Lovelace: Button card
Instead do something like this:
state:
  - operator: template
    value: "[[[ return entity.attributes.temperature == 18; ]]]"
    color: rgb(255, 0, 0)
Perfect, thank you @paddy0174 !
I have another small question: is it possible to make the font color conditional? I saw that there is color_type: card and color_type: label but I did not find a way to make the font change color.
I am asking because I am creating some buttons with text only and I do not want to color the card to highlight the current value.
You want to change the label font color ? Use the styles:
styles:
  label:
    - color: |
          if (states['climate.eq_3_living_room'].attributes.temperature < 20)
          return "#000000";
          return "#131fbf";
But I thought one of the main features of the button-card is that the color is applied if the state condition is true and you then do not need to define a second condition.
After all, icon color and card color change without an if statement.
In Germany we have a saying, that translates to “all pathes go to Rome!” (coming from the ancient roman empire), meaning, whatever you choose, you’ll end up in Rome. :smiley:
You can define the colors you want with the way you choose, it doesn’t really matter which one. Both should work. For “your” way to work, you just need to set the same style definitions as you would with the second way.
  state:
      value: "[[[ return entity.state ]]]"
      styles:
        icon:
          - color: 'rgba(var(--color-green),1)'
        label:
          - color: 'rgba(var(--color-green-text),1)'
This is just an example. :slight_smile:
Yes, it’s all “the same in green” :wink: :smiley:
Well, I figured since the color_type: is so elegant, it could also be applied to the label rather than having to work with variables/statements.
But I tried it and it is not quite working yet.
type: custom:button-card
entity: climate.eq_3_living_room
color_type: card
show_name: true
show_icon: false
show_state: false
state:
    value: '[[[ return entity.attributes.temperature == 4.5; ]]]'
    styles:
      label:
        - color: |
              if (entity.attributes.temperature == 4.5)
              return "#ff0000";
              return "#131fbf";
tap_action:
  action: call-service
  service: climate.set_temperature
  service_data:
    temperature: 4.5
    entity_id: climate.eq_3_living_room
The card itself is not being colored in red but the new style is not being applied (I left the color_type in there for reference).
Quick additional question:
am I correct in understanding that it is possible to define background images for this button card? I saw the background changing example on github but strangely no example for a simple, permanent background, so not sure if this is possible with the animation css.
So I’m using this template which works great (thanks @tom_l)
  light_button:
    aspect_ratio: 4/3
    color_type: icon
    hold_action:
      action: more-info
      haptic: selection
    label: >
      [[[ var bri = entity.attributes.brightness &&
      Math.round(entity.attributes.brightness / 2.55);  if
        (entity.state === 'on') return (bri ? (bri+"%") : 'On'); else return "Off"; ]]]
    layout: icon_label
    show_label: true
    show_name: true
    state:
      - styles:
          card:
            - border: solid 1px var(--button-card-light-color-no-temperature)
            - box-shadow: 0px 0px 10px 3px var(--button-card-light-color-no-temperature)
          label:
            - color: var(--paper-item-icon-active-color)
        value: 'on'
      - styles:
          card:
            - border: solid 1px var(--primary-color)
            - box-shadow: none
        value: 'off'
      - icon: mdi:alert
        label: Lost
        styles:
          card:
            - border: 'solid 1px #7f7f7f'
            - box-shadow: none
          icon:
            - color: '#ff0000'
            - opacity: 0.4
          label:
            - color: '#7f7f7f'
          name:
            - color: '#7f7f7f'
        value: unavailable
    styles:
      card:
        - border-radius: 10px
        - padding: 6px 6px 6px 6px
        - margin: 0% 0% 0% 0%
        - '--ha-card-background': rgba(0, 0, 0, 0)
      grid:
        - grid-template-areas: '"i l l" "n n n"'
        - grid-template-rows: 33% auto
        - grid-template-columns: 33% auto
      icon:
        - width: 28px
        - padding: 0px 0px 0px 0px
        - color: var(--button-card-light-color-no-temperature)
      label:
        - font-size: 12px
        - justify-self: right
        - color: var(--secondary-text-color)
      name:
        - justify-self: middle
        - align-self: end
        - font-size: 14px
        - color: var(--primary-text-color)
        - white-space: normal
    tap_action:
      action: toggle
Which gives me this
1
I’m trying to change the motion card to a RED border and flashing when active if possible ?
How or which part of the template code should I change to achieve this.
Because my coding sucks; an example would be appreciated in helping me understand, thanks :+1:
Don’t know about the flashing part but changing to red when on is easy enough, just these two last lines:
  light_button:
    aspect_ratio: 4/3
    color_type: icon
    hold_action:
      action: more-info
      haptic: selection
    label: >
    layout: icon_label
    show_label: true
    show_name: true
    state:
      - styles:
          card:
            - border: solid 1px red
            - box-shadow: 0px 0px 10px 3px red
Nice; you have a gift my friend. Thanks once again for taking the time to help :+1:
2
I have a problem and hope someone can help me. How do I get the buttons round at the bottom?
this is my code…
entity: group.wohnzimmer_all
aspect_ratio: 1
color_type: card
show_state: true
hold_action:
  action: fire-dom-event
  browser_mod:
    command: popup
    title: Wohnzimmer
    large: false
    hide_header: true
    style:
        .mdc-dialog {
          backdrop-filter: blur(17px);
          -webkit-backdrop-filter: blur(17px);
          background: rgba(0,0,0,0.25);
        .mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
          background: none !important;
          box-shadow: none;
          border-radius: 0px;
        .mdc-top-app-bar {
    card:
      type: vertical-stack
      cards:
        - type: custom:simple-thermostat
          entity: climate.wohnzimmer
        - type: entities
          card_mod:
            class: content
          entities:
            - entity: sensor.wandthermostat_wohnzimmer_temperature
            - entity: sensor.wandthermostat_wohnzimmer_humidity
            - entity: binary_sensor.wandthermostat_wohnzimmer_battery
        - type: custom:mini-graph-card
          entities:
            - color: '#385581'
          line_width: 6
          hour24: true
          group: true
          align_icon: left
          align_state: right
          align_header: left
          hours_to_show: 24
          show:
            fill: fade
            icon: false
            state: false
            name_adaptive_color: false
            labels: hover
            legend: false
          tap_action:
            action: none
custom_fields:
  Brightness:
    card:
      state:
        - value: 'on'
          color: rgba(65,65,63,0.2)
        - value: 'off'
      show_name: false
      show_state: false
      show_entity_picture: false
      color_type: icon
      tap_action:
        browser_mod:
          command: popup
          hide_header: true
          large: false
          style:
              .mdc-dialog {
                box-shadow: none;
                border-radius: 0px;
              .mdc-top-app-bar {
          card:
            type: entities
            entities:
              - type: custom:light-popup-card
                entity: light.wohnzimmer
                icon: none
                hideIcon: true
                fullscreen: false
                brightnessWidth: 130px
                brightnessHeight: 360px
                borderRadius: 1.7em
                sliderColor: '#c7c7c7'
                sliderTrackColor: rgba(25, 25, 25, 0.9)
              - type: custom:hui-element
                card_type: horizontal-stack
                card_mod:
                  style: |
                    #root {
                      justify-content: center;
                      margin-top: 2em;
                cards:
                  - type: custom:button-card
                    styles:
                      card:
                        - background: '#d8d9e1'
                    tap_action:
                      service: light.turn_on
                      service_data:
                        entity_id: light.wohnzimmer
                        color_temp: 153
                    styles:
                      card:
                        - background: '#d5b08d'
                    tap_action:
                      service_data:
                        color_temp: 326
                card_mod:
                  style: |
                    #root {
                      margin-bottom: 1em;
                cards:
                    styles:
                      card:
                        - background: '#ce944b'
                    tap_action:
                      service_data:
                        color_temp: 500
                    styles:
                      card:
                        - background: >-
                            radial-gradient(circle, rgba(255, 255, 255, 1) 0%,
                            rgba(255, 255, 255, 0) 80%), conic-gradient(rgb(120, 39,
                            230), rgb(230, 34, 231), rgb(228, 5, 136), rgb(228, 25,
                            25), rgb(229, 105, 30), rgb(232, 226, 46), rgb(125, 230,
                            41), rgb(52, 232, 40), rgb(51, 231, 92), rgb(52, 232,
                            224), rgb(32, 125, 229), rgb(18, 39, 229), rgb(120, 39,
                            230))
                    tap_action:
                      browser_mod:
                        command: popup
                        title: Wohnzimmer
                        hide_header: true
                        card:
                          type: custom:light-entity-card
                          brightness: true
                          color_temp: true
                          full_width_sliders: false
                          hide_header: true
                          show_slider_percent: true
                          smooth_color_wheel: true
                          persist_features: true
                          consolidate_entities: true
      styles:
        card:
          - width: 40px
        icon:
          - width: 70%
      style: |
        ha-card {
          box-shadow: none;
          background: transparent
      icon: mdi:brightness-6
show_entity_picture: true
styles:
  card:
    - width: 100px
    - height: 100px
  grid:
    - grid-template-areas: '"i" "n" "s"'
    - grid-template-columns: 1fr
    - grid-template-rows: 1fr min-content min-content
  name:
    - justify-self: start
    - padding-left: 7px
    - font-weight: bold
    - font-family: Sans-serif
    - font-size: 13px
  img_cell:
    - justify-content: start
    - padding-left: 19px
    - padding-top: 7px
    - align-items: start
    - margin: none
  state:
    - font-color: red
    - font-size: 15px
    - padding-left: 7px
    - padding-bottom: 10px
    - text-transform: capitalize
    - font-size: 13px
  icon:
    - width: 30%
  custom_fields:
    Brightness:
      - position: absolute
      - left: 60%
      - top: 10%
      - width: 60%
state:
  - value: 'on'
    entity_picture: \local\img\icons8-armchair-96.png
    color: rgba(243, 241, 239, 1)
  - value: 'off'
    styles:
      card:
        - filter: opacity(50%)
      icon:
        - filter: grayscale(100%)
Thanks in advance
I add width, height and border radius to the code. now it look like this… but how do I get the buttons in the middle of the card?
                    styles:
                      card:
                        - border-radius: 50%
                        - width: 50px
                        - height: 50px
                    tap_action:
                      service_data:
                        color_temp: 153
I’m not entirely sure either for the border but I make my buttons ‘wiggle’ when they turn on. You might like that instead :grin:
state:
  - value: 'on'
    styles:
      card:
        - box-shadow: 0px 0px 2px 1px {{ color | default('var(--paper-item-icon-color)') }}
        - animation: wiggle 0.16s 6
extra_styles: |
  @keyframes wiggle {
    0% { transform: rotate(0deg); }
    33% { transform: rotate(10deg); }
    66% { transform: rotate(-10deg); }
    100% { transform: rotate(0deg); }
Actually, I just remembered that I do this for blinking but it blinks the whole button not the border. Maybe it is a clue?
state:
  - value: 'unavailable'
    styles:
      icon:
        - color: var(--accent-color)
        - animation: blink 2s ease infinite
      state:
I can’t really find a practical solution for my “problem”: i have a dehumidifer card and i show different text. based on it’s power consumption.
All works, but i wonder, is it any better way to define “state_display” ? Currently i have veeeery long definition and it’s quite a mess. Can it be broken into multiple lines to be more “user friendly” for editing?
state_display: "[[[ if (states['sensor.tasmota_2_energy_power_1'].state ==0)  return \"IZKLJUČEN \_ \" + states['sensor.tasmota_2_energy_power_1'].state + \"W\";  else if (states['sensor.tasmota_2_energy_power_1'].state <10)  return \"NAPAKA! \_ \" + states['sensor.tasmota_2_energy_power_1'].state + \"W\"; else if (states['sensor.tasmota_2_energy_power_1'].state <50)  return \"VLAGA JE OK: \_ \" + states['sensor.tasmota_2_energy_power_1'].state + \"W\"; else  return \"RAZVLAŽUJE: \_ \" + states['sensor.tasmota_2_energy_power_1'].state + \"W\";]]]"
You’re totally on the right track. :+1: Thanks for reminding me, I need this as well and had totally forgotten about @keyframes!
To make a border “blink”, you need to set the @keyframes, but change the border color from say yellow to black to yellow to black. :slight_smile:
Not sure if its been asked but i had a quick search and couldnt find anything. Are you able to inject or use a custom font for specific sections of a card e.g. I want a label to display with a LED Matrix font. My TTF is in my www folder so i would assume using Extra_Styles and then declaring the font source would work but it didnt for me:
@font-face {
font-family: TEST;
src: url(/local/fonts/TEST.ttf);
font-weight:400;
-font-family: TEST
To use Google fonts you can do this…
styles:
  card:
    - font-family: Oswald
In your 'resources.yaml`
- url: https://fonts.googleapis.com/css?family=Oswald
  type: css
You can also use local fonts, there is a post somewhere on here that explains it (I beleive tom_l added the finishing touches. If I were a betting man I’d wager he will be here soon… :slight_smile: )
I have the following but won’t promise it is the entirety of the instructions… I can’t actually remember :blush:
In my 'resources.yaml`
- url: /local/fonts/loadfonts.js
  type: module
In my www folder I have two files:
loadfonts.js
function loadcss() {
    let css = '/local/fonts/fonts.css?v=0.013'
    let link = document.createElement('link');
    let head = document.getElementsByTagName('head')[0];
    let tmp;
    link.rel = 'stylesheet';
    link.type = 'text/css';
    tmp = link.cloneNode(true);
    tmp.href = css;
    head.appendChild(tmp);
    console.info('%c Font Style sheet loaded', 'color: white; background: #000; font-weight: 700;');
loadcss();
and
fonts.css
@font-face {
  font-family: "Oswald";
  src: url(/local/fonts/oswald-variablefont_wght.woff2) format('woff2');
And then the font file I downloaded form google fonts in woff2 format
Actually I just remember I setup a custom font for a theme and used the resources. Those as woff and work. This is a ttf but doesn’t appear to load.
I’ll do some more checking later. No need to download from Google for me. The font is all local.
@ [dexstar]
how do you use or save that template ?
I am trying to duplicate it to a button, but it needs something that i am missing ?
is it a grid card or what ? how can i use this ?
thanks in advance
gr. Wim
