Thank you! This worked for me.
if âsourceâ is an attribute of the media_player entity you shouldnt need the brackets around it, and
[[[ return states['media_player.android_tv_192_168_2_123'].attributes.source == 'Google TV Launcher'; ]]]
should work properly.
this is the regular syntax:
icon: >
[[[ return states['climate.front_room'].attributes.hvac_action == 'heating'
? 'mdi:radiator' : 'mdi:radiator-disabled'; ]]]
or some variables you might have in your system to test:
variables:
installed: >
[[[ return states['update.home_assistant_supervisor_update'].attributes.installed_version; ]]]
latest: >
[[[ return states['update.home_assistant_supervisor_update'].attributes.latest_version; ]]]
the you need that html syntax (eg with serving image files) thereâs a bit of care you need to show using the various quotes:
styles:
card:
- background-image: >
[[[ return `url("${states['sensor.moon_phases'].attributes.entity_picture}")`; ]]]
but even there you see the attribute simply listed after the dot.
Ever figure this out?
I have the same problem, I also get âFailed to call service switch/turn_on. connection lostâ. Definitely used to work before.
- type: custom:button-card
entity: switch.wohnzimmer_heizung_switch_7
show_name: true
name: Window Detection
show_state: false
color_type: card
color: rgb(254, 129, 0)
icon: mdi:window-open-variant
styles:
name:
- font-size: 15px
action: service
service:
domain: input_boolean
action: toggle
entity_id: switch.wohnzimmer_heizung_switch_7
Any help appreciated.
This never worked as button-card never supported data
: you should use service_data
instead of data
. Or use the last dev version which now supports this format.
not only does the official example (first post) use exactly that syntax, I tried it with 4.0.0-dev.12 yesterday, I still get same error:
From official example in first post:
- type: horizontal-stack
cards:
- type: "custom:button-card"
color_type: blank-card
color_type: card
color: rgb(223, 255, 97)
icon: mdi:volume-plus
action: service
service:
domain: media_player
action: volume_up
entity_id: media_player.livimg_room_speaker
color_type: card
icon: mdi:volume-minus
action: service
service:
action: volume_down
EDIT: And yes, it worked before, it stopped working only recently
Please read the documentationâŚ
action: call-service
service: media_player.volume_down
service_data: # or data with the latest beta
I tried the syntax from github now. Syntax from first post has been replaced, but I still get âFailed to call service switch/turn_on. connection lostâ:
cards:
entity: switch.wohnzimmer_thermostat_switch_9
show_name: true
show_state: false
color_type: card
icon: mdi:snowflake
styles:
name:
- font-size: 15px
service: input_boolean.toggle
service_data:
entity_id: switch.wohnzimmer_thermostat_switch_9
Sorry, this really used to work, and it really doesnât anymore. Hope anyone can confirm this.
youâre missing tap_action
cards:
show_name: true
show_state: false
color_type: card
icon: mdi:snowflake
styles:
name:
- font-size: 15px
tap_action:
service_data:
also input_boolean.toggle
for a switch
entity?
I added tap_action now, and the connection lost is gone. However, now it doesnât toggle the color anymore, nor does it actually change the entity state.
The behaviour and examples for this card changed, I mean, even in this thread started by @kuuji, my old syntax was totally normal.
Quite annoying.
That post is from 5y ago (I canât edit it because itâs not mine)⌠Iâve taken over the development of the card several years ago. The updated documentation is on GH (master branch for stable and dev branch for dev versions)
First of all, thank you for the work.
I have 1200 lines of yaml for 8 TRV Thermostats with 6 buttons each, that code used to work. I may have been using a very old version of this card before and updated it without noticing the break.
I guess I will try to get the old version running again.
EDIT: Itâs 1200 lines because it has all kinds of other sliders, knobs and graphs in it, it would be a lot of work to replace all the affected lines.
I donât think this has anything to do with button-card but with the entity itself and something that has changed in HA.
I use LedFX integration and since I updated to 2023.7.x (from 2023.4) my LedFX toggles have the same issue (exact same error as what you have). If I go to my entities page and try toggling there, it shows the issue as well. Which in my case means it canât be button-card since itâs not even being used there.
Can you try this out too? Go to your entities page (so outside of Dashboard/Lovelace) and see if controlling the entity there works. If that gives the same error, then it has nothing to do with button-card, but itâs an integration or HA issue.
if anything, you should update to the latest, and stop using the wrong service for the domain at hand.
as Jerome has also said above.
tap_action:
service: switch.toggle
service_data:
if you move to version 4 (now in beta) you can also use the official target and/or data, instead of service_data.
If that still doesnt work, somethingâs amiss with your entities, as ASNNetworks suggests (or, maybe somewhere in the rest of your 1200 lines⌠)
using many many of these toggles, and noise whatsoeverâŚ
Update,
I realized that the custom zha quirk, that I use for my TRV Thermostat was broken.
Even weirder, after I updated the quirk all buttons actually work again ⌠with the old syntax.
So if anyone is interested, this works with the current 3.5 Version of custom Button Card:
type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 33% 33% 33%
grid-template-rows: auto
grid-template-areas: |
"Master Master Master"
"Master2 Master2 Master2"
"Outside Outside Outside"
"Area1 Area1 Area1"
"Mmain1 Mmain2 Mmain3"
"Mmain11 Mmain22 Mmain33"
"Mmain111 Mmain222 Mmain333"
"Area2 Area2 Area2"
"Area21 Area22 Area23"
"Area211 Area222 Area233"
"Area2111 Area2222 Area2333"
"Area3 Area3 Area3"
"Area31 Area32 Area33"
"Area311 Area322 Area333"
"Area3111 Area3222 Area3333"
"Flur1 Flur2 Flur3"
cards:
- type: custom:simple-thermostat
entity: climate.wohnzimmer_thermostat_thermostat_2
header:
view_layout:
grid-area: Mmain1
- type: custom:layout-card
layout_type: grid
layout:
"button1 button2 button3"
cards:
show_name: true
show_state: false
color_type: card
icon: mdi:snowflake
styles:
name:
- font-size: 15px
tap_action:
service_data:
entity: switch.wohnzimmer_thermostat_switch_12
show_name: true
show_state: false
color_type: card
icon: mdi:logout
styles:
name:
- font-size: 15px
service_data:
entity_id: switch.wohnzimmer_thermostat_switch_12
entity: switch.wohnzimmer_thermostat_switch_8
show_name: true
show_state: false
color_type: card
icon: mdi:human-male-child
styles:
name:
- font-size: 15px
service_data:
entity_id: switch.wohnzimmer_thermostat_switch_8
entity: switch.wohnzimmer_thermostat_switch_10
show_name: true
name: Limescale Protection
show_state: false
color_type: card
icon: mdi:timer-alert-outline
styles:
name:
- font-size: 15px
service_data:
entity_id: switch.wohnzimmer_thermostat_switch_10
entity: switch.wohnzimmer_thermostat_switch_11
show_name: true
show_state: false
color_type: card
icon: mdi:timetable
styles:
name:
- font-size: 15px
service_data:
entity_id: switch.wohnzimmer_thermostat_switch_11
entity: switch.wohnzimmer_thermostat_switch_7
show_name: true
show_state: false
color_type: card
styles:
name:
- font-size: 15px
service_data:
entity_id: switch.wohnzimmer_thermostat_switch_7
view_layout:
grid-area: Mmain11
- type: entities
entities:
- entity: number.wohnzimmer_thermostat_number_temperature_calibration_2
name: Wohnzimmer Calibration
view_layout:
grid-area: Mmain111
entity: climate.tobi_thermostat_thermostat
header:
view_layout:
grid-area: Mmain2
layout_type: grid
layout:
cards:
entity: switch.tobi_thermostat_switch_3
show_name: true
show_state: false
color_type: card
icon: mdi:snowflake
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.tobi_thermostat_switch_3
entity: switch.tobi_thermostat_switch_6
show_name: true
show_state: false
color_type: card
icon: mdi:logout
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.tobi_thermostat_switch_6
entity: switch.tobi_thermostat_switch_2
show_name: true
show_state: false
color_type: card
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.tobi_thermostat_switch_2
entity: switch.tobi_thermostat_switch_4
show_name: true
show_state: false
color_type: card
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.tobi_thermostat_switch_4
entity: switch.tobi_thermostat_switch_5
show_name: true
show_state: false
color_type: card
icon: mdi:timetable
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.tobi_thermostat_switch_5
show_name: true
show_state: false
color_type: card
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
view_layout:
grid-area: Mmain22
- type: entities
entities:
- entity: number.tobi_thermostat_number_temperature_calibration
name: Tobi Calibration
view_layout:
grid-area: Mmain222
entity: climate.kuche_thermostat_thermostat_3
header:
view_layout:
grid-area: Mmain3
layout_type: grid
layout:
cards:
entity: switch.kuche_thermostat_switch_15
show_name: true
show_state: false
color_type: card
icon: mdi:snowflake
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.kuche_thermostat_switch_15
entity: switch.kuche_thermostat_switch_18
show_name: true
show_state: false
color_type: card
icon: mdi:logout
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.kuche_thermostat_switch_18
entity: switch.kuche_thermostat_switch_14
show_name: true
show_state: false
color_type: card
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.kuche_thermostat_switch_14
entity: switch.kuche_thermostat_switch_16
show_name: true
show_state: false
color_type: card
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.kuche_thermostat_switch_16
entity: switch.kuche_thermostat_switch_17
show_name: true
show_state: false
color_type: card
icon: mdi:timetable
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.kuche_thermostat_switch_17
entity: switch.kuche_thermostat_switch_13
show_name: true
show_state: false
color_type: card
styles:
name:
- font-size: 15px
action: service
service:
action: toggle
entity_id: switch.kuche_thermostat_switch_13
view_layout:
grid-area: Mmain33
- type: entities
entities:
- entity: number.kuche_thermostat_number_temperature_calibration_3
name: KĂźche Calibration
view_layout:
grid-area: Mmain333
EDIT: The above code uses, both old and new syntax, starts using old code after âwohnzimmerâ, yet all buttons work.
and yet, that old syntax is using the incorrect service for the domain. Even if it works, why would you use that? just fix it and be sure any other issues are not caused by that.
it is rather remarkable though, because this:
service:
action: toggle
entity_id:
was only introduced 2 days ago in the still beta 4 version⌠up to that version, youâd need service_data
for the service call
btw, please dont post these huge code blocks, as no-one will check your complete config. If you want to focus on a specific detail, please post that onlyâŚ
I will in time update everything, donât really want to go into this again. Took me from 18th of July until today to fix my own stuff, I really want to avoid that in the future.
custom:button-card
got some well required
A lot of new shiny features and support for the latest home assistant features (requires HA >= 2023.7):
- translations do work again
- a lot of template helpers
- support for the new icons
- support for the new actions, including assist
- variables dependencies
- And many more
If you find any bug, please open a GH issue!
4.0.0 (2023-07-29)
BREAKING CHANGES
helpers: If you were using any of the beta before
4.0.0-dev14
. Please replace all the calls to helper functions withhelpers.xxx
for eg.helpers.relativeTime(entity.state)
orhelpers.localize(entity)
- hacs: Minimum required HA Version is now 2023.7
actions: Requires HA 2023.4 minimum. Support for the new action format (
target
is also be supported),service_data
should be renamed todata
(but it still works with the old format) - icons: This might break your card-mod setup
- this might break some of your color settings
Features
repeat_limit
forhold_action
(73c216f), closes #564 #555 - actions: Support for the new action (assist) and all the future ones (d9c17a4), closes #711 #685
custom_fields: Add
do_not_eval
to stop evaluating js templates in an embedded card (1638cf8) -
helpers: all template functions are now available through the
helpers
object (f22ed69) - icons: replace ha-icon with ha-state-icon to follow new HAâs icons per domain automatically (ab6a3f5)
templates: new
relativeTime
function to display a relative time in a template and update it automatically (965a3d7), closes #701 - templates: New date and time format helpers (9b4fb05)
- variables: A variable can depend on another variable based on their nameâs alphabetical order (8cddccb), closes #656
- Force the
numeric_precision
for states which are numbers (24d75c2) - new helper functions for date/time in templates (2b75993), closes #701
- Support for localization in templates (5de2dc9)
Bug Fixes
- *_action more-info entity as a template was not evaluated (02441b2), closes #734
group_expand
now works even if the entity is not agroup.xxx
(f192ded), closes #645 - Color are now aligned with HA > 2022.12 (685d55e), closes #635
- custom fields would sometime throw unsafeHTML errors (c67e1d5), closes #725
- ha-icon (if in custom_fields) size was weird (a448c8e)
- ha-state-icon CSS selector was wrong (a1bb39a)
- icon would be cut with card height defined (19f8393), closes #731
- localization fix (02dfab3), closes #685 #693
- lock icon was displaying over more-info dialog (bf075b0), closes #694
- lock would go out of the button (0b3e4d3)
- non string fiels would error with an unsafeHTML error (d65c347), closes #725
- numerical states would not follow HAâs format (72d7c41), closes #662
- optimize contrast color compute (35109c3)
- relativeTime didnât support to set the first letter uppercase (f8b9b09), closes #735
- Some cards with child cards wouldnât be clickable (9f21c58)
- text/icon contrast when using label-card (01e199b)
- variable which were objects were only evaluated once (e40bda9)
templates:
variables
wasundefined
if none where provided. (fad332b), closes #718 - tooltip would show over everything (1bc8f99)
color: main config
color
was broken (b93c996) - hacs: minimum HA version 2023.7 (db3b394)
templates: donât use the
numeric_precision
from the card config forlocalize
in js templates by default (2cc384f)
Thanks for giving button-card
some , much appreciated!
I mean, itâs THE most used and needed card in HA.
Guys, just a quick question, i grabbed code from someone, now since release 4.0.0 , all my icons are white, when an entity is turned on, how can i change it back to the real state icon? i us declutter card, here are values for on/off
Not sure what i need to change?
state:
- value: "on"
'[[variable]]': '[[spin]]'
styles:
card:
- --ha-card-background: '[[on_card_color]]'
- opacity: '[[opacity_on]]'
name:
- color: '[[on_name_color]]'
state:
- color: '[[on_state_color]]'
lock:
- color: var(--lock-color-on)
label:
- color: '[[on_label_color]]'
- value: "off"
'[[off_variable]]': '[[off_spin]]'
styles:
card:
- opacity: '[[opacity]]'
icon:
- color: '[[off_icon_color]]'
name:
- color: '[[off_name_color]]'
state:
- color: '[[off_state_color]]'
label:
- color: '[[off_label_color]]'
- font-size: '[[label_font_size]]'
- font-weight: '[[label_font_weight]]'
lock:
- color: var(--lock-color-off)
For my default, i have the icon on âautoâ
default:
# Button Options
- lock: false
- aspect_ratio: 1/1
- opacity: 0.4
- opacity_on: 1.0
- border-radius: 12px
# Icon Options
- color: auto
- size: 25%
- margin-right: 60px
- margin-left: 0px
- variable: spin
- spin: false
- off_variable: spin
- off_spin: false
Shouldnt the âautoâ option give the real color of the light?
Edit : NM, seems to be a bug in 4.0.0 release
