Thanks yeah that worked, I didn’t realise uppercase mattered on a state like that.
Cheers
HI Rom,
Writing to you because I am really completely puzzled what happened with my Marquee… It filled out the full width of the button before, no matter how many alerts were going on, but lately leaves a big empty space left and right of the text (on 1 alert)
using:
type: custom:button-card
template: button_default_title
styles:
card:
- padding: 5px
[[[ var phrase = states['sensor.count_alerts_notifying'].state == 1
? 'Alert:' : 'Alerts:';
return `<div style='display: inline-flex;'>
<div>${states['sensor.count_alerts_notifying'].state} ${phrase} </div>
<marquee>
<span style='align-items: center;font-weight:normal;font-size:18px;'>
System alerts: ${states['sensor.marquee_alerts'].state} </span>
</marquee>`; ]]]
and template:
button_default_title:
aspect_ratio: 12/1
styles:
card:
- background-color: var(--background-color-off)
- color: var(--text-color-off)
- font-size: 20px
- font-weight: bold
the card isnt filled out completely to the left and right anymore, but centered, and I cant find the way back:
how could I do that, please have a look?
the number should be fully to the left (with padding 5px), and the Marquee should simply float in from the right (again, padding 5px)
when 2 alerts are live the button shows like I want it:
I just stumbled across this and I guess it’s implied by this Q&A. I thought I’d state it explicitly though. I accidentally put the confirmation
section under the button config instead of inside one of the action sections. This was fine until I added a second action and then tried to figure out why all actions now has the confirmation dialogue. So, the docs says you should put it under an action but it actually works in the main config too. It’s thus either an undocumented feature or completely unintentional.
Hi all
I started using this card yesterday and so far love it, thanks for this.
I have an issue with my buttons :
How can i change the color of the shadow to yellow ?
This is my code :
state:
- value: 'on'
styles:
card:
- box-shadow: 2px 2px 2px 1px var(--paper-item-icon-active-color)
icon:
- color: 'rgb(255, 255, 0)'
It is documented in both the main config section and in the action section of the README Main is general, in the action one it’s specific to that action. I agree, I could have explicitly said that in the doc
Instead of using var(--paper-item-icon-active-color)
use var(--button-card-light-color)
which returns the actual color of the light, or if you want just yellow all the time, box-shadow: 2px 2px 2px 1px rgb(255, 255, 0)
Shucks, you’re right. Thanks for the feedback.
Thank you so much, worked just fine.
Hi Rom,
creating a very simple card (…). Hoping to.
template: button_picture_script_small
entity: sensor.espresso
tap_action:
action: toggle
entity: switch.espresso_keuken
hold_action:
action: navigate
navigation_path: /ui-settings/settings
I only now discover we can not override the entity in a tap: toggle action, but only on a hold action? Since I use hold_action system wide for navigating around, I really need the override on the tap action… Would you consider adding that possibility please?
Now only allowed for more-info (which was my request too https://github.com/custom-cards/button-card/blob/master/README.md#action
Is there any intention to support the new “action: fire-dom-event” of the browser-mod integration?
Yes, it’s on its way, but I need a PR to be merged first.
tap_action: action: toggle entity: switch.espresso_keuken
What about:
tap_action:
action: call-service
service: '[[[ return states["switch.espresso_keuken"].state === "off"? "switch.turn_on" : "switch.turn_off" ]]]'
service_data:
entity_id: switch.espresso_keuken
Yah, thanks,
I did consider that, (and it works alright) but found the overriding entity option way more elegant
Wouldn’t you accept a feature request for that?
I have an issue, not sure if it’s frontend, but I have a lot of buttons, a hold press shows the “more info” dialog… When I close it, my frontend hangs for 3 sec… This was not happening a few core releases ago… Someone seeing this too?
Had the same issue (used to hang for like 8 to 10 sec every time), never could find out what was happening. Was having A LOT of stuff in one page and it generated that behavior.
In the end I was tired and just rebuilt the whole thing differently
For me it was only happening on my phone (OnePlus 7T Pro), not on an android 10 tablet, not on any ios device, not on MacOS/Windows/Linux
Yeah, i have it too on oneplus 6t… less on desktop chrome… There is an issue, not sure where it’s related…
Started noticing it a few weeks ago, what’s not happening before, and I didn’t change anything in Lovelace
If you look online, you’ll see there are several reports where webview is slow on oneplus devices and it has never been fixed
yeah, but it was always smooth as hell, untill some core releases ago
Been there… Good luck I spent hours trying to figure it out… If you find something let me know!
Everything is running smooth here, it’s only after I close the more dialog
Is there an issue reported somewhere on github about oneplus issue? Indeed om my Samsung tablet it’s better
