Lovelace: Button card
It’s actually two custom cards nested inside a horizontal stack which is then nested inside a vertical-stack-in-card.
  • Vertical-stack-in-card is used to eliminate the gaps between cards.
  • Horizontal stack is used to place the two buttons on the same line.
  • Custom:button-card is used for the left side of the button (a.k.a. “big icon”). The templating features are used to round the left side corners and apply styling.
  • Slider-entity-row is used in full_row mode for the right side of the button. Card modder is used on Slider-entity-row to apply the same styling from the custom:button-card templates.
Although it took me quite a while to fine tune, the actual config is fairly simple. Here’s the code. You should be able to copy/paste with minor adjustments to the entity and name fields.
Button-card Templates
button_card_templates:
  vertical-divider-grey:
    color_type: blank-card
    styles:
      card:
        - width: 3px
        - color: '#292929'
  horizontal-divider-grey:
    styles:
      card:
        - height: 3px
        - background-color: '#292929'
  dimmer-left-button-settings:
    template: left-button-settings
    icon: mdi:lightbulb
    styles:
      card:
        - width: 160px
Actual Button
- type: custom:vertical-stack-in-card
  cards:
    - type: horizontal-stack
      cards:
        - type: custom:button-card
          template: vertical-divider-grey
          template: dimmer-left-button-settings
          entity: light.kitchen_cabinets
        - type: custom:card-modder
          style:
            background-color: '#222222'
            border-radius: 0px 10px 10px 0px
            height: 39px
            padding: 8px
          card:
            type: custom:slider-entity-row
            step: 2
            full_row: true
      template: horizontal-divider-grey
Here’s some inspiration: https://github.com/custom-cards/button-card/blob/master/README.md#with-operator-on-state
Woops, I forgot that part :sweat_smile: I’ll add it for the next release
That was my first attempt before asking for help…
…nor could I…
That’s a relief! :wink:
Legend… Thanks very much.
I hate to ask (because you have already given so much) but…
…would it be possible to have templated tap_action, dbltap_action and hold_action?
:no_mouth:
What would be your use case?
As a general answer, I’d use the config-template-card for that, what do you think?
Actually, I think my case is even more complex than just wanting templated *_action.
I am using buttons to display motion, door and window sensors. I sometimes have door and window sensors in the wrong state (cheap sensors!) so I use a double tap to open a custom-popup-card which allows me to set that sensor’s state via an input_select.
I combined all these buttons to use one template but the motion sensors don’t need a dbltap_action.
I have also realised that motion, door, and window sensors also have different icons (of course!) so would need to template those as well which I don’t think is possible either???
Here is my template after combining Door and Window and before realising the icons were wrong!
EDIT: Also, yes I have still got to template my label properly…
#=== Door and Window Sensors
#=== If the button card ever allows templated tap_action
#=== this is the name_template...
#===    var sensor_name = entity.attributes.friendly_name;
#===    if (sensor_name.search('PIR') === 0) {
#===      return sensor_name.split('PIR ')[1];
#===    } else if (sensor_name.split(' ')[sensor_name.split(' ').length - 1] === 'Door') {
#===      var sensor_name = sensor_name.replace(' Door', '');
#===      return sensor_name;
#===    } else {
#===      var sensor_name = sensor_name.replace(' Window', '');
#===      var sensor_name = sensor_name.replace('Left', '(L)');
#===      var sensor_name = sensor_name.replace('Centre', '(C)');
#===      var sensor_name = sensor_name.replace('Right', '(R)');
door_and_window_sensors:
  name_template: >
      return sensor_name;
    } else {
      return sensor_name;
  show_label: true
  label_template: >
    return entity.state === 'on' ? '-MOVEMENT-' : ''
  layout: icon_label
  aspect_ratio: 2.5/1
  state:
    - value: "on"
      icon: mdi:run
      styles:
        card:
          - box-shadow: 0px 0px 8px 2px var(--secondary-text-color)
        icon:
          - color: var(--secondary-text-color)
    - value: "off"
      icon: mdi:human-handsdown #mdi:walk
  styles:
#    card:
#      - width: 110px
    name:
      - font-size: 12px
    label:
      - font-size: 12px
      - font-weight: bold
      - justify-self: start
  tap_action:
    action: none
  hold_action:
    action: none
  dbltap_action:
    action: more-info
Why not just declare a generic template for your generic settings and declare specific templates for windows or doors that inherit your generic template and set your actions?
Something like this:
generic_sensors:
  name_template: >
      return sensor_name;
    } else {
      return sensor_name;
  show_label: true
  label_template: >
    return entity.state === 'on' ? '-MOVEMENT-' : ''  ## Maybe this has to be specific for motion only, if so move it in the motion one
  layout: icon_label
  aspect_ratio: 2.5/1
  styles:
#    card:
#      - width: 110px
    name:
      - font-size: 12px
    label:
      - font-size: 12px
      - font-weight: bold
  state:
    - value: "on"
      styles:
        card:
        icon:
  tap_action:
    action: none
  hold_action:
    action: none
window_sensors:
  template: generic_sensors
  dbltap_action:
    action: more-info
  state:
    - id: sensor_on
      icon: mdi:window-open
    - value: "off"
      icon: mdi:window-closed
door_sensors:
  dbltap_action:
    action: more-info
  state:
    - id: sensor_on
      icon: mdi:door-open
    - value: "off"
      icon: mdi:door-closed
motion_sensors:
  state:
    - id: sensor_on
      icon: mdi:run
    - value: "off"
And then use the appropriate template in each type of sensor you want to display:
  • motion_sensors
  • windows_sensors
  • door_sensors
The trick here is that you can inherit template from a template and overload/add anything.
Brilliant!
Thanks…
EDIT: That all worked perfectly, Thanks again. The more I use this card the better it gets!!
And in case anyone is interested in how it looks…
nice!
of course you need to show us the code that creates all of this now…
Oh, ok.
Just for you :wink:
Templates
#=== Motion, Door and Window Sensors Header
motion_door_and_window_sensors_header:
  show_name: false
  show_label: true
  show_icon: false
  layout: icon_label
  label_template: >
    var i;
    var entities = entity.attributes.entity_id;
    var count = 0;
    var entity_type = entity.attributes.friendly_name.split(' ')[1];
    for (i = 0; i < entities.length; i++) {
      var state = states[entities[i]].state;
      if (state === 'on') {
        count += 1;
    if (entity_type === 'PIR') {
      var label_prefix = '-- Motion';
      var label_sufix = ' Detected --';
    } else if (entity_type === 'Door') {
      var label_prefix = '-- Doors';
      var label_sufix = ' are Open --';
    } else {
      var label_prefix = '-- Windows';
    return label_prefix + (count.toString() > 0 ? label_sufix : ' --');
  styles:
    card:
      - background-color: var(--paper-card-background-color) #"rgba(0, 0, 0, 0.0)"
    label:
      - padding-left: 24px
      - font-size: 24px
      - color: var(--primary-text-color)
    grid:
      - grid-template-areas: '"l"'
      - grid-template-columns: 1fr
# Motion sensors
motion_sensors:
  template: generic_motion_door_and_window_sensors
  state:
    - id: sensor_on
      icon: mdi:run
    - value: "off"
# Door sensors
door_sensors:
  dbltap_action:
    action: more-info
  state:
    - id: sensor_on
      icon: mdi:door-open
    - value: "off"
# Window sensors
window_sensors:
  dbltap_action:
    action: more-info
  state:
    - id: sensor_on
    - value: "off"
#=== Generic Motion, Door and Window Sensors
generic_motion_door_and_window_sensors:
  name_template: >
      return sensor_name;
    } else {
      return sensor_name;
  show_label: true
  label_template: >
      return entity.state === 'on' ? '-MOTION-' : '';
    } else {
      return entity.state === 'on' ? '-OPEN-' : '';
  layout: icon_label
  aspect_ratio: 2.5/1
  state:
    - value: "on"
#      icon: mdi:run
      styles:
        card:
        icon:
#    - value: "off"
#      icon: mdi:human-handsdown #mdi:walk
  styles:
#    card:
#      - width: 110px
    name:
      - font-size: 12px
    label:
      - font-size: 12px
      - font-weight: bold
  tap_action:
    action: none
  hold_action:
    action: none
  dbltap_action:
    action: more-info
Button Cards
  #=== Motion, Door And Window Sensors
  - type: vertical-stack
    cards:
      #=== Motion
      - type: "custom:button-card"
        entity: group.all_pir_sensors
        template: motion_door_and_window_sensors_header
        cards:
#          - type: "custom:button-card"
#            color_type: blank-card
            entity: binary_sensor.pir_hall
            template: motion_sensors
            entity: binary_sensor.pir_dining_room
            entity: binary_sensor.pir_kitchen
        cards:
            entity: binary_sensor.pir_sitting_room
            entity: binary_sensor.pir_pool_room
            entity: binary_sensor.pir_upstairs_hall
        styles:
          card:
            - height: 1px
      #=== Doors
        entity: group.all_door_sensors
        cards:
            entity: binary_sensor.front_door
            template: door_sensors
            state:
              - value: "on"
                icon: mdi:door-open
              - value: "off"
            entity: binary_sensor.back_door
            state:
              - value: "on"
                icon: mdi:door-open
              - value: "off"
            entity: binary_sensor.side_door
            state:
              - value: "on"
                icon: mdi:door-open
              - value: "off"
        cards:
            entity: binary_sensor.patio_door
            state:
              - value: "on"
                icon: mdi:door-open
              - value: "off"
            entity: binary_sensor.shed_door
            state:
              - value: "on"
                icon: mdi:door-open
              - value: "off"
        styles:
          card:
            - height: 1px
      #=== Windows
        entity: group.all_window_sensors
        cards:
            entity: binary_sensor.pool_room_left_window
            template: window_sensors
            entity: binary_sensor.pool_room_centre_window
            entity: binary_sensor.pool_room_right_window
            entity: binary_sensor.kitchen_window
        cards:
            entity: binary_sensor.dining_room_left_window
            entity: binary_sensor.dining_room_right_window
            entity: binary_sensor.shower_room_window
            entity: binary_sensor.bathroom_window
        styles:
          card:
            - height: 20px
Some publicity for another card I’ve just created :blush:
It’s a small card that helps you declutter your Lovelace config by using templates for block of cards or a simple card. Changing the template will change it everywhere where its used.
This will be helpful for those of you who embed many cards in a vertical-stack-in-card for example with only small differences like the entity.
I’m thinking about you @petro, @daphatty or @jimz011 :wink:
ok, so have many buttons and switches using the same body.
in fact they only differ in label( template).
Ive succesfully made a template for those:
ikea_label:
  label_template: >
    function capitalizeFirstLetter(string) {
    return string.charAt(0).toUpperCase() + string.slice(1).toLowerCase();
    var id = entity.entity_id.split('.')[1].slice(11);
    return capitalizeFirstLetter(id);
switch_label:
  label_template: >
    var id = entity.entity_id.split('.')[1].slice(3, -9);
    return states['sensor.' + id + '_actueel'].state + ' Watt';
and use this in the templates for button_switch and button_switch_ikea.
Since these have the rest of the switch (body) in common, i thought Id make a template: button_body and use these with the label templates as follows:
button_switch_ikea:
  template: ikea_label
and then in the entity config use that compound template
    template: button_switch_ikea
    entity: switch.sub_woofer_outlet
    state:
      - value: 'on'
        icon: 'mdi:speaker-wireless'
      - value: 'off'
        icon: 'mdi:speaker-off'
this doesn’t work unfortunately and only the button_body is taken into account…
I’ve also tried to use the entry config as follows
    state:
      - value: 'on'
      - value: 'off'
but this has the same effect in the frontend.
Why won’t this work?
You can only define one template, not multiple.
You have to think of templates as a chain. You start from your button-card config and you go all the way up to the last template defined. The chain can be as long as you want.
So what you want to achieve is possible but it has to be done like this:
main_template:
  [all your common config here]
ikea_label:
  template: main_template # this will inherit the things from main_template
  label_template: >
switch_label:
  label_template: >
And then you use only:
switch_label or ikea_label for your buttons
ok thanks. Will test. cool.
A bit complex it is though, and error prone.
wouldn’t you consider easing up on that, and adding the option for more than 1 template? seems the obvious way to unclutter (pun intended).
A bit like anchors really.
Hope you would have a look.
I won’t implement that sorry as it’s already possible with the solution above. It’s not meant to replicate yaml anchors (which I don’t like) :slight_smile:
I will do so, but can only share it next weekend as I’m currently on a trip. Remind me if I forget :slight_smile:
I, too, am looking forward to your post. I’ve spent the last several hours attempting to replicate your awesome layout and cannot coax layout-card to behave properly. Enjoy your trip!
Hello guys, another rookie here.
I’ve got this set up and kinda working but I’m also suspecting im doing something wrong.
Pretty much everything i configure works. But I cant seem to get “state” to change color or icon of the entity inside the custom button card.
Im doing my editing inside the “RAW config editor” within the lovelace UI, is this somehow wrong?
Also, do i need anything else to get this to work? Custom UI maybe?
