dexstar
November 24, 2021, 2:25am
6151
Welcome to the community. Hope this helps you out.
First you’ll need this plugin installed from the amazing @thomasloven
https://github.com/thomasloven/lovelace-hui-element
Then; click on the 3 dots and Edit Dashboard.
Click on the 3 dots again and select Raw configuration editor.
Then paste this code from the equally amazing @tom_l
button_card_templates:
red_border:
aspect_ratio: 4/3
color_type: icon
hold_action:
action: more-info
haptic: selection
label: >
[[[ var bri = entity.attributes.brightness &&
Math.round(entity.attributes.brightness / 2.55); if
(entity.state === 'on') return (bri ? (bri+"%") : 'On'); else return "Off"; ]]]
layout: icon_label
show_label: true
show_name: true
state:
- styles:
card:
- border: solid 1px red
- box-shadow: 0px 0px 10px 3px red
label:
- color: var(--paper-item-icon-active-color)
value: 'on'
- styles:
card:
- border: solid 1px var(--primary-color)
- box-shadow: none
value: 'off'
- icon: mdi:alert
label: Lost
styles:
card:
- border: 'solid 1px #7f7f7f'
- box-shadow: none
icon:
- color: '#ff0000'
- opacity: 0.4
label:
- color: '#7f7f7f'
name:
- color: '#7f7f7f'
value: unavailable
styles:
card:
- border-radius: 10px
- padding: 6px 6px 6px 6px
- margin: 0% 0% 0% 0%
- '--ha-card-background': rgba(0, 0, 0, 0)
grid:
- grid-template-areas: '"i l l" "n n n"'
- grid-template-rows: 33% auto
- grid-template-columns: 33% auto
icon:
- width: 28px
- padding: 0px 0px 0px 0px
- color: var(--button-card-light-color-no-temperature)
label:
- font-size: 12px
- justify-self: right
- color: var(--secondary-text-color)
name:
- justify-self: middle
- align-self: end
- font-size: 14px
- color: var(--primary-text-color)
- white-space: normal
tap_action:
action: toggle
light_button:
aspect_ratio: 4/3
color_type: icon
hold_action:
action: more-info
haptic: selection
label: >
layout: icon_label
show_label: true
show_name: true
state:
- styles:
card:
- border: solid 1px var(--button-card-light-color-no-temperature)
- box-shadow: 0px 0px 10px 3px var(--button-card-light-color-no-temperature)
label:
value: 'on'
- styles:
card:
- box-shadow: none
value: 'off'
- icon: mdi:alert
label: Lost
styles:
card:
- box-shadow: none
icon:
- color: '#ff0000'
- opacity: 0.4
label:
- color: '#7f7f7f'
name:
- color: '#7f7f7f'
value: unavailable
styles:
card:
grid:
icon:
- width: 28px
label:
- font-size: 12px
name:
- align-self: end
- font-size: 14px
tap_action:
action: toggle
Make sure it is at the TOP and Save.
ADD the “MANUAL CARD” and paste this code. Change the entities to suit your setup.
entities:
- type: custom:hui-element
card_type: horizontal-stack
cards:
- entity: switch.meals
template: light_button
type: custom:button-card
- entity: switch.entry
- entity: binary_sensor.garage_motion
tap_action:
action: more_info
template: red_border
type: entities
Hopefully no errors and it works
dexstar
November 24, 2021, 7:46am
6152
After some (LOTS) of trial and error. Success. A flashing border.
Now; to see if I can turn this into a template would be awesome.
The code if anyone is interested. Improvements appreciated too.
state:
- value: 'on'
styles:
card:
- animation: bgcolorswap 1s linear infinite
extra_styles: |
@keyframes bgcolorswap {
0% {
border: 15px solid rgb(0, 0, 0, 50%);
25% {
border: 5px solid rgb(255, 27, 27, 50%);
50% {
75% {
100%
styles:
card:
tap-action:
action: more-info
klogg
(Klogg)
November 24, 2021, 8:09am
6153
Way off topic (but as I was quoted… )
What do you use to create the animated gif of a (partial) screen shot?
dexstar
November 24, 2021, 10:25am
6155
The template
red_border:
aspect_ratio: 4/3
color_type: icon
hold_action:
action: more-info
haptic: selection
label: >
layout: icon_label
show_label: true
show_name: true
state:
- styles:
card:
label:
- value: 'on'
styles:
card:
extra_styles: |
0% {
border: 3px solid rgb(0, 0, 0, 50%);
25% {
border: 3px solid rgb(255, 27, 27, 50%);
50% {
75% {
100% {
- styles:
card:
- box-shadow: none
value: 'off'
- icon: mdi:alert
label: Lost
styles:
card:
- box-shadow: none
icon:
- color: '#ff0000'
- opacity: 0.4
label:
- color: '#7f7f7f'
name:
- color: '#7f7f7f'
value: unavailable
styles:
card:
grid:
icon:
- width: 28px
label:
- font-size: 12px
name:
- align-self: end
- font-size: 14px
And the card
entities:
cards:
- entity: binary_sensor.bathroom_motion
tap_action:
action: more_info
- entity: switch.living_room
tap_action:
action: more_info
type: entities
geefi868
(Wim)
November 24, 2021, 8:55pm
6156
Thanks for the help !
Unfortunately there is an error. In the Lovelace view the button says " custom element does not exist: hui-element.
dexstar
November 24, 2021, 9:12pm
6157
You need to add the plugin from the 1st step; that is giving you the error message.
benm7
(Ben M)
November 25, 2021, 1:47am
6158
I am trying to create a button which resets a particular filter value on my vacuum based on an input select, but can’t seem to get it right. Hoping someone can give me some tips on how to get this working!
Example using ‘Services’:
service: vacuum.send_command
entity_id: vacuum.robomac
command: reset_consumable
params:
- sensor_dirty_time
My button code:
tap_action:
action: call-service
data_template:
params: "{{ input_select.robomac_reset }}_time"
Where ‘input_select.robomac_reset’ will be one of the following:
sensor_dirty
filter
main_brush
side_brush
try {{states(input_select.robomac_reset)}}_time
benm7
(Ben M)
November 25, 2021, 4:09am
6160
No luck Im afraid, this is the error I get when I call it:
geefi868
(Wim)
November 25, 2021, 8:32am
6161
I have never used a manual plugin, so probably that is why I made the mistake.
I have only copied the hui-element.js to the www. Folder.
And then ofcourse the other steps
I assume that is not correct ?
dexstar
November 25, 2021, 9:48am
6162
I’ll send you a guide to help you out. At “Work” at the moment.
nice wiggle, just found it and added to the templates:
wiggle:
state:
- value: 'on'
styles:
card:
- animation: wiggle 0.16s 6
extra_styles: |
@keyframes wiggle {
0% { transform: rotate(0deg); }
33% { transform: rotate(10deg); }
66% { transform: rotate(-10deg); }
100% { transform: rotate(0deg); }
seeing this in the inspector though…
Unhandled Promise Rejection: SyntaxError: Custom element name contains a character that is not allowed
must we ignore, or can we fix…
Four things to check:
For jinja tempates, the entity should be in quotes (in this case single quotes within your double quotes as you have it on one line):
"{{ states('input_select.robomac_reset') }}_time"
Secondly, however, I believe this custom card is an exception in that it uses javascript templates , not jinja templates.
Thirdly, I think (but might be wrong) that calling a service from this card uses service_data
not data_template
. But obviously I can’t test this, so I can’t guarantee this will work at all:
tap_action:
service_data:
params: "[[[ return states['input_select.robomac_reset'] + '_time'; ]]]"
Finally, I assume you have confirmed that your robot model actually supports a send_command
command called reset_consumable
? Not all models can use this service, and even then the commands available for it will vary quite a bit.
klogg
(Klogg)
November 25, 2021, 1:48pm
6165
TBH I never even noticed.
You are though, the ‘Inspector Inspector’ (apoplogies if the dry humour fails to translate…) so I am hoping now that you can tell me
benm7:
No luck Im afraid,
Quotes, of course! + JS instead of jinjia2
benm7
(Ben M)
November 25, 2021, 10:41pm
6167
getting close! It’s not spitting up any errors but its not resetting either. I can confirm my vacuum supports it as I was able to reset the dirt sensor using the ‘Services’ section perfectly fine.
I had to update my input selects to match the instructions below, but the code I am using below (also tried with a ; as shown) doesn’t seem to reset anything.
tap_action:
service_data:
params: "[[[ return states['input_select.robomac_reset'] + '_time' ]]]"
So I think it is running the command ok but passing incorrect parameters???
benm7
(Ben M)
November 25, 2021, 11:54pm
6168
Ok its definitely the passing of the parameters causing the issue, as this works below to reset the filter:
tap_action:
service_data:
params: ['filter_work_time']
Does anything about incorrect parameters show in the Home Assistant logs when you press the button?
I think the yaml is expecting the parameter to be passed as a list within square brackets, but I’m getting to the limits of my JavaScript knowledge here, so not sure how that can be done.
