Lovelace: Button card
Yeah, I had exactly that and only on my oneplus phone :man_shrugging:
As far as I know, itā€™s not related to home-assistant, itā€™s related to some issues with webview and oneplus phones. Just Google for ā€œoneplus webview slowā€ youā€™ll see a lot of of them. But with home assistant it manifests itself after closing a popup :upside_down_face: with other apps sometimes for me it just freezes
Edit: I hzd sometimes better results with webview beta. If you go this route, youā€™ll have to enable the developer settings and explicitly assign webview beta as your webview provider
I noticed indeed a new webview update some days ago , i think issue started occuring that periodā€¦ Gonna try and earlier version with apk mirrorā€¦ Cause I never had issue before
Hmm, tried going back to 87.0, rls 30/12 ā€¦
Same issue :frowning:
Sorry to ask about something where I assume itā€™s a obvious answer I just canā€™t find.
I have a lot of cards where I would like to reference the name in other fields in order to template the cards. In the following example I would like to use content of ā€œnameā€ in input_select option and in the state template. I assume I can somehow reference content of the fieldā€¦?
          - type: 'custom:button-card'
            entity: input_select.tidspunkt_dag
            show_icon: false
            color_type: card
            tap_action:
              action: call-service
              service: input_select.select_option
              service_data:
                entity_id: input_select.tidspunkt_dag
                option: Morgen
            styles:
              card:
                - font-size: 12px
            state:
              - operator: template
                value: >
                  [[[ return states['input_select.tidspunkt_dag'].state ===
                  'Morgen' ]]]
                color: var(--accent)
Use a variable :wink:
@RomRider
Is it possible to pass a variable to the spin state? I cant get it to work.
Something like
state:
  - value: 'on'
    spin: '[[[ return variables.option ]]]'
No that is not possible but spin is the same as setting the CSS animation and you can use templates there :wink: :
styles:
  icon:
    - animation: rotating 2s linear infinite
Sorry for the spam for people who received some emails from github-action it went crazy, Iā€™ve changed the release system :smiley:
However, good news, the latest version implements support for fire-dom-event :slight_smile:
Iā€™m having a strange issue when trying to update:
Logger: custom_components.hacs
Source: custom_components/hacs/api/hacs_repository_data.py:117
Integration: HACS (documentation, issues)
First occurred: 21:01:35 (5 occurrences)
Last logged: 21:03:35
No content to download
First time Iā€™ve seen this :stuck_out_tongue:
Try again, Iā€™ve just fixed it :slight_smile: (Iā€™ve updated the release bot and I f***ed up sorry :pray:)
Done :smiley:
Updated correctly and poppups are working again and very fast :smiley:
Thank you so much!
Amazing! Before I update, can you confirm that the new fire-dom-event action works on both tap_action AND hold_action?
Just to prevent unnecessary work and troubleshooting.
It works on any action
Iā€™m trying to change the icon based on the state of the binary sensor. I have custom:button-card set up for the PiHole to check if the device is online. I have set up the ping binary sensor. What I want to achive is to change the ICON in the button card from mdi:pi-hole to mdi:alert-outline as soon as there is no connectivity. Following is the code for the button, however the ĆÆcon"change doesnt work. Can someone help?
- aspect_ratio: 2/1
                  template: black_larger_template
                  custom_fields:
                    blc: |
                        return `<span>Blocked: <span style="color: var(--text-color-sensor);">${states['sensor.pi_hole_ads_blocked_today'].state}</span></span>`
                    blc2d: |
                        return `<span><span style="color: var(--text-color-sensor);">${states['sensor.pi_hole_ads_percentage_blocked_today'].state}%</span></span>`
                    qur: |
                        return `<span>Queries: <span style="color: var(--text-color-sensor);">${states['sensor.pi_hole_dns_queries_today'].state}</span></span>`
                  entity: sensor.pi_hole_ads_percentage_blocked_today
                  icon: >
                      if (entities['binary_sensor.pihole_ping'].state === 'on') return 'mdi:pi-hole';
                      return 'mdi:alert-outline';
                  styles:
                    grid:
                      - grid-template-areas: '". n" "i blc2d" "i qur" "i blc"'
                      - grid-template-columns: 1fr 1fr
                      - grid-template-rows: 1fr min-content min-content min-content
                    icon:
                      - color: yellow
                    custom_fields:
                      blc:
                        - padding-bottom: 0px
                        - padding-top: 0px
                        - align-self: middle
                        - font-size: 15px
                        - justify-self: end
                        - color: white
                      blc2d:
                        - padding-top: 0px
                        - font-size: 15px
                        - justify-self: end
                        - color: white
                        - '--text-color-sensor': >-
                            [[[ if
                            (states["sensor.pi_hole_ads_percentage_blocked_today"].state <
                            10) return "red";  if
                            30) return "orange"; else return 'white'; ]]]
                      qur:
                        - padding-top: 0px
                        - padding-left: 10px
                        - justify-self: end
                        - font-size: 15px
ā€¦ok I got it. Chage the entities to states (in icon):
 icon: >
      if (states["binary_sensor.pihole_ping"].state === 'on') return 'mdi:pi-hole';
Hey,
So I have updated to the latest version, and still not able to use the ā€œaction: fire-dom-eventā€ of the browser-mod as part of the button card tap_action.
I have decluttering template where tap_action is one of the variables, which is working fine, however it refuses to work with action: fire-dom-event.
Anything I am missing?
Is this working for anyone with button card at all? Even without decluttering?
Clear your cache and/or make sure you are really running the latest version by looking at your javascript console.
Hey,
Yes sure I did that, and running the latest.
@sergio_pt @ASNNetworks, it seems there are reports of custom:button-card not working with browser_mod popups with the new fire-dom-event using the 3.4.2 version of button-card.
Would you mind confirming it works for you and if so could you please share with the community a working config? :slight_smile:
Thanks for your help! :pray:
Hi @RomRider,
Sure, I can confirm itā€™s working.
Please find below a snippet of my working code in my ā€˜custom:button-cardā€™:
              tap_action:
                #service: browser_mod.popup
                browser_mod:
                  command: call-service
                  service_data:
                    title: Heater
                    deviceID:
                      - this
                    large: false
                    hide_header: false
                    auto_close: false
                    card:
                      type: entities
                      title: Mi Heater
                      show_header_toggle: false
                      entities:
                        - type: 'custom:simple-thermostat'
