Lovelace: Button card
Did you ever figure this out? Looking for the same functionality.
@paddy0174
I have done a lot of tests, but I just canā€™t align the icons as I would like.
For example here I would like to align the 3 icons to the right centering them with the left icon which is larger.
I have tried with various methods that I know but I have not been able to obtain the desired result.
I would like to have it like that:
type: custom:stack-in-card
mode: vertical
cards:
  - type: custom:stack-in-card
    mode: horizontal
    style: |
      ha-card {
      box-shadow: none;
    cards:
      - type: custom:button-card
        styles:
          card:
            - font-size: 10px
          icon:
            - width: 50px
          name:
            - font-weight: normal
            - font-size: 20px
        entity: sensor.stato_riscaldamento
        color: rgb(128, 128, 128)
        state:
          - value: IN FUNZIONE
            color: rgb(255, 0, 0)
        show_state: true
        show_name: true
        show_label: true
        styles:
          card:
            - font-size: 9px
          icon:
            - width: 40px
          name:
            - font-size: 13px
        entity: switch.riscaldamento_00_off
        icon: hass:power
        styles:
          card:
            - font-size: 9px
          icon:
            - width: 40px
          name:
            - font-size: 13px
        entity: switch.riscaldamento_20_on
        icon: hass:fire
        styles:
          card:
            - font-size: 9px
          icon:
            - width: 40px
          name:
            - font-size: 13px
        icon: hass:fire
  - type: entities
    entities:
      - entity: automation.riscaldamento_programmato
        name: Riscaldamento Automatizzato
        icon: hass:calendar-clock
        style: |
          :host {
            --paper-item-icon-color:
          rgb(255, 128, 0);
    state_color: false
Iā€™ve been trying to use a global variable but still getting a ButtonCardJSTemplateError: TypeError: Cannot read properties of undefined (reading ā€˜stateā€™) error message. Any hints what Iā€™m missing here?
entity: sensor.wallbox_power
triggers_update:
  - binary_sensor.Wallbox_charging
state_display: |
    var sensor_state = (states['binary_sensor.Wallbox_charging'].state);
    if (sensor_state == "off")
      return "----";
    else
      return "0000"
Equal comparisons in javascript require 3 equal signs. I think you should also end the last return line with a semi-colon too.
See if this works:
    if (sensor_state === "off")
      return "----";
    else
      return "0000";
Iā€™m trying to concatenate a variable to create a dictionary and Iā€™m wondering if anyone has gotten something to work.
Basically, I need to have the same value (ie: 255,255,0) reflected in two formats
  • rgb(255,255,0)
  • [255,255,0]
So Iā€™m trying to do something like
template:
  variables:
    color: ā€œā€
  styles:
    card:
      - background: >
          [[[ return ā€œrgb(ā€œ + variables.color + ā€œ)ā€ ]]]
    tap_action:
      action: call-service
      service: light.turn_on
      service_data:
        rgb_color: >
            return '[' + variables.color + ']';
  template: template
  variables:
    color: 255,255,0
However, the concatenation doesnā€™t work no matter how I try it / quote it / back tick template it.
Anyone have any thoughts on a good way to accomplish this?
edit: OMG, Iā€™m an idiot.
I have no idea why I was trying to concatenate instead of just return variables.color.split(ā€˜,ā€™).
@sahni make the W lowercase. Entities are always lowercase.
@reste_narquois you can use ===, but it isnā€™t necessary. Itā€™s a strong coercive check ā€” so it also checks types. @sahniā€™s error is with the state. The state is null, and you canā€™t get the attribute of null (which is what the error says).
Thanks Pieter, that solved the problem. I didnā€™t know that entities have to be always lowercase
Iā€™m sorry, still busy with the minimalist-ā€œthemeā€, so not a lot of time to answer. Sorry, really! :slight_smile:
A few things upfront. I changed from custom:stack-in-card back to the native HA cards, vertical-stack and horizontal-stack. I had a few problems with the custom-card, so Iā€™d say change back and see if things get better.
If you work with resizable/responsive layouts (thatā€™s what lovelace is), Iā€™d advise against using fixed width or height statements (no px, use % or em). If you imagine how a browser is working with this configuration, it canā€™t get aligned correctly. Imagine you have a div that spans the whole width (100%), assuming in relaity thatā€™s 1000px. Now we put a simple 1px dot in the middle. Would be 500px from the left. Now change the view from 1000px to 999px. Where should your dot sit now? In theory on 499.5px, but half pixels?! So it ends up on 499px and your layout is off by 1px, and you canā€™t catch that. If you use % or em you will make your life easier. :slight_smile:
Leave out the aspect_ratio. It mostly complicates the designs, as it changes things in the background. It is better to configure such things by yourself. If you need a bigger button, thereā€™s always a 125% setting available, eg. for width, height and so on. I never use aspect_ratio, it twice shot my layout and I had to start new.
Iā€™d start your configuration differently:
Take a vertical-stack and put in one (!) button-card, and your switch. In the button-card setup a grid-template with four custom-fields where you put in the ā€œrealā€ four buttons (button-cards). That should give you a more even layout an it is better configurable. :slight_smile:
Oh, and before I forget: Leave all the unimportant stuff out for the first steps. What you want is the icon aligned, the text comes afterwards.
I creatred a button-card in another button-card. Iā€™m a complete newbie in html and css. Can anybody explain, how to remove the white boxes around the small icons?button
And hereā€™s the code:
entity: binary_sensor.terrassentur
show_state: true
show_name: true
show_label: true
aspect_ratio: 1/1
state:
  - value: 'off'
    icon: mdi:door
    styles:
      card:
        - background-color: gainsboro
      icon:
        - color: lightslategray
      state:
  - value: 'on'
    icon: hue:room-other
    styles:
      icon:
        - color: red
  - styles:
      card:
        - background-color: red
      icon:
        - color: white
    value: unavailable
styles:
  icon:
    - top: '-25%'
    - left: 5%
    - position: absolute
  card:
    - border-radius: 5px
  name:
    - font-size: 12px
    - font-weight: bold
    - top: 60%
    - left: 8.1%
  label:
    - align-self: end
    - padding: 7px
    - font-size: 11px
    - font-weight: bold
    - font-family: Helvetica
  state:
    - font-size: 12px
    - top: 77%
    - left: 8.1%
  custom_fields:
    lueften:
      - top: 5%
      - left: 63%
    batterie:
      - top: 30%
      - left: 63%
tap_action:
  action: more-info
hold_action:
  action: more-info
custom_fields:
  batterie:
    card:
      entity: sensor.wz_terrasentuer_battery
      icon: mdi:check
      show_icon: true
      show_state: false
      show_name: false
      show_label: false
      color_type: icon
      state:
        - value: ok
          icon: mdi:battery
          styles:
            icon:
              - color: green
        - value: low
          icon: mdi:battery-10
          styles:
            icon:
              - color: red
        - styles:
            card:
            icon:
              - color: white
          value: unavailable
      styles:
        card:
          - width: 25px
          - height: 25px
          - box-shadow: 0 0 0 0
  lueften:
    card:
      entity: binary_sensor.lueften_wohnzimmer
      icon: mdi:check
      show_icon: true
      show_state: false
      show_name: false
      show_label: false
      color_type: icon
      state:
        - value: 'off'
          icon: mdi:close
          styles:
            icon:
              - color: green
        - value: 'on'
          icon: mdi:alpha-l-box
          styles:
            icon:
              - color: green
        - styles:
            card:
            icon:
              - color: white
          value: unavailable
      styles:
        card:
          - width: 25px
          - height: 25px
Hey guys,
Is there a way to wrap these buttons to a new line within the same ā€œcardā€ space? instead of them being all squashed up like this?
Im using Samā€™s code that Ive kinda bastardised
This is my code;
Iā€™m sure Iā€™m just missing something, but I donā€™t know what
Thanks!
EDIT: Just FYI, the top two lines are two different cards. They look a bit weird, id love to be able to get them to wrap to two lines within one card as well.
Also as Iā€™m sure you can tell by my terminology, I know nothing about CSS etc. I can seem to work things out most of the time though if Iā€™m pointed in the right direction LOL
EDIT
LOL
TYPE: Grid
Now I just need to work out the spacing
Ok,
Im stumped with the spacing here?
this is one of the buttons, if anyone has any ideas, would be awesome :slight_smile:
type: grid
cards:
    color: transparent
    entity: input_select.room_lights
    show_name: true
    aspect_ratio: 2/1
    color_type: label-card
    icon: phu:rooms-bedroom
    state:
      - icon: phu:rooms-bedroom
        styles:
          icon:
            - color: white
            - width: 40px
          name:
            - color: white
            - font-size: 12px
            - padding-top: 5px
        value: Bedroom
        styles:
          icon:
            - color: white
            - opacity: 0.5
            - width: 40px
          name:
            - color: white
            - font-size: 12px
            - padding-top: 1px
        operator: default
    styles:
      icon: null
    tap_action:
      service: input_select.select_option
      service_data:
        entity_id: input_select.room_lights
        option: Bedroom
EDIT: it was render as squares
Got there in the end :slight_smile:
I have a short question regarding show_last_changed. If I use this option, it should show me the last_changed attribute from the sensor. So far, so good.
Unfotunately after a restart of HA I get the time from the last restart, despite the dev-tools show the correct time from the last change.
Anyone an idea? :slight_smile:
Thatā€™s how the last changed property works. Dev tools doesnā€™t show this, so Iā€™m not sure how youā€™re getting that.
FYI read this, last_changed is not an attribute btw.
Thanks @Petro for the link! :+1: :slight_smile: In theory I know that, but I found the dev tools show the real value for last_changed and not the HA restart. Thatā€™s why I was working with this for a while now.
In the dev-tools I did a simple
{{ states.input_boolean.puppy_big_out.last_changed }} #gives the "real" timestamp from the last change
opposing to button-card that shows the HA restart timestamp (friendly format).
I use this in custom:logbook-card (link) as well, and there it shows the real value, too. Only button-card does show the value from the restart?
Can it be, that button-card works with the last_updated state attribute? That would explain the difference, but I havenā€™t checkedā€¦
Last changed 100% gives you the last value, which will be the restart if you restarted, it will not give you anything before the restart timestamp. When did you restart last? Paste this into your template editor and youā€™ll see they all match around the restart time and build up later dates. So if you restarted yesterday, most that donā€™t update once a day will be yesterday while the rest will be random times between yesterday and today.
{{ states | map(attribute='last_changed') | map('string') | sort | list }}
Logbook will show you the histories last changed, not whatā€™s on the state object.
There is no last_updated attribute. There is a last_updated property. It behaves very similar to last_changed in that it will always be past your last restart.
Hello there, hope someone could help me.
I canā€™t figure out to stretch my mini-graph-card inside a button-card. There is a space between bottom of the card and the graph.
The only thing which is working is increasing the height of the row with grid-template-rows, but the aspect_ratio 1/1 isnā€™t kept.
Hereā€™s my code :
    aspect_ratio: 1/1
    icon: mdi:chair-rolling
    entity: sensor.ble_temperature_thermometre1
    custom_fields:
      graph:
        card:
          type: custom:mini-graph-card
          entities:
            - sensor.ble_temperature_thermometre1
          show:
            icon: false
            state: false
          line_width: 5
      hu: |
          return `<ha-icon
          icon="mdi:water-percent:"
          style="width:20px;color: skyblue;">
          </ha-icon><span style="color: var(--text-color-sensor);">${states['sensor.ble_humidity_thermometre1'].state}%</span>`
      temp: |
          return `<ha-icon
          icon="mdi:thermometer:"
          style="width:20px;color:var(--accent-color);">
          </ha-icon><span>${entity.state}Ā°C</span>`
    styles:
      custom_fields:
        graph:
          - overflow: unset
      card:
        - overflow: unset
      grid:
        - grid-template-areas: '"n i" "temp hu" "graph graph"'
        - grid-template-columns: 50% 50%
        - grid-template-rows: 1fr 1fr 1fr
        - overflow: unset
      name:
        - font-size: 16px
        - color: white
      state:
        - font-size: 10px
        - color: white
And with setting
    styles:
      grid:
        - grid-template-rows: 30% 30% 100%
The card is higher than others in my horizontal stackā€¦
Many thanks for your help
Thanks @petro! :slight_smile: I did some more checks and it is like you said. The dev-tols show the same timestamp as button-card. Must have been a mixup or me not looking close enough. So far, so good, thank you! :slight_smile:
But I still didnā€™t get what I wanted. :frowning: You donā€™t happen to know where I could get the last time an input_boolean was switched (preferrably to on) even with one or many HA restarts in between? :slight_smile: In theory the value the logbook card is using. I can look it up in logbook card, but if you would know it right awayā€¦ :smiley: :rofl:
Thank you!
There is no easy way to do it. The fastest to the goal option would be to create an input_datetime and set it in the automation that turns on the boolean.
Hello all,
I was just made aware of this great card and am trying to get it to work.
I had opened a thread describing my problem here https://community.home-assistant.io/t/how-to-change-button-color-depending-on-temperature/357273
I donā€™t want to spam this thread so I will only repeat the vital code here :slight_smile:
Anyway, I am trying to create a button that sets the thermostat temperature and also changes itā€™s color based on the current temperature.
- type: button
            tap_action:
              service: climate.set_temperature
              service_data:
                temperature: 18
                entity_id: climate.eq_3_master_bedroom
So whenever the temperature differs from 18, I would like the button to be grey. Whenever the value equals 18, I would like it to be red.
However, the state itself is not ā€œ18ā€. The temperature is a state attribute.
The value has to be written differently, but I do not know how.
entity: climate.eq_3_living_room
color: rgb(192, 192, 192)
state:
  - value: 18
icon: mdi:fire-off
tap_action:
  service_data:
    temperature: 18
Could someone help me please? :slight_smile:
