Lovelace: Button card
The answer;
  - type: custom:mushroom-chips-card
    card_mod:
    style: |
      ha-card {
        --chip-box-shadow: none;
        --chip-background: none;
    chips:
      - type: entity
        entity: sensor.temp
        icon_color: blue
#mushroom #chips #shadow #card-mod
that actually worked…
custom card
type: custom:button-card
show_icon: false
show_state: false
show_name: true
show_label: false
view_layout:
  grid-column: 3
  grid-row: 4
grid:
  - position: absolute
styles:
  card:
    - width: 200px
    - height: 200px
    - border-radius: 0px
    - background-color: blue
  grid:
    - grid-template-areas: >-
        "n n n n n n n n 9 10" "item2 item2 item2 item2 item2 6 7 8 9 10" "item2
        item2 item2 item2 item2 6 7 8 9 10" "item2 item2 item2 item2 item2 6 7 8
        9 10" "1 2 3 4 5 6 7 8 9 10" "1 2 3 4 5 6 7 8 9 10" "1 2 3 4 5 6 7 8 9
        10" "1 2 3 4 5 6 7 8 9 10" "1 2 3 4 5 6 7 8 9 10" "1 2 3 4 5 6 7 8 9 10"
    - grid-template-columns: repeat(10, 1fr)
    - grid-template-rows: repeat(10, 1fr)
  name:
    - font-size: 10px
    - align-self: center
    - justify-self: start
  custom_fields:
    item2:
      - align-self: start
custom_fields:
  item2:
    card:
      entities:
        - entity: light.standerlampe
      icon: mdi:lightbulb-variant
      show_name: false
      styles:
        card:
          - background: white
          - border-radius: 50%
          - width: 40px
          - height: 40px
        img_cell:
          - background: none
      style: |
        ha-card {
          box-shadow: none;
thank you for your help :slight_smile:
I actually tried with the chips card during my ā€œtrial-and-errorā€ run… i had the same issue… but now i could prop get it to work as intended…
Another one to the same card…
Someone that knows why this happens…
pre-change
custom card
after change
custom card2
only thing that changes…
pre-change-code
code after change…
i dont get how that changing one ā€œblockā€ from ā€œnā€ to ā€œ1ā€ can affect ā€œimg_cellā€ that way… in my logic it should at most move the ā€œnameā€ tekst a bit to the right… but that should be all…
Any thoughts…??
No problem! You can also play more with the style of the custom:button-card in the custom_field. For instance using state for on off and then the styles like icon under it. Which allows you to have stylings for different states, like turn the bulb to yellow when it’s on and to grey when it’s off etc. All is documented very well in the READ.ME on the Github of this card.
I’m not a CSS expert myself, but I did manage to create amazing looking button-cards with grid by using this tool: https://grid.layoutit.com
It allows you to create the grid visually and shows the code you can copy/paste to use with the button-card. Perhaps it’s easier to create your grid layout there first and then copy the code to button-card.
That is a very cool tool… thx :slight_smile:
I also tried my hand on the absolute positioning… it seems alot easier to work with when " freehand placing" elements…
Hello Guys,
I spend the better part of the day working myself into button-card and I created this dude here:
As an experienced user you might already see, that the GUI already displays the button.card somehow strange in the edit view.
When I try to make a horizontal stack, the cards overlay.
Bildschirmfoto 2022-10-16 um 22.26.05
Might someone please help me with what I’m doing wrong here?
aspect_ratio: 1/1
icon: mdi:home-lightning-bolt-outline
entity: sensor.gesamtverbrauch_haus_taglich
show_state: true
show_units: false
custom_fields:
  i_2: |
      return `<ha-icon
        icon="mdi:sigma"
        style="width: 25px; height: 25px; color: white;">
        </ha-icon>`
  unit: kWh
styles:
  grid:
    - grid-template-areas: '"i i_2" "n n" "s unit"'
    - grid-template-columns: 55% 1fr
    - grid-template-rows: 55% 10% 1fr
    - align-items: start
    - gap: 4%
  name:
    - padding-left: 10px
    - font-size: 16px
    - color: grey
  state:
    - align-self: end
    - font-size: 28px
    - padding-bottom: 8px
  card:
    - width: 150px
    - height: 150px
  icon:
    - color: |
          if (entity.state < 7) return 'lime';
          if (entity.state >= 7 && entity.state < 80) return 'orange';
          else return 'red';
    - width: 100%
    - filter: opacity(60%)
  img_cell:
    - align-self: start
    - text-align: end
  custom_fields:
    unit:
      - color: grey
      - align-self: end
      - font-size: 16pt
    i_2:
      - justify-self: end
      - padding-top: 8px
      - padding-right: 8px
Thanks in advance!
I found the problem. Obviously the aspect_ratio in combination with a fix width/height caused the problem. After undoing this it works fine now.
I’ve seen a number of people using the variable
ā€œā€“button-card-light-color-no-temperatureā€
When I use this in my config, this variable still changes when the light goes from warm-white to cool-white.
Is there anything specific that needs to be done to use this variable?
Make sure you use two dashes, in your example you only use one.
So: --button-card-light-color-no-temperature
Thanks @ASNNetworks
The YAML does use 2 dashes. Not sure why they disappeared in my message above:
entity: light.lamp_x_officedesk
styles:
  card:
    - width: 80px
    - box-shadow: 0px 0px 10px 3px var(--button-card-light-color-**no-temperature**)
box-shadow: 0px 0px 10px 3px var(–button-card-light-color-no-temperature)
or
box-shadow: 0px 0px 10px 3px var(–button-card-light-color)
have the same effect:
The GOAL:
Show a yellow ā€˜on’ glow (and ideally icon) when it’s on, regardless of the color temperature or brightness. Like this:
Well, the code is meant to show the color of the light with and without the temperature. If you have bulbs that only operate RGB, then both codes would return the exact same color since the light has no temperature attribute. And if the light isn’t RGB, there is no point in using the variable. It’s to reflect the color the light is currently in.
Light entity color variable (see link)
If a light entity is assigned to the button, then:
  • the CSS variable --button-card-light-color will contain the current light color
  • the CSS variable --button-card-light-color-no-temperature will contain the current light without the temperature
You can use them both in other parts of the button. When off, it will be set to var(--paper-item-icon-color)
If your goal is to show a YELLOW glow and icon when a light is on, why not just use a color code and state styles, so you have different styles depending on state?
state:
  - styles:
      icon:
        - color: rgb(255,255,0)
      card:
        - width: 80px
        - box-shadow: 0px 0px 10px 3px rgb(255,255,0)
    value: 'on'
styles:
  card:
    - width: 80px
When state is on it will apply the styles listed there. When the state is anything else, like off or unavailable it will revert to default. You can create multiple states. If the light doesn’t match any of the states you created, it will use the default style (the one at the bottom). If you want other colors for the default styles, then list them there (like greyed out icon color when off, or different color shadow or background etc).
What bothers me in this type of glow is that when glow is ON it goes into neighbouring card, if not set very small, since glow is ā€œdrawnā€ outside of reuglar card. It should be drawn to the inside…
Then use a different style? Like inset. → CSS Box Shadow | CSS-Tricks - CSS-Tricks
Yes! Thanks! Added to my favorites.
I managed to put it in my card without card-mod. Just replace above ā€œbox-shadowā€ with
- box-shadow: inset 0 0 50px lime
and you get glow to inside. Perfect!
Well yes, that’s kinda the feature of this card and is also shown in the above code. You don’t need card-mod for styling this card, it’s explained in great detail in the readme.
I found even better version by adding another parameter:
- box-shadow: inset 0 0 30px 10px lime
it gives nicer and clearer color at very edges.
If your goal is to show a YELLOW glow and icon when a light is on, why not just use a color code and state styles , so you have different styles depending on state?
That’s what I like about this forum. I never thought off solving this in a completely different way: state styles
:slight_smile:
Works like a charm!
I loved the Laundry Card. I’m a new to HA but learning as fast as I can. I notice on the card you use a type: custom:hui-entities-card. Where I can find this custom:hui-entities-card?
