Lovelace: Button card
Yeah, sorry. I should have said to add to the raw Lovelace
Still loving this button and playing around with it. I have created a logo in photoshop which is the tv station, rounded on one side and gradient filled to nothing on the other. Its half the width of a standard full width card.
I was hoping to have this on the left and the channel name on the right but for some reason the button is taller than the image I have created?
I thought it was because i was using layout: icon_name_state to put the channel name on the far right, but even setting show_label: false it does not resize the height of the button.
Any ideas? Its the BBC One card in the image below, you can see its rounded which is the image I supplied but the button is has space above and below the image
Share your config please, we canā€™t do anything without it.
Sorry, couldnā€™t copy and paste the code from my phone. Here it is. There are quite a few bits commented out from having a play trying to fix it so apologies for that:
      - type: custom:button-card
        entity: switch.skyq_bbconelounge
        show_entity_picture: true
        show_name: true
        show_icon: false
        show_label: false
        style:
          - padding: 0px
        styles:
          card:
        #  - width: 100px  #100% #99px
        #      - height: 100px
          entity_picture:
            - width: 100%
            - height: 100%
         # name:
         #   - justify-self: start
         #   - padding-left: 10px
         #   - font-weight: bold
         #   - text-transform: lowercase
        entity_picture: "/local/images/remote/bbconefaded2.png"
        #action: on  #skyq_bbconelounge
would love to to try this requested feature on the new Lock option.
testing this in my lock template :
button_body_lock:
  lock:
    enabled: true
    unlock: hold
  confirmation:
    text: >
      [[[ return 'Are you sure you want to toggle ${entity.attributes.friendly_name}? If not, do nothing.' ]]]
which changes the lock action to Hold, as requested, and make tap do nothing. so far so good. Holding the button makes the lock open and grey out, but then clicking it again(to get the confirmation) does this:
20
Is this an incorrect configuration?
please have a look?
edit
wait, I used regular quotes, and not backtick quotes. sorry, doing whatā€™s desired now:
28
Guess thereā€™s always a ā€˜cancelā€™ (Annuleer) there? So need to change my confirmation text :slight_smile:
btw do we have options to sale the confirmation box? it now seems so out of context.
thanks
Iā€™m trying to use the state option to change the colour of an input_boolean according to the state (on or off) but it doesnā€™t seems to be working. I have the following:
  - cards:
      - type: entity-button
        entity: input_boolean.temp_alarm
        icon: 'mdi:garage-open'
        state:
          - value: 'off'
            color: red
          - value: 'on'
            color: green
Iā€™ve tried changing the colourā€™s, changing the mdi icon but nothing seems to be making a differance. Fairly sure Iā€™m missing something fundamental, any help would be appreciated!
youā€™;re missing the ā€˜stylesā€™ key.
have a look here:
button_default_state:
  state:
    - value: 'on'
      styles:
        card:
          - color: '#555B65'  #'#5daf35'
          - background-color: '#F0C209'
        icon:
          - color: '#555B65'
        label:
          - color: red
    - value: 'off'
      styles:
        card:
          - color: '#F0C209'
          - background-color: '#555B65'
        icon:
          - color: '#F0C209'
        label:
          - color: rgba(0, 0, 0, 0.0)
    - value: 'unavailable'
      styles:
        card:
          - opacity: 0.6
          - color: grey
          - --paper-item-icon-color: grey
Youā€™re using the core entity-button.
This is about the. type: custom:button-card
Being stupid but why does this code not give me a button that takes me to a different lovelace screen?
      cards:
        action: navigate
        navigation_path: /lovelace/5/
oops, yes, that too :wink:
ARGH!!!
Thanks, working as expected now!
sorry, worked it out!
    - type: vertical-stack
      cards:
        tap_action:
          action: navigate
Still cannot work out how to solve my display issue above though
a question on the new exemption option:
is it per design the lock flashes quickly on an exemption name which is incorrect? Ive used it with a name listed with lowercase first letter instead of lower case, and it starts flashing quickly (instead of disappearing) and the next tap doesnā€™t do anything.
Using an uppercase username makes the lock disappear alright, but the next tap still gives me the conformation dialogā€¦
this might be a feature request, but Iā€™ll post it anyway, maybe it is already possible:
Id like the confirmation to show up only on the admin account, and not at all for all other accounts, and stay silent (donā€™t toggle at all). Iow, only the admin account would be allowed to unlock (albeit with a conformation).
As I understand the exemption now, the list of users would not see the confirmation, and unlock directly?
thanks for having a look
Iā€™ll have a look soon, it should be pretty easy.
But something like this should work:
styles:
  card:
    - padding: 0px
Yes it is by design, the lock flashes if youā€™re in not in the exemption list.
With this config:
  • Only admin can unlock the button
  • Only admin will have the confirmation since heā€™s the only one who can unlock
lock:
  enabled: true
  exemptions:
    - username: admin
confirmation:
  text: Your text
cool! thanks a bunch. great design!
just tested and we can do this too, which is very nice indeed:
    exemptions:
      - username: !secret button_unlock_name
secondly, please let me ask this: Iā€™ve set the unlock name now in a button_template. But I can see use for having different lists of exemptions on different buttons.
Could we set the exemption on an individual button, while all the other lock settings are defined in the template? Would these settings merge?
Problem: the link to install button-card is 404
Use HACS or the release
Thanks.
I have stripped all the surplus code out and have this picture now:
from this code:
        styles:
          card:
            - padding: 0px
          entity_picture:
removing the state etc gets me this:
with this code:
        show_name: false
        show_icon: false
        show_label: false
        show_state: false
        styles:
          card:
            - padding: 0px
So I am nearly there, then I found your justify guides for the img cell:
        styles:
          card:
            - padding: 0px
          img_cell:
            - justify-content: start
So now have this:
I am hoping to put the card name on the far right now in the middle, will have a play and see how I get on.
Thank you for this card!
Can someone help me with dynamic color for light brightness? I want the color to change as the brightness changes.
   -  type: 'custom:button-card'
      entity: light.bedroom
          var bri = states['light.bedroom'].attributes.brightness;
          return 'rgb(248, 222, ' + (bri ? bri : 0) + ')';
      label: |
          return 'Brightness: ' + (bri ? Math.round(bri/255*100) : '0') + '%';
      show_label: true
      icon: 'mdi:ceiling-light'
      color: >
        ${states['light.living_room'].attributes.brightness < 50 ? 'rgb(255, 255, 0)' : 'rgb(255, 255, 125)'}
      state:
        - value: 'off'
          color: 'rgb(0, 0, 0)'
It outputs the correct rgb for the name and the label works fine.
Is it possible to show a toggle on the button? Like an entity toggle header?
