Lovelace: Button card
Thanks. Am I not able to use this version without the hold_action? I removed all references to it, but still not able to toggle anything.
You can, but have to have something on the view that implements longpress still:
  • entity-button
  • glance
  • picture-entity
  • picture-glance
Like @RomRider said, weā€™ll find a way around this
:tada::tada: Version 0.4.1 :tada::tada:
New features
  • confirmation now takes a free text to display in the confirmation box
  • Fallback to simple click support when longpress is not found. Make sure you read this for long press support!
Fixes
  • Fixes #114 (rounded corners with color_type: card) and supports card-modder now
Breaking changes
  • confirmation is now taking a string.
@scfigg, version 0.4.1 which was just released fixes this. Only single click support if longpress is not found.
:tada::tada: Version 0.5.0 :tada::tada:
New features
  • show_units: true/false
  • units: overrides the default units of a sensor
  • overflowing text will be cut at the end with ...
  • layout:
    Fixes #103
    This option enables you to modify the layout of the card.
    It is fully compatible with every show_* option. Make sure you set show_state: true if you want to show the state
    Multiple values are possible, see the image below for examples:
    • vertical (default value if nothing is provided): Everything is centered vertically on top of each other
    • icon_name_state: Everything is aligned horizontally, name and state are concatenated
    • name_state: Icon sits on top of name and state concatenated on one line
    • icon_name: Icon and name are horizontally aligned, state is centered below
    • icon_state: Icon and state are horizontally aligned, name is centered below
    • icon_name_state2nd: Icon, name and state are horizontally aligned, name is above state
    • icon_state_name2nd: Icon, name and state are horizontally aligned, state is above name
Hi all
is it possible to change text color on state
Iā€™ve done like this
            show_state: false
            show_icon: false
            show_name: true
            state:
              - value: 'on'
                style:
                  - color: yellow
But I get the background color to change, not the text.
55
How can I change just the text?
@woody4165, the color of the text is automatically calculated based on the background color, but for that to work, the color has to be expressed in RGB or HEX.
Itā€™s not (yet) possible to define the color of individual elements.
Instead of color: yellow use color: rgb(255,255,0) or color: '#FFFF00' in the state directly, not in the style object:
            show_state: false
            show_icon: false
            show_name: true
            state:
              - value: 'on'
                color: rgb(255, 255, 0)
Thanks!
Itā€™s working now.
Hey everyone,
Iā€™m working on this currently:
Which enables you to do stuff like (itā€™s ugly, on purpose :smile:):
entity_picture
Feedback very much welcome, on the PR directly please :slight_smile:
Not sure whatā€™s up, but color and color_type are behaving strangely in both 0.4.1 and 0.50.
With color_type: icon, I get a blue icon and white background (the rgb() is orange so Iā€™d expect an orange icon).
With color_type: card, I get a blue background and a white icon.
If I comment out the color and color_type and assign the color in the style: I get the expected orange background.
  - type: custom:button-card
    color_type: icon
    color: rgba(245,116,56,1)
    style:
#      - background-color: rgba(245,116,56,1)
      - border-radius: 10px
      - box-shadow: 3px 3px rgba(0,0,0,0.4)
    entity: media_player.firetv_living_room
    icon: mdi:stop
    name: BUTTON only CType card
    hold_action: none
    tap_action:
      action: call-service
      service: androidtv.adb_command
      service_data:
        entity_id: media_player.firetv_living_room
        command: "input keyevent 86"
If I nest the button within a config-template-card and define the color_type: and color: the button fails to render at all, but works fine if color is defined in the style:
  - type: custom:config-template-card
    variables:
      - states['input_select.firetv_choices'].state
    entities:
      - input_select.firetv_choices
    card:
      color_type: card
      color: rgb(245,116,56)
      style:
      entity: "${vars[0] === 'FireTV Living Room' ? 'media_player.firetv_living_room' : 'media_player.firetv_bedroom'}"
      icon: mdi:stop
      hold_action: none
      tap_action:
        service_data:
          entity_id: "${vars[0] === 'FireTV Living Room' ? 'media_player.firetv_living_room' : 'media_player.firetv_bedroom'}"
I still canā€™t seem to get hold_action to work, even with a picture entity in the view/card:
  - type: horizontal-stack
    cards:
      - type: picture-entity
        entity: switch.furnace_switch_29
        state_image:
          'off': /local/pictures/furnace-off.png
          'on': /local/pictures/furnace.png
        tap_action:
          action: toggle
        hold_action:
          action: more-info
        entity: switch.lamp
        state_image:
          'off': /local/pictures/lamp-off.jpg
          'on': /local/pictures/lamp.jpg
        tap_action:
          action: toggle
        hold_action:
          action: more-info
    cards:
      - type: 'custom:button-card'
        entity: switch.bathroom_light
        hold_action:
          action: more-info
        tap_action:
          action: toggle
        color: var(--primary-color)
        icon: attribute
        entity: switch.bathroom_fan
        hold_action:
          action: more-info
        tap_action:
          action: toggle
        icon: attribute
Any Ideas? It works for the picture entity
errors in the browser console?
all I see is this, which is a common one:
/frontend_latest/26357108de036797f570.chunk.js:3210 Uncaught TypeError: Cannot read property ā€˜replaceChildā€™ of null
at HTMLElement._rebuildCard (/frontend_latest/26357108de036797f570.chunk.js:3210)
at HTMLElement.t.addEventListener.once (/frontend_latest/26357108de036797f570.chunk.js:3210)
at i (app-652a7f4d.js:410)
at /frontend_latest/26357108de036797f570.chunk.js:4568
Youā€™ve cleared your browser cache since upgrading?
Yeah, I did that
I see six of these in the console:
TypeError: Argument 1 of Window.getComputedStyle does not implement interface Element.
from code:
getFontColorBasedOnBackgroundColor(backgroundColor) {
  let parsedBackgroundColor = null;
  if (backgroundColor.substring(0, 3) === "var") {
    let rgb = getComputedStyle(this.parentNode).getPropertyValue(backgroundColor.substring(4).slice(0, -1)).trim();
    parsedBackgroundColor = this.hexToRgb(rgb.substring(1));
  } else {
    const parsedRgbColor = backgroundColor.match(/^rgb\s*\(\s*(\d+)\s*,\s*(\d+)\s*,\s*(\d+)\s*\)$/i);
    parsedBackgroundColor = parsedRgbColor ? parsedRgbColor : this.hexToRgb(backgroundColor.substring(1));
  let fontColor = ''; // don't override by default
  if (parsedBackgroundColor) {
    // Counting the perceptive luminance - human eye favors green color...
    const luminance = (0.299 * parsedBackgroundColor[1] + 0.587 * parsedBackgroundColor[2] + 0.114 * parsedBackgroundColor[3]) / 255;
    if (luminance > 0.5) {
      fontColor = 'rgb(62, 62, 62)'; // bright colors - black font
    } else {
      fontColor = 'rgb(234, 234, 234)';// dark colors - white font
  return fontColor;
Note that when color_type: is ā€œiconā€ the specified rgb() color is not used. Here is what Inspector shows for Icon:
<ha-icon style="color: var(--paper-item-icon-color); width: 40%; height: auto;" icon="mdi:stop" class=""></ha-icon>
Hey, it randomly started working after I restarted. Thanks!
@RomRider Is it possible to show the value of another entity with this button card yet please? e.g. the buttons below show a count from a sensor, but change colour based on an input_boolean on/off state.
The following Lovelace yaml for Tiles Card shows how the Windows button above is coded:
- entity: input_boolean.window_is_open
  row: 2
  column: 1
  background:
    value_on: rgb(71,39,45) #Red
    value_off: rgb(49,68,42) #Green
  label_sec:
    color:
      value_on: rgb(220,69,121) #Red text
      value_off: rgb(134,219,85) #Green text
  icon:
    color:
  templates:
    label_sec: "return 'Windows: ' + entities['sensor.windows_open'].state;"
    style: "return 'font-weight: bold;'"
    icon: "if (state === 'on') return 'mdi:window-open'; else return 'mdi:window-closed'"
Thanks in advance!
What browser are you using?
Nope thatā€™s not supported (yet?), feel free to open an issue on github :blush:
Iā€™m currently converting the whole button to typescript following @iantrichā€™s suggestion. Expect some delay before the next feature as this is a massive refactoring process. However, this will fix problems with long press support and prepare the card for a better future!.
Massive work, I canā€™t wait til the hold_action is working like it should. For now I am holding out on this card but man you are making it so much better now. If only the core button would be something like this.
Other question: wouldnā€™t it be possible to contribute this to core when it is ready?
