Never mind
Thanks!
Never mind
Thanks!
Here’s an example from my setup that starts a Watch TV activity on my Harmony Hub. I’m not entirely sure that’s what you’re looking for, but I hope it helps provide a little inspiration.
- type: 'custom:button-card'
icon: 'mdi:television'
color_type: card
show_name: false
entity: sensor.harmony_activity
styles:
card:
- background: 'rgba(255,255,255,0.45)'
- width: 55px
- height: 55px
- border-radius: 50%
icon:
- width: 35px
- color: '#303741'
state:
- value: "Watch TV"
styles:
icon:
- color: 'rgb(255,255,255)'
card:
- background: 'rgb(0,128,0)'
- operator: default
styles:
icon:
- color: '#303741'
tap_action:
action: call-service
service: remote.turn_on
service_data:
entity_id: remote.harmony_hub
activity: "Watch TV"
@petro, I’ve found a way to change the ripple effect color, I’ll add this in the next release.
awesome, that will be great.
Quick question while I am busy with my layout: can you set like a horizontal stack with 2 columns where the left column is 60% of the screen and the right one 40%? I don’t see that option now, but it would be cool if I could do that.
The reason I’m looking for this is because I want 5 cards next to each other, but a header above the first 3, and then a second header on the last 2 cards.
Check out layout-card. It does exactly what you seek.
Edit: NVM. I went back to the button-card github page and found an example in the documentation. I swear, sometimes CSS+YAML makes my head spin.
You can show me how it looks in practice.
Or… You can also test it yourself on your setup and see the result
so I tried to change my anchors to button_card_template.
custom_button_switch: &custom_button_switch
label_template: >
var id = entity.entity_id.split('.')[1].slice(3, -9);
return states['sensor.' + id + '_actueel'].state + ' Watt';
color: auto
show_state: true
show_label: true
tap_action:
action: toggle
haptic: light
hold_action:
action: more-info
haptic: success
styles:
card:
- border-radius: 12px
- width: 105px
- height: 105px
- --paper-card-background-color: rgb(255, 251, 239)
name:
- justify-self: start
- padding-left: 3px
- font-weight: bold
- font-family: Helvetica
- font-size: 13px
label:
- color: gray
- font-size: 11px
- padding: 0px 10px
- padding-left: 3px
state:
- font-size: 11px
- padding: 0px 10px
- text-transform: capitalize
- font-weight: bold
- padding-left: 3px
grid:
- grid-template-areas: '"i" "n" "s" "l"'
- grid-template-columns: 1fr
- grid-template-rows: 1fr min-content min-content
img_cell:
- align-self: center
- text-align: start
- margin-left: 10px
and
- <<: *custom_button_switch
entity: switch.sw_audio_auditorium_template
lock: true
state:
- value: 'on'
icon: 'mdi:music'
# spin: true (uncomment this line for spinning icon)
styles:
name:
- color: black
state:
- color: gray
label:
- color: red
- value: 'off'
icon: 'mdi:music-off'
style:
- opacity: 0.6
styles:
label:
- color: rgba(0, 0, 0, 0.0)
icon:
- color: grey
name:
- color: grey
state:
- color: grey
- value: 'unavailable'
style:
- opacity: 0.4
- color: grey
- --paper-item-icon-color: grey
styles:
label:
showing:
to
button_card_template:
switch:
label_template: >
color: auto
show_state: true
show_label: true
tap_action:
action: toggle
haptic: light
hold_action:
action: more-info
haptic: success
styles:
card:
- width: 105px
- height: 105px
name:
- padding-left: 3px
- font-weight: bold
- font-size: 13px
label:
- color: gray
- font-size: 11px
- padding: 0px 10px
- padding-left: 3px
state:
- font-size: 11px
- padding: 0px 10px
- font-weight: bold
- padding-left: 3px
grid:
img_cell:
- text-align: start
- margin-left: 10px
and
type: horizontal-stack
cards:
- type: custom:button-card
template: switch
entity: switch.sw_multi_purpose_template
state:
- value: 'on'
icon: 'mdi:toggle-switch'
styles:
name:
- color: black
state:
- color: gray
- value: 'off'
icon: 'mdi:toggle-switch-off'
style:
- opacity: 0.6
styles:
label:
icon:
- color: black
name:
- color: black
state:
- color: black
style:
- opacity: 0.4
- color: grey
styles:
label:
showing:
what am I doing wrong here, please have a look?
@Mariusthvdb, it’s button_card_templates
with a s
at the end
Thanks, this one looks to work only with the actual cards itself, but not inside of a card. I am looking to create below example, but then in 1 or multiple vertical stacked cards. This way I can optimize the screen on phones etc. where I wouldn’t be able to fit for example “Creative Room” and “Bedroom” next to each other when using the automatic setup. I can get the 5 buttons next to each other, but then the headers are not aligned with the buttons.
To make it really agnostic, I’d add an arbitrary attribute to the entity and use the attribute value in the template:
homeassistant:
customize:
light.xxxx:
name_it_like_you_want: sensor.xxxx`
And then your entity light.xxxx
will have an attribute name_it_like_you_want
with the value
I’m using quite this trick quite often.
Each room should be:
I must be missing something really obvious here, but in the docs its says to put your templetes “In ui-lovelace.yaml
(or in another file using !import
What is and how do you use !import
I have my lovelace config split and use !include
for each view and also for my compact custom header config.
I’d like to put all my button templates in a separate file too. What obvious thing have I missed/do I not know about?
Is the below screenshot the expected outcome of the following card config? The card is significantly taller than 2px.
button_card_templates:
horizontal-blank-gap:
styles:
card:
- height: 2px
template: horizontal-blank-gap
Thanks for this card, great functionality and versatility. Many of us are making remotes so here is one someone can use as a starting point. This one is for Kodi and uses all native methods, so no scripts/automations needed.
Image example:
Template:
remote_button_normal:
styles:
icon:
- color: var(--primary-color)
card:
- border-radius: 0px
- opacity: 0.5
remote_button_round:
template: remote_button_normal
styles:
card:
- border-radius: 15px
Remote stack:
cards:
- cards:
tap_action:
service: media_player.kodi_call_method
service_data:
method: Input.ContextMenu
entity_id: media_player.theater
template: remote_button_round
icon: 'mdi:menu-open'
hold_action:
service_data:
method: Input.Up
repeat: 100
icon: 'mdi:menu-up-outline'
tap_action:
service_data:
method: Input.Up
- icon: 'mdi:chevron-double-up'
hold_action:
service_data:
method: Input.ExecuteAction
action: pageup
repeat: 100
tap_action:
service_data:
action: pageup
- cards:
- icon: 'mdi:menu-left-outline'
tap_action:
service_data:
method: Input.Left
- icon: 'mdi:alpha-s-circle-outline'
tap_action:
service_data:
method: Input.Select
- icon: 'mdi:menu-right-outline'
tap_action:
service_data:
method: Input.Right
- cards:
- icon: 'mdi:backburger'
tap_action:
service_data:
method: Input.Back
- icon: 'mdi:menu-down-outline'
hold_action:
service_data:
method: Input.Down
repeat: 100
tap_action:
service_data:
method: Input.Down
- icon: 'mdi:chevron-double-down'
hold_action:
service_data:
action: pagedown
repeat: 100
tap_action:
service_data:
action: pagedown
- cards:
- icon: 'mdi:chevron-double-left'
tap_action:
service_data:
action: stepback
- icon: 'mdi:pause'
tap_action:
service_data:
action: playpause
- icon: 'mdi:chevron-double-right'
tap_action:
service_data:
action: stepforward
- cards:
- icon: 'mdi:layers-outline'
tap_action:
service_data:
action: fullscreen
- icon: 'mdi:cctv'
tap_action:
service_data:
method: Input.ShowPlayerProcessInfo
- icon: 'mdi:information-outline'
tap_action:
service_data:
method: Input.ShowOSD
type: vertical-stack
You’re right, it’s a documentation error, it’s !include
Add: color_type: blank-card
Ok, I’m definitely missing something. I cannot find a way to have the button card templates in a separate file.
However I do the spacing it either ignores the template or fails entirely and gives the big red box.
I’d like to have all my button templates in one file and then !include
it in ui-lovelace.yaml
so that it is available for every view which is itself a separate file with an !include
(I have a feeling this might be something that @Mariusthvdb has done? Or @petro if he is not sticking with his anchors?)
I did that and it works:
!include file.yaml
And then in file.yaml:
template1:
[stuff]
template2:
[stuff]
And I also have separate files for each view.
