        action: call-service
        service: media_player.select_source
tried commenting out the img cell bits but no difference
button is currently looking like this,
I am hoping to keep the same size button, but have the image fill the grid at least horizontally.
button_card_templates:
  homekit_dimmer:
    deep_press: true
    color_type: icon_label
    tap_action:
      action: toggle
      haptic: heavy
    hold_action:
      action: more-info
    color: auto
    color_type: card
    show_last_changed: true
    show_label: true
    show_icon: true
    aspect_ratio: 1/1.25
    styles:
      grid:
        - grid-template-areas: '"i" "n" "s" "l" "slider"'
        - grid-template-columns: 1fr
        - grid-template-rows: 1fr min-content min-content min-content
      img_cell:
        - justify-content: start
        - align-items: start
      name:
        - justify-self: start
        - padding-left: 12px
        - font-weight: bold
        - text-transform: Titlecase
        - font-size: 13px
      label:
        - font-size: 13px
        - padding: 0px 10px
      icon:
        - height: 70%
        - background-color: rgb(0,0,0)
    state:
      - value: 'on'
        styles:
          card:
            - background-color: black
            - box-shadow: 0px 0px 12px 2px var(--button-card-light-color)
            - color: 255,255,255
          icon:
            - color: var(--button-card-light-color)
          label:
            - color: rgb(255,255,255)
      - value: 'off'
        styles:
          card:
            - box-shadow: 0px 0px 12px 2px rgb(255,9,9)
          icon:
            - color: red
          label:
      - value: 'unavailable'
        styles:
          card:
            - color: rgb(0,0,0)
          icon:
            - color: rgb(0,0,0)
          label:
            - color: rgb(0,0,0)
          state:
            - color: rgb(0,0,0)
      - type: horizontal-stack
        cards:
            template: homekit_dimmer
            tap_action:
              action: toggle
            icon: 'mdi:lamp'
            entity: light.corey
            custom_fields:
                slider:
                  card:
                    type: custom:slider-entity-row
                    full_row: true
                    hide_state: true
                    hide_when_off: true
                    entity: light.corey
The top one is my template and the bottom one is in my lovelace views.
@RomRider Im sure the code isn’t perfect but it works :slight_smile:
I’m not sure if its possible to template the custom_field or not since it changes depending on the entity_id
I hope this helps you @mcfrojd
Sorry, this is driving me mad. How can I fill the button with the image I have? Is it possible?
You can see here a working config for what you want to achieve:
That’s not implemented no… I’d use decluttering-card for now to achieve that.
Could you please open a feature request (template support for embedded cards config) so that I can have a look?
Done, I hope I did it right. My first feature request :slight_smile:
Thanks again for everything you do!
Is it possible to set the opacity of an image used in this card?
Is it possible to display the media icon when showing a media player? e.g.
“Living room Display” is currently on and running an internet Stream. When I show the speakers as an entity list, I see their icon:
Here’s the YAML used:
    cards:
      - entity: media_player.living_room_display
        type: 'custom:button-card'
EDIT: Found it, show_entity_picture: true! … It’s not documented anywhere. :confused:
Yes, by using this in the styles of (probably) entity_picture for you:
styles:
  entity_picture:
    - opacity: 0.5
Did you try show_entity_picture: true?
Found it, just before you posted. Thanks!
It’s not documented anywhere on the README. I did a search (after finding it) and only 1 occurrence, a little obscure.
Well, 1 occurence means it is documented as far as I understand how numbers work… Feel free to open a PR with enhancement to the documentation if you think it’s not enough.
Hi All,
What a great plugin, i love it! I’m new and need some help with the template part of the button card.
Probably i’m totally missing something here :wink:
I created a nice button that works like a charm.
      - aspect_ratio: 1/1
        color: auto
        entity: light.living_room_hektar
        hold_action:
          action: more-info
        label: >
          [[[ var bri = Math.round(entity.attributes.brightness / 2.55);  if
          (entity.state === 'on') return (bri ? (bri+"%") : '') ]]]
        layout: icon_label
        show_label: true
        show_state: true
        styles:
          grid:
            - grid-template-areas: '"l s" "i i" "n n"'
            - grid-template-rows: 1fr 3fr 1fr
            - grid-template-columns: 1fr 1fr
          label:
            - padding-left: 10%
            - font-size: 80%
          name:
            - font-size: 80%
          state:
            - justify-self: end
            - padding-right: 10%
            - font-size: 80%
Capture
I need to copy this button multiple time so i’d like to use template. To start off I added the following to my configuration.yaml and try to reboot.
  light_button:
    styles:
      name:
        - font-size: 80%
But i’m getting following error:
Component error: button_card_templates - Integration ‘button_card_templates’ not found.
What am i missing, wrong place to put your button_card_templates or missing module? help! :upside_down_face:
I use HASS.io and installed the button card module with HACS
Greetz Niels
The button_card_template code needs to go in your Lovelace file, not config.yaml
I just put it right at the end of my Lovelace code so it’s out of the way
Hi Dave,
Ah, right i need to add this to the raw config editor in Hass.io.
I think there is no ui-lovelance.yaml in Hass.io.
Anyway this is working.
Thanks!
