For timers i use custom:flipdown-timer-card from HACS. Try and see if it fits your needs.
Changing the values helped a bit! but the icon is still spinnig off center. I could not find a way to align the icon in the center.
Maybe check mine. But I didnāt try spin it.
custom_fields:
alert:
- border-radius: 50%
- position: absolute
- height: 14px
- width: 14px
- line-height: 14px
- margin-left: 8px
- margin-top: -4px
- justify-self: start
- align-self: start
- border-radius: "50%"
- background-color: "var(--white)"
- color: "var(--red)"
- display: "[[[ return variables.alert ? 'block' : 'none'; ]]]"
- animation: blink 2s ease infinite
Good evening everybody!
I am trying to make a list with all the states that a device can have and activate a custom field when the device is in one of those states. I am trying this for a while now but I can not get the var sensor in the ulm_state_sensor working.
With the code I have now I can get it to work when I place the entity directly in the var sensor of the custom button. But when I want to use the variables.ulm_state_sensor the entire icon disappears from the dashboard.
Does anyone know how to get the var sensor to work with the entity from variables.ulm_state_sensor?
Custom button code
dot_active_test:
variables:
ulm_state_sensor: "[[[ return variables.ulm_state_sensor; ]]]"
ulm_state_sensor_test: >
var sensor = states[variables.ulm_state_sensor].state
var state = {
"none": "1",
"docked": "1 ",
"cleaning": "1",
"default": "0"
return (state[sensor] || state["default"]);
styles:
custom_fields:
dot_test:
- position: "absolute"
- left: "25px"
- top: "-3px"
- height: "17px"
- width: "17px"
- border: "2px solid var(--card-background-color)"
- font-size: "17px"
- line-height: "17px"
- background-color: >
return "rgba(var(--color-green),1)";
extra_styles: |
[[[ return `
@keyframes spinning {
10% {
transform: rotate(36deg) ;
20% {
transform: rotate(72deg) ;
20% {
transform: rotate(108deg) ;
40% {
transform: rotate(144deg) ;
50% {
transform: rotate(180deg) ;
60% {
transform: rotate(216deg) ;
70% {
transform: rotate(252deg);
80% {
transform: rotate(288deg);
90% {
transform: rotate(324deg) ;
100% {
transform: rotate(360deg) ;
custom_fields:
dot_test: >
if (variables.ulm_state_sensor_test == 1){
return `<ha-icon icon="mdi:reload" style=" animation: spinning 3s linear infinite; width: 17px; height: 17px; color: var(--primary-background-color);"></ha-icon>`
Dashboard code
- type: 'custom:button-card'
template: device_card_vacuum
variables:
ulm_card_binary_sensor_alert: true
ulm_mode: input_select.vacuum_mode
ulm_state_sensor: vacuum.robot_vacuum
entity: vacuum.robot_vacuum
Thanks for the example! i havenāt managed to get the icon alignāt in the middle but with some tweaking it isnāt very noticeable anymore. Maybe I will figure it out someday gheghe
My apologies in advance if my question / use case is not designed for the custom:button-card. I currently have an Insteon based system connected to HA through an ISY994i which causes Insteon āscenesā to appear as āentitiesā within HA.
This works ok and the scenes can be manipulated using the regular entities card, but their are some weird āside effectsā that Iām trying to overcome using custom:button-card with a Horizontal Stack. Ideally scenes should only have an āonā / āoffā button and no status information or iconagraphy. The picture below shows both the current state using the built-in HA Entites Card versus a mock-up of what Iād like to see using Horizontal Stacks with custom:button-card
I have the beginning bits of the YAML code put together shown below:
type: horizontal-stack
cards:
- type: custom:button-card
color_type: label-card
color: rgb(0, 0, 0)
name: Movie Time in Rumpus Room
color_type: blank-card
color_type: card
color: rgb(0, 97, 0)
color_type: card
color: rgb(97, 0, 0)
I have a couple of questions:
Using the YAML above, scenes with long names are cut off. I would like instead for the scene name to be able to fill up the available space to the left of the āOnā button. How would I be able to do that?
I read up briefly on ātemplatesā with custom:botton-card, and it seems to me that if I have a list of 30 or so Scenes that I wanted to list out using this format that a template would be a good way to do this. Is this correct? Or is there a better way?
Thank you for taking the time to answer my questions.
Thereās two ways you can approach problem 1: keep the code you have and set overflow: visible to your text field. Untested, so you might have to do some trial and error and the biggest drawback is if the text is long enough, it will cover your on and off buttons also.
The more elegant way would be to increase the width of your label-card and justify the text to the left.
As for problem 2: yes, it makes sense to create a template for this. But Iād recommend first to get your card looking like you want it and then move on to creating s template.
Thank you for the tips on how to do this. After a little experimentation, I was able to come up with the following YAML which does what Iām looking for:
cards:
color: rgb(0, 0, 0)
name: All Bathroom lights
- styles:
name:
- overflow: visible
- text-align: left
- vertical-align: text-top
- width: 270px
color_type: card
tap_action:
action: call-service
service: switch.turn_on
service_data:
entity_id: switch.all_bathroom_lights
- styles:
card:
- height: 28px
- margin-top: 7px
- width: 70px
color_type: card
tap_action:
service: switch.turn_off
service_data:
- styles:
card:
- height: 28px
- margin-top: 7px
- width: 70px
And this provided the look that I was going for, which is shown in the picture below:
Need to figure out how to turn this into a template . . .
In the card below I am receiving the following error when I click any of the On/Off/Dim/Bright buttons. Does anyone know what could be going wrong?
Failed to call service light/turn_on connection lost
Also, whatās the correct syntax to call multiple entity_idās when using service-data?
type: grid
columns: 2
cards:
- type: button
show_name: true
show_icon: true
name: Kitchen & Entry
icon: mdi:sofa
entity_id: light.light_entry_lamp_hue
hold_action:
service: scene.turn_on
service-data:
entity_id: scene.entry_room_bright
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
browser_id: THIS
dismissable: true
content:
type: vertical-stack
cards:
- type: custom:mod-card
card:
cards:
entity_id: light.light_entry_corner_hue
show_name: true
show_icon: false
tap_action:
service: light.turn_off
service-data:
entity_id: >-
light.kitchen_can_lights
show_name: true
show_icon: false
tap_action:
service: light.turn_on
service-data:
entity_id: >-
entity_id: scene.entry_room_dim
show_name: true
show_icon: false
tap_action:
service-data:
show_name: true
show_icon: false
tap_action:
service-data:
card_mod:
style: >
ha-card { --ha-card-background: rgb(65, 68, 74); filter:
drop-shadow(2.5px 2.5px 0.125rem rgb(48, 48, 51)); }
- type: horizontal-stack
cards:
show_name: true
show_icon: true
tap_action:
action: toggle
entity: switch.salt_lamp
icon: mdi:lava-lamp
- type: custom:mushroom-light-card
entity: light.light_entry_corner_hue
icon: mdi:lamp-outline
fill_container: true
use_light_color: true
show_brightness_control: true
show_color_temp_control: true
show_color_control: true
collapsible_controls: false
layout: horizontal
primary_info: name
card_mod:
style: >
ha-card { --ha-card-background: rgb(51, 49, 49); filter:
drop-shadow(2.5px 2.5px 0.125rem rgb(179, 179, 179)); }
entity: light.light_entry_lamp_hue
layout: horizontal
primary_info: name
card_mod:
style: >
entity: light.kitchen_can_lights
use_light_color: false
show_color_temp_control: false
show_color_control: false
layout: horizontal
primary_info: name
card_mod:
style: >
card_mod:
style:
ha-dialog$: |
div.mdc-dialog div.mdc-dialog__scrim {
backdrop-filter: blur(10px);
div.mdc-dialog__container {
align-items: center;
Trying to use the āsourceā attribute from my Android/Google TV and this wonāt work, what am I doing wrong?
entity: media_player.android_tv_192_168_2_123
[[[ return
`${states['media_player.android_tv_192_168_2_123'].attributes.source}` ]]]
show_entity_picture: true
styles:
grid:
- grid-template-areas: '"i gutter n"'
- grid-template-columns: min-content 24px 1fr
card:
- background: var(--ha-card-background)
- padding: 24px
- '--mdc-ripple-press-opacity': 0
icon:
- width: 70px
- height: 70px
- border-radius: 16px
- border: 5px solid var(--ha-icon-active-color)
name:
- font-size: 16px
- color: var(--hki-primary-text-color)
- width: 100%
- text-align: left
state:
- operator: template
value: >
return states['media_player.android_tv_192_168_2_123'].attributes.source
=== 'Netflix'
entity_picture: /local/netflix.png
styles:
card:
- background: rgba(229,9,20)
icon:
- border: 5px solid rgba(229,9,20,0.5)
I think you are just looking for the state of the timer.
I have this in a custom button card:
The spinning hour glass with the timer countdown below is just that:
custom_fields:
pause:
card:
entity: timer.timer_30_min
show_state: true
show_name: false
tap_action:
service: input_boolean.toggle
service_data:
entity_id: input_boolean.adguard_pause
styles:
card:
- box-shadow: none
- border: none
- margin-left: 0%
- width: 35px
state:
- font-size: 10px
icon:
- width: 100%
state:
- value: idle
styles:
icon:
- color: var(--paper-item-icon-color)
state:
- color: white
- value: active
styles:
icon:
- color: red
state:
- color: red
spin: true
(untested) Shouldnāt it be
attributes[āsourceā]
It did not like thatā¦
[[[ return
`${states['media_player.android_tv_192_168_2_123'].attributes[āsourceā]` ]]]
styles:
grid:
card:
- padding: 24px
icon:
- width: 70px
- height: 70px
name:
- font-size: 16px
- width: 100%
- text-align: left
state:
value: |
var bri = states['media_player.android_tv_192_168_2_123'].attributes[āsourceā];
return 'Google TV Launcher';
entity_picture: /local/googletvlauncher.png
styles:
card:
- background: rgb(66, 133, 244)
icon:
- border: 5px solid rgb(15,157,88)
value: |
return 'Twitch';
entity_picture: /local/twitch.png
styles:
card:
- background: rgba(169,112,255)
icon:
- border: 5px solid rgba(169,112,255,0.5)
value: >
return states['media_player.android_tv_192_168_2_123'].attributes[āsourceā]
=== 'Netflix'
styles:
card:
icon:
value: |
return 'YouTube';
entity_picture: /local/youtube.png
styles:
card:
- background: rgb(255,0,0)
icon:
- border: 5px solid rgba(255,0,0,0.5)
These are the wrong apostrophs. I donāt know, which you used, but you can only use these "
or this '
, like so:
['source']
This happens a lot with people working on Apple computers, seeing this apostrophes problem here more often, always with Apple
Yeah, my problem is, Iām not a native speaker, so Iām really struggeling with the different names for different apostrophesā¦ I donāt even know the correct names in my own language.
Yes I am using Mac lol, but that didnāt work either.
[[[ return
`${states['media_player.android_tv_192_168_2_123'].attributes['source']` ]]]
styles:
grid:
card:
- padding: 24px
icon:
- width: 70px
- height: 70px
name:
- font-size: 16px
- width: 100%
- text-align: left
state:
value: |
var bri = states['media_player.android_tv_192_168_2_123'].attributes['source'];
styles:
card:
icon:
value: |
return 'Twitch';
styles:
card:
icon:
value: >
return states['media_player.android_tv_192_168_2_123'].attributes['source']
=== 'Netflix'
styles:
card:
icon:
value: |
return 'YouTube';
styles:
card:
icon:
This seems like a mix of custom-template-card & button-card.
What about just
[[[ return
states['media_player.android_tv_192_168_2_123'].attributes['source'] ]]]
Thanks for the response, so I have tried this and it shows the right app name at the top sure, but for some reason the image doesnāt changeā¦
[[[ return
styles:
grid:
card:
- padding: 24px
icon:
- width: 70px
- height: 70px
name:
- font-size: 16px
- width: 100%
- text-align: left
state:
value: |-
[[[ return states['media_player.android_tv_192_168_2_123'].attributes['source'];
return 'Google TV Launcher'; ]]]
styles:
card:
icon:
value: |-
return 'Twitch'; ]]]
styles:
card:
icon:
value: |-
return 'Netflix'; ]]]
styles:
card:
icon:
value: |-
return 'YouTube'; ]]]
styles:
card:
icon:
value: |-
return 'Disney+'; ]]]
entity_picture: /local/disneyplus.png
styles:
card:
icon:
When you use operator: template
the value should return true or false.
So a correct example will be
state:
value: |-
[[[ return states['media_player.android_tv_192_168_2_123'].attributes['source'] == 'Google TV Launcher'; ]]]
