Lovelace: Button card
Well, that worked flawlessly, thanks a lot Marius!
kind regards,
Ben
I really like the custom:button-card. However, I am not able to achieve following use-case and hope you can help.
I am using the custom button-card for opening and closing of my gate doors, which functionality wise works just fine.
I would like enable some icon animation while the gate doors open or close (hence, when in motion).
I would as well like to disable multiple button-clicks while the doors are in motion.
Since the gate only has two states, “Open” and “Closed” and hence, no state called “Opening/Closing”, I would like to use a time-frame (15sec) after button-click to represent the state “Opening/Closing” and also during this time-frame to enable the animation and and disabling of multiple clicks.
Any ideas how to best achieve this?
Thanks.
I rely heavily on the button-card for all my dashboards. It hasn’t been supported since 2021 and there have not been any commits in at least 2 years. With the latest 2023.3 version of HA, there is a new precision masking feature (actual name??) that allows you to set the decimals of precision. I has JS code to set the precision in some tiny buttons that would display a huge red box when the sensor is not working. Without the JS, the box is empty so I changed the precision on the device (Humidity without decimals) and removed the JS. Problem is that button-card does not support this new feature and it is unsupported so no chance of it ever being added…
This is how it displays with the JS code in place
This is how it displays once I removed the JS code even though I set the humidity to not have decimals:
This is the YAML:
type: custom:button-card
entity: sensor.office_multi_sensor_humidity
state_display: |
    var result = Number(entity.state).toFixed(0);
    return result.concat("%");
styles:
  card:
    - height: 100%
    - width: 42px
    - padding: 0px 0px 0px 2px
  name:
    - text-transform: uppercase
    - font-size: 12px
    - font-weight: normal
    - justify-self: center
    - letter-spacing: 2px
    - padding: 0%
tap_action:
  action: none
show_icon: false
show_name: false
show_state: true
layout: name_state
While there may be a way to keep the JS code that sets precision and not have it break the dashboard if something happens to the sensor, I am quite concerned that some future update will blow up all my 50 or so views where I likely used the button-card. Are there alternatives? Is some brilliant developer willing to take on maintenance from the original developer @RomRider ? I love this card but I don’t want to keep using it if it isn’t supported… too big of a risk.
Example of my main dashboard where I heavily rely on it… all of those are button-cards
I just found “Paper buttons Row” in HACS and i’m playing a bit with it. First test look promising…it seems that it has all from button card plus more.
But… since i also have a lot of custom:button cards going to a different card will take a lot of time and programming…
yes, this might become a issue.
was wondering why I had no issues in my button-cards since the latest update, and my taking out all(!) rounds in the yaml config though, I just realized Ive had
${Math.round(states['sensor.raw_value'].state)}
since forever on those.
So, as much as I would hope to see an updated, or maybe should say maintained custom:button-card, the latest (great) change in HA really holds no issue for this card at all.
as a matter of fact: it simply returns what you say it should and in that, is way more predictable and configurable than any core Frontend card :wink:
btw, there are subtle differences between the various methods for rounding Math.round(), toInt(), toFixed():
Hi Juan,
sorry for this late response, but please let me ask how you get the colored icon background in the first?
been looking for a way to get the same effect as on the new Tile cards and dit find something like:
'radial-gradient(var(--card-background-color) 60%, transparent calc(60% + 1px)), conic-gradient(var(--tile-color) {{ (states(config.entity) |float * 100) | round(0) }}% 0%, var(--card-background-color) 0% 100%);
tried to rebuild that to JS and add it to
styles:
  icon:
    - background: >
        [[[ return 'radial-gradient(var(--card-background-color) 60%,transparent calc(60% + 1px)), conic-gradient(var(--tile-color) Math.round(states[config.entity])% 0%, var(--card-background-color) 0% 100%)';
but no such luck just yet…
the color is set correctly by this, but the background size isnt…
          styles:
            img_cell:
#               - background-color: "rgba(var(--color-theme),0.05)"
              - border-radius: 50%
              - place-self: start
              - width: 42px
              - height: 42px
            icon:
  #             - filter: drop-shadow(0 0 12px var(--button-card-light-color))
              - background: >
                  [[[ var color = entity.attributes.rgb_color;
                      return (entity.state === 'on') ?
                      'rgba(' + color + ',0.2)' : 'none'; ]]]
this is copied from mushroom internal templates, and I only moved it to the start of the cell, as that is where I want the icons…
Scherm­afbeelding 2023-03-06 om 11.16.32
@Mariusthvdb I will add my response here to not clutter the Mushroom thread with custom:button-card stuff.
This line defines the size of the icon within the img_cell. And could it be that there is some overflowing not allowed or margin/padding from other areas in your card that cut off the icon bit?
thanks! yes, I just added a line indeed not to clutter Mushroom.
on the button, no I dont think so, and even in it’s cleanest form:
      - type: custom:button-card
        entity: light.dining
        icon: mdi:silverware
        <<: &style
#           template: button_light
          show_last_changed: false
          styles:
            img_cell:
              - border-radius: 24px
              - place-self: start
              - width: 42px
              - height: 42px
            icon:
              - background: >
still doest not show the full circle:
Scherm­afbeelding 2023-03-06 om 11.33.19
with my light template:
        <<: &style
          styles:
            img_cell:
              - place-self: start
              - width: 42px
              - height: 42px
            icon:
              - background: >
its back to the one posted above…
taking the img_cell section out brings back all to its correct proportions, only doesnt set the background circle:
Scherm­afbeelding 2023-03-06 om 11.38.27
If you try to add some padding to the img_cell? Then other parts should inherit that information and probably not cutoff the icon part.
no that does not help (yet) as it the background itself simply isnt complete yet.
Scherm­afbeelding 2023-03-06 om 11.49.37
adding padding 2px to this:
Scherm­afbeelding 2023-03-06 om 11.50.55
        <<: &style
          styles:
            img_cell:
              - padding: 2px
              - place-self: start
              - width: 42px
              - height: 42px
            icon:
              - background: >
so I am looking for a before and after of the currently visible background
It must be something in the rest of your card. For now I cannot determine it because you use yaml-anchors and templates. But a simple setup with the same code used by you returns to this:
      - type: "custom:button-card"
        entity: sensor.lowest_price
        show_label: false
        show_name: false
        color: blue
        styles:
          img_cell:
            - background-color: "rgba(var(--color-blue),0.05)"
            - border-radius: "50%"
            - place-self: "start"
            - width: "42px"
            - height: "42px"
          # added to overrule theme settings for general card design
           card:
            - background: "none"
            - box-shadow: "none"
Scherm­afbeelding 2023-03-06 om 12.25.26
using:
        show_label: false
        show_name: false
        color: auto
        styles:
          img_cell:
            - background-color: "rgba(entity.attributes.rgb_color,0.05)"
            - width: "42px"
            - height: "42px"
          card:
background-color needs to be set on the icon:
Scherm­afbeelding 2023-03-06 om 12.27.18
so we know theming has nothing to do with it, this is default theme:
Scherm­afbeelding 2023-03-06 om 12.28.21
@basbrus
on to something:
    - type: grid
      columns: 5
#       square: false
      cards:
          color: auto
          styles:
            img_cell:
              - background-color: >
                  [[[ return 'rgba(' + entity.attributes.rgb_color + ',0.2)'; ]]]
              - width: "38px"
              - height: "38px"
          styles:
            img_cell:
#               - background-color: >
#                   [[[ return 'rgba(' + entity.attributes.rgb_color + ',0.2)'; ]]]
#               - padding: 2px
              - place-self: start
              - width: "38px"
              - height: "38px"
            icon:
              - background: >
#             - background: >
#                 [[[ return 'radial-gradient(var(--card-background-color) 60%,transparent calc(60% + 1px)), conic-gradient(var(--tile-color) 2% 0%, var(--card-background-color) 0% 100%)';
apparently, when setting the background to the icon, it only sees the smaller area, where using it on the img_cell it takes all into account…
I did that before, because somehow I couldn’t get the color to show at all. Probably a template mistake, because now I see:
Scherm­afbeelding 2023-03-06 om 14.23.47
so 2 things left after this progress!
  • icon is not centered inside the background.
  • content is lower because of the colored background, almost touching the bottom of the card as you can see.
adding justify-content: center makes at least the icon placement work (the padding is depending on grid columns, 4 is ok, 4 starts to be too low). This is required because by default the cells are rendered with:
styles_img_cell:
  styles:
    img_cell:
      - align-items: start
      - justify-content: start
in my other buttons… pfff
          color: auto
          styles:
            img_cell:
              - justify-content: center
              - place-self: start
              - width: 38px
              - height: 38px
Scherm­afbeelding 2023-03-06 om 14.39.34
guess placement will have to do for now, maybe I will play some more with the paddings.
left now is the coloring when off;
                  [[[ var rgb = (entity.state === 'on') ? entity.attributes.rgb_color : 'var(--primary)';
                      return 'rgba(' + rgb + ',0.2)'; ]]]
with var(–primary) being the single rgb value primary: 99,107,117 seems to be the way to go, but then I need to adjust my other colors once more, because they are not standing out :wink:
o well…Ill fix it for now on
                  [[[ var rgb = (entity.state === 'on') ? entity.attributes.rgb_color : '211,211,211';
Scherm­afbeelding 2023-03-06 om 15.11.06
though darker themes require extra work…
Glad you found a way to make it work :smile:
This what exactly that I was expecting; some styling related to the img_cell/icon in one of your templates/anchors. At least from the snippets shown I was not able to help any further :wink:
Dark themes are always a bit more difficult with creating a fitting contrast.
I never even noticed it was no longer maintained!!
I am in deep trouble if this ever stops working.
This, for example is almost 100% buttons :scream:
argghhh… feeling your pain already :wink:
btw @basbrus my main issue now is the various display devices messing with some carefully crafted buttons in grids (4 or 5 card, who to let drop off the card, have it overflow…e tc etc)
because of that, ive just rewritten a full button-card config especially for this, and though it seems utterly simple, the template behind it require attention for all details…
  - type: grid
    columns: 4
    square: false
    cards:
        <<: &style
          template:
            - styles_state_default_auto
            - action_default
          color: auto-no-temperature
          layout: icon_name
          show_state: false
          styles:
            card:
              - padding: 5px
              - font-weight: bold
              - font-size: 13px
              - border-right: >
                      ? '0.5rem solid var(--button-card-light-color)' : 'none';
            img_cell:
              - place-self: start
              - width: 34px
              - height: 34px
        entity: light.living
        <<: *style
believe it or not, but even the bottom 34px’s need to be adjusted to 32px for these buttons so show a round (and not flattened circle on mobile)
Good day Marius, no problem. I eventually found the solution.
Please see below my ‘room-card’ version. I use decluttering to avoid repetition.
decluttering_templates:
  card_room:
    card:
      aspect_ratio: 1/1
      entity: '[[entity]]'
      icon: '[[icon]]'
      show_icon: true
      show_label: false
      show_state: false
      # size: 50%
      tap_action:
        action: navigate
        navigation_path: /lovelace-mobidash/[[room]]
      double_tap_action:
        action: navigate
      hold_action:
        action: toggle
      custom_fields:
        chips:
          card:
            type: custom:mushroom-chips-card
            chips:
              - type: conditional
                conditions:
                  - entity: '[[light_group]]'
                    state: 'on'
                chip:
                  type: template
                  icon: mdi:lightbulb-outline
                  icon_color:  >
                    {% if is_state('[[light_group]]', 'on') %}
                      #FFBF00
                    {% else %} light-blue {% endif %}
                  content_info: none
                  tap_action:
                    action: more-info
                  card_mod:
                    style: |
                      @keyframes clip {
                        0% {
                          clip-path: inset(100% 0 0 0);
                        100% {
                          clip-path: inset(0 0 0 0);
                      ha-card {
                        --chip-box-shadow: 0px 0px;
                        animation: clip linear infinite;
                        {% if is_state('[[input_boolean_autooff]]', 'off') %}
                        animation-duration: 3s;
                        {%- else -%}
                        {%- endif %}
              - type: conditional
                conditions:
                  - entity: '[[switch_group]]'
                    state: 'on'
                chip:
                  type: entity
                  icon: mdi:toggle-switch-variant-off
                  icon_color: '#FFBF00'
                  content_info: none
                  tap_action:
                    action: more-info
              - type: conditional
                conditions:
                  - entity: '[[motion_group]]'
                    state: 'on'
                chip:
                  type: entity
                  icon: mdi:motion-sensor
                  icon_color: green
                  content_info: none
                  tap_action:
                    action: more-info
              - type: conditional
                conditions:
                  - entity: '[[media_group]]'
                    state_not: 'off'
                chip:
                  type: entity
                  icon: mdi:play-pause
                  icon_color: green
                  content_info: none
                  tap_action:
                    action: more-info
              - type: conditional
                conditions:
                  - entity: '[[door_group]]'
                    state: 'on'
                chip:
                  type: entity
                  icon: mdi:door-open
                  icon_color: red
                  content_info: none
                  tap_action:
                    action: more-info
              # - type: conditional
              #   conditions:
              #     - entity: '[[aircon_switch]]'
              #       state_not: 'off'
              #   chip:
              #     type: template
              #     entity: '[[climate]]'
              #     icon_color:  >
              #       {% if is_state('[[climate]]','fan_only') %}
              #         yellow
              #       {% elif is_state('[[climate]]','cool') %}
              #         light-blue
              #       {% elif is_state('[[climate]]','dry') %}
              #         light-blue
              #       {% else %} {% endif %}
              #     icon: >
              #         mdi:fan
              #         mdi:snowflake
              #         mdi:snowflake
              #     # content: '{{state_attr("[[climate]]", "hvac_action") }}'
              #     tap_action:
              #       action: call-service
              #       service: climate.turn_off
              #       target:
              #         entity_id: '[[climate]]'
              #     hold_action:
              #       action: more-info
              #     card_mod:
              #       style: |
              #         @keyframes rotation {
              #           0% {
              #             transform: rotate(0deg);
              #           100% {
              #             transform: rotate(360deg);
              #         ha-card {
              #           --chip-box-shadow: 0px 0px;
              #           animation: rotation linear infinite;
              #           animation-duration: 3s;
              #           {%- else -%}
              #           {%- endif %}
              - type: conditional
                conditions:
                  - entity: '[[fan_switch]]'
                    state_not: 'off'
                chip:
                  type: entity
                  icon: mdi:fan
                  icon_color: light-blue
                  content_info: none
                  tap_action:
                    action: toggle
                  hold_action:
                    action: more-info
                  card_mod:
                    style: |
                        0% {
                        100% {
                      ha-card {
                        {% if is_state('[[fan_switch]]','on') %}
                        {%- else -%}
                        {%- endif %}
              - type: conditional
                conditions:
                  - entity: '[[cover]]'
                    state: 'closed'
                chip:
                  type: template
                  entity: '[[cover]]'
                  icon: mdi:curtains-closed
                  tap_action:
                    action: more-info
              - type: conditional
                conditions:
                  - entity: '[[alarm]]'
                    state_not: 'disarmed'
                chip:
                  type: template
                  entity: '[[alarm]]'
                  icon_color: red
                  icon: '{{ "mdi:shield-account-outline" if states("[[alarm]]") in ["armed_night","armed_away"] }}'
                  tap_action:
                    service: alarm_control_panel.alarm_disarm
                      entity_id: '[[alarm]]'
                  hold_action:
                    action: more-info
                  card_mod:
                    style: |
                      @keyframes blink {
                          50% {opacity: 0;}
                      ha-card {
                        animation: blink linear infinite;
                        {% if states("[[alarm]]") in ["armed_night","armed_away"] %}
                        {%- else -%}
                        {%- endif %}
              - type: conditional
                conditions:
                  - entity: sensor.unraid_disk_status
                    state_not: 'Ok'
                chip:
                  type: template
                  entity: '[[sensor_disk]]'
                  icon_color: red
                  icon: "{{'mdi:harddisk' if is_state_attr('[[entity]]', 'friendly_name','Unraid Disk Status') }}"
                  tap_action:
                    action: more-info
              - type: conditional
                conditions:
                  - entity: sensor.unavailable_entities
                    state_not: '0'
                chip:
                  type: template
                  entity: '[[sensor_unavailable]]'
                  icon_color: red
                  icon: "{{'mdi:alert-circle' if is_state_attr('[[entity]]', 'friendly_name','Unraid Disk Status') }}"
                  tap_action:
                    action: more-info
              - type: conditional
                conditions:
                  - entity: binary_sensor.home_assistant_condition
                    state: 'on'
                chip:
                  type: template
                  entity: '[[sensor_hass]]'
                  icon_color: red
                  icon: "{{'mdi:home-assistant' if is_state_attr('[[entity]]', 'friendly_name','Unraid Disk Status') }}"
                  tap_action:
                    action: more-info
              - type: conditional
                conditions:
                  - entity: '[[entity]]'
                    state_not: 'unavailable'
                chip:
                  type: template
                  icon: "{{'mdi:cctv' if is_state_attr('[[entity]]', 'friendly_name','Doorbell') }}"
                  tap_action:
                    action: navigate
                    navigation_path: surveillance
            alignment: start
            layout: vertical
            card_mod:
              style:
                  ha-card {
                    margin-left: 30%;
                    background: none;
                    --chip-box-shadow: none;
                    --chip-border-width: 0;
                    --chip-icon-size: 20px;
                    --chip-height: 20px;
                    --chip-background: none;
                    --chip-spacing: 3px;
                    padding-top: 0px;
                    border: 0px;
                    box-shadow: none;
                  :host {
                    --mush-icon-size: 20px;
                    --mush-chip-spacing: 3px;
        ambient: >
            if (states['[[entity]]'].attributes.friendly_name != 'Unraid Disk Status' && (states['[[entity]]'].attributes.friendly_name != 'Doorbell'))
            return `${Math.round(states['[[temperature]]'].state) }°C | ${Math.round(states['[[humidity]]'].state) }%`;
            return `${Math.round(states['[[temperature]]'].state) }°C`;
      styles:
        custom_fields:
          chips:
            - padding: 5px 0px 0px 20%
            - overflow: unset
            - align-self: start
            - justify-self: end
            # - filter: opacity(50%)
          ambient:
            - margin-top: -280%
            - font-size: 12px
            - padding: 0px 0px 0px 3px
            - justify-self: start
            - color: > # added the enitity filter to accomodate outdoor, which has no climate
                  if ((states['[[entity]]'].attributes.friendly_name != 'Outdoor Lights') && (states['[[entity]]'].attributes.friendly_name != 'Unraid Disk Status')
                    && (states['[[entity]]'].attributes.friendly_name != 'Doorbell') && (states['[[climate]]'].state == 'fan_only')) return "yellow";
                    && (states['[[entity]]'].attributes.friendly_name != 'Doorbell') && (states['[[climate]]'].state == 'cool')) return "#03A9F4";
                    && (states['[[entity]]'].attributes.friendly_name != 'Doorbell') && (states['[[climate]]'].state == 'dry')) return "deepskyblue";
            # - align-self: middle
        card:
          - overflow: hidden
          - border-width: 0
          - border-style: outset
        grid:
          - grid-template-areas: '"n chips" "ambient chips" "i chips"'
          - grid-template-columns: 1fr 1fr
          - grid-template-rows: 1fr min-content min-content
          - padding: 0px 0px 0px 0px
          - justify-items: "center"
        img_cell:
          - background-color: >  # var(--secondary-background-color) # rgba(0,0,0,.2) #"rgba(var(--color-green),0.05)"
                if (entity.state == 'on') return '#d4ebf2';
                if (states['sun.sun'].state == 'above_horizon') return 'rgba(0,0,0,.1)';
                if (states['sun.sun'].state == 'below_horizon') return 'rgba(100, 100, 100,.5)';
                else return 'var(--theme-color)';
          - width: "75%"
          - height: "75%"
          - max-width: "none"
          - max-height: "none"
          - position: "absolute"
          - left: "50%"
          - top: "50%"
          - transform: "translate(-50%,-50%)"
          - margin-top: "25%"
          - margin-left: "-25%"
        icon:
          - place-self: center
          - color: >
                if (entity.state == 'on') return '#03A9F4';
                else return 'grey';
          - width: 50%
          - overflow: "hidden"
          # - display: "grid"
        name:
          - margin-bottom: 150%
          - font-size: 16px
          - font-weight: bold
          - text-overflow: "ellipsis"
          - overflow: unset
and a sample use
        type: custom:decluttering-card
        template: card_room
        variables:
        - entity: group.master_room_lights
        - icon: fas:restroom
        - name: Master
        - temperature: sensor.avg_master_temperature
        - humidity: sensor.master_humidity
        - room: master
        - climate: climate.master
        - input_boolean_autooff: input_boolean.plate01_autooff
        - light_group: group.master_room_lights
        - motion_group: group.master_room_motion
        - media_group: group.master_room_media
        - door_group:
        - aircon_switch: switch.master_aircon_power
        - fan_switch: fan.masterfan
        - cover: cover.mastercurtains
        - sensor_disk: sensor.unraid_disk_status
        - sensor_unavailable: sensor.unavailable_entities
        - sensor_hass: binary_sensor.home_assistant_condition
thanks, nice,
will have a thorough peek and c&p where required :wink:
I use a decluttering template for this. Hoping that it could help you; the length is to do with time only or date and time input datetime card.
  datetime_format_extra:
    card:
      entity: '[[ent]]'
      show_name: false
      show_state: false
      show_icon: false
      show_label: true
      label: |-
          return (entity.state).substring(0,((entity.state).length == 19 ? 16 : 5 ))
      styles:
        border-radius: 1px
        card:
          - height: 30px
          - width: 80px
        label:
          - color: >-
              [[[ var id = states['[[flag]]'].state;   return (id == "on") ?
              "green": "red" ]]]
      tap_action:
        action: more-info
I have a card that rotates through some background images, but once the temperature passes a threashold I want a solid background color to flash. The background color works, but not the flashing.
          card:
            - animation: |
                [[[ if (entity.state <= 58)
                  return "bgswap1 20s linear infinite";
                else
                  "blink 2s ease infinite";
