Lovelace: Button card
I believe what you want to do is the opposite no?
  navigation_path: >
    [[[ return (window.location.pathname.split('/')[2] == 'alarm')
        ? '/ui-settings/alarm' : null; ]]]
No, what I need is that when the button is displayed on ā€˜alarmā€™ (full path ā€œ/ui-settings/alarmā€)
Schermafbeelding 2021-02-24 om 15.09.47
Schermafbeelding 2021-02-24 om 15.08.16
it remains there, if not, it should navigate thereā€¦
reversing the logic to:
hold-action:
  action: navigate
  navigation_path: >
    [[[ return (window.location.pathname.split('/')[2] == 'home')
because it either is on Home or on Alarm in the settings dashboard doesnt help.
I now see this in Chrome inspector upon holding:
does that make sense at all?
I have a full set of shortcut menu buttons using:
    tap_action:
      action: navigate
      navigation_path: >
        [[[ return (window.location.pathname.split('/')[2] == 'weer_klimaat')
            ? '/ui-settings/home_climate_settings' : '/lovelace/weer_klimaat'; ]]]
working as expected. Not sure why this would be different. Ive disabled the button template to be sure, but that still makes no difference.
Right, Iā€™ve just seen the issueā€¦ hold-action should be hold_action :slight_smile:
rightā€¦ duh. so sorryā€¦!Ā±
working right nowā€¦
Hi!
Iā€™m having a weird issue here. I was creating a new button card, when (to me) all of a sudden the ā€œstylesā€ variables had no effect anymore. Actually they take effect, when I toggle the button. But after refreshing the site, the settings again show no effect. And this goes for all my lovelace pages, in every browser, with every user and in the app.
Iā€™m talking about these settings:
styles:
  card:
    - border-radius: 15px
    - font-size: 14px
    - background-color: '#262626'
  state:
      - value: 'on'
        styles:
          card:
            - background-color: '#4d4d4d'
It looks like this:
My compelte UI is affected by this. Can someone help here? This would be really appreciated!
Please share the full config, not just a part of it.
Also state is not supposed to be under styles but at the same level than styles.
Sorry, this was a copy-paste mistake. ā€œstateā€ is indeed an the level of styles.
Should I post the complete lovelace config?
The weirdest thing is, I just used a backup of my complete HA instance from yesterday, when the issue wasnā€™t there, but it didnā€™t disapear.
Here is my config of a single button:
type: 'custom:button-card'
entity: light.buro_decke
tap_action:
  action: toggle
hold_action:
  action: fire-dom-event
  browser_mod:
    command: popup
    title: Helligkeit & Szenen
    style:
        .mdc-dialog__scrim {
          backdrop-filter: blur(20px) brightness(70%);
          -webkit-backdrop-filter: blur(20px) brightness(70%);
    card:
      type: entities
      entities:
        - type: 'custom:light-popup-card'
          icon: []
          fullscreen: false
          brightnessWidth: 130px
          brightnessHeight: 360px
          borderRadius: 20px
          sliderColor: '#c7c7c7'
          sliderTrackColor: '#1a1a1a'
          actionSize: 70px
          actionsInARow: 3
          actions:
            - service: scene.turn_on
              service_data:
                entity_id: scene.buro_decke_konzentrieren
              color: '#e6ffff'
              service_data:
                entity_id: scene.buro_decke_hell
              color: '#ffeecc'
              service_data:
                entity_id: scene.buro_decke_relax
              color: '#ffb31a'
      title: []
double_tap_action:
  browser_mod:
    command: popup
    title: Farbe / Temperatur
    style:
    card:
      type: 'custom:light-entity-card'
      shorten_cards: false
      consolidate_entities: true
      color_wheel: true
      persist_features: true
      brightness: true
      color_temp: true
      white_value: true
      color_picker: true
      smooth_color_wheel: true
      hide_header: true
      child_card: false
      show_slider_percent: true
      full_width_sliders: true
      effects_list: false
icon: 'mdi:ceiling-light'
color: auto
show_state: false
aspect_ratio: 1/1
styles:
  card:
    - border-radius: 15%
    - width: null
    - height: null
    - padding-bottom: 12px
    - margin-left: null
    - font-size: 15px
state:
  - value: 'on'
    styles:
      card:
But the problem occurs at every button. Thanks in advance!
Not the complete lovelace config, the config of one of your button which doesnā€™t work and the button-card templates used, if any.
Remove that, those are not valid values.
Okay I removed the ā€œnullā€ entries but it didnā€™t help. They also have been there before, when it still looked the way it should.
It seems that the behavior doesnā€™t affect only button-card, so thereā€™s nothing I can do for you regarding button-card.
Maybe your theme is bugged, or one of the parent card of the buttons is (layout-card, vertical-stack-in-card, stack-in-card, etcā€¦)
yeah I made a simple as possible card:
aspect_ratio: 1/1
styles:
  card:
and the problem stll is present.
It seems, that it came all of a sudden. Strangeā€¦
Iā€™m using the standard theme.
But thank you anyways. :slight_smile:
You seem to have a lovelace addon interfering with all the cards (I can tell by how the background glitches initially), look there first (disable them one by one and see which one is the culprit)
You where right! I deleted the last one Iā€™ve installed, which was:
now everything works again. Thanks for your expertise! It would have been hard for me to figure that out, since it didnā€™t stop working immediately.
is there a way to change the color of the card and the icon to 2 different colors with a state change?
There are several examples in the documentation over on github, maybe you should try that first :slight_smile: But the answer is yes it is possible.
  color_type: card
  state:
    - value: YOUR_STATE
      color: YOUR_BACKGROUND_COLOR
      styles:
        icon:
          - color: YOUR_ICON_COLOR
Any chance you could share more then just that one card, I"d like to shameless steal a ton of that because its simply awesome
Is there a option to get the correct brightness instead above 100%? Iā€™m using the code below but it have a brightness between 0/255 so it shows like 144% etc, would like to have it between 0/100. :slight_smile:
label: |
    var bri = states['light.tvlamp'].attributes.brightness;
    return 'Helderheid: ' + (bri ? bri : '0') + '%';
You divide it by 2.55 :slight_smile:
label: |
    return 'Helderheid: ' + (bri ? Math.round(bri / 2.55) : '0') + '%';
OC
what/which card do you want to see?
