Wow, I never thought of passing 0 in as the brightness for light.turn_on
in order to turn it off! I learned something today.
I donāt know if this is of any use to anyone, but I wanted to share my lovelace setup with you guys. Why in this thread you might ask? Well because the majority of my lovelace setup consists of this mighty button-card (lets say almost 80% of my setup are these buttons?).
Anyways I hope you guys can make use of it.
Thread:
Repo:
Add a delay to the end of the script.
anyone else seeing this:
no idea which file it canāt find, they are all thereā¦in fact, im not using any files at all, only some mdi: icons and they are all showingā¦
Youāre not using the latest version (or you didnāt clear your cache). This is fixed in 1.9.0.
Thanks , thought I did both but will check again. no easy way of finding the version in the .js file?
Made me thinking : this couldnāt be caused by entities not being available? I ask because I have my Hue lights on the buttons, and they are logged āunavailableā regularlyā¦ (long story)
Also some simply are powered off, so they should show unavailable on the button (which they do btw)
Nope. However if you use custom updater, you should use the /customcards endpoint instead of /local for your card files to skip cache. See https://custom-components.github.io/custom_updater/How-it-works
And itās unrelated it entities that are unavailable.
cool, thanks, no worries: I simply always dl the file from https://raw.githubusercontent.com/custom-cards/button-card/master/dist/button-card.js and trust is is the latest
have custom updater installed, but didnāt yet change to the new endpoints, since I donāt like custom cards requiring extra system file settings in my setup. Since the card changed white a bit lately, Ill hit and hold till things have materialized. manual updating till that time for me.
good to know! thanks.
Good thing is I used your code and I just used the option you think is even better and that one works Thanks!
To make it perfect I am wondering if thereās a way to get this back as a status to this button card. Would be cool if I could get the status to switch between off / dim / on, where it now does off / on / on. If I could have different states there, then I can also use different styling for each, where I could make it greyscale when off, icon light up when dimmed and the full card light up when fully on.
color: auto
is what youāre looking for , the color of the icon color will change automatically based on the light brightness.
However for the state itās not possible (as a light is either on or off), youāll have to use label_template and display what you want based on the state of your light.
Something like:
show_label: true
show_state: false
label_template: >
if (entity.state == 'on' && entity.attributes.brightness && entity.attributes.brightness < 255) return "Dim";
if (entity.state == 'on') return "On";
return "Off";
Ok, so I understand I need to add conditional labels and use those instead of states, but that also means I cannot do something like below? (Mock-up in Excelā¦, will recreate later in HASS)
Sure you can, using state on top of it:
state:
- operator: template
value: >
return entity.state == 'on' && entity.attributes.brightness && entity.attributes.brightness < 255;
styles:
# Your Dim Styles
value: >
styles:
# Your On Styles
- operator: default
styles:
# Your Off Styles
Cool! Gonna try that immediately when I get home. Will show the results
Thatās what Iām currently doing but I noticed that there is a graphic for pressed events. I want to modify that graphic instead of adding or creating scripts with a delay at the end. Also, the delay in response on a cellphone is long enough that the on/off doesnāt register.
There is already feedback when the button is pressed (ripple effect), but because your background is really dark, you canāt see it. I would have to modify the color of the ripple effect based on the background color, or maybe use the color
as the feedback color for the ripple effect.
Is there a way for me to do it with CSS in the style section? If not, that could be a good enhancement. Nothing too pressing so donāt break your back on it. I can make a PR if thatās the route you want to go.
have a button with lock, not to accidentally switch the switch. Works just fine. When holding this, and the blue circle shows, no more-info window pops up though. It does on all the other buttons.
Is this a bug? or per design. it is a bit confusing tbh, to have the same user action have different response from the system. especially sinde the blue more-info circle shows as expected.?
thanks for having a look
Itās expected. lock, locks everything (even hold_action). The blue circle is just feedback about the fact that youāre holding down your mouse or your finger on the screen. When lock is true, youāll first have to tap on the button to unlock it, and then hold the button to have the hold_action
fire up.
Thereās no way to do that right now. Iāll have a look.
Did something change again?
- type: horizontal-stack
cards:
- type: conditional
conditions:
- entity: switch.watch_tv
state: 'on'
card:
type: custom:button-card
color_type: card
action: service
service:
domain: remote
action: send_command
entity_id: remote.harmony
device: 55198007
command: 'VolumeDown'
icon: mdi:volume-minus
color: rgb(75, 75, 77)
worked like a charm before, but now I am unable to click the button.
This stopped working a long time agoā¦ Please read the documentation on github.
It should be:
tap_action:
action: call-service
service: remote.send_command
service_data:
device: 55198007
