Lovelace: Button card
:+1: Nice card.
In my case, there are no ā€˜templowā€™ entries for the forecast. What was your configuration entry for Darksky?
08%20PM
Name is shown as 73Ā°F - 73Ā°F / undefinedĀ°F
{'datetime': '2019-06-23T19:00:00', 'temperature': 73, 'precipitation': None, 'condition': 'cloudy'}
Iā€™m guessing youā€™re using the sensor and not the weather integration found here
I am using Darksky weather integration. :thinking:
weather:
  - platform: darksky
    api_key: !secret darkskyapi
Ah, I see. I thought you were showing the full attributes, but thatā€™s just one forecast item. :man_shrugging: this is mine:
      "datetime": "2019-06-23T00:00:00",
      "temperature": 73,
      "templow": 58,
      "precipitation": 0.7,
      "wind_speed": 6.67,
      "wind_bearing": 232,
      "condition": "rainy"
Why does yours have an hour? Are you doing an hourly forecast?
Here is my darksky sensor. I am not doing an hourly forecast.
  - platform: darksky
    forecast:
      - 0
      - 1
    monitored_conditions:
      - summary
      - icon
      - temperature
      - minutely_summary
      - daily_summary
      - temperature_high
      - temperature_low
      - apparent_temperature
      - hourly_summary
      - precip_type
      - precip_intensity
      - cloud_cover
      - nearest_storm_distance
      - wind_bearing
      - wind_speed
      - humidity
      - pressure
      - precip_probability
    scan_interval:
      minutes: 5
HI,
Ive tried this, but when I use the multiline notation, the droplet wonā€™t show and simply returns the code on the buttonā€¦
name_template: >
  return states['weather.home_darksky'].attributes.temperature + 'Ā°C - ' +
         states['weather.home_darksky'].attributes.forecast[0].temperature + 'Ā°C / ' +
         states['weather.home_darksky'].attributes.forecast[0].templow + 'Ā°C'
label_template: >
  return '\U0001F4A7 ' + (states['weather.home_darksky'].attributes.forecast[0].precipitation || 0) + ' mm';
46
Isnā€™t this accepted in the button-card?
Secondly, do you really get the more-info response? If I click the button nothing happens at all.
Is there any way to localize the state in entity.state?
I tried using this.hass.localize(entity.state) aswell as hass.localize(entity.state) to no avail
Try copying this :droplet: or from here
Yes, more-info works
Are you trying to do that in a template? I havenā€™t tested this, but try the following with your entity:
this.hass.localize(states[entity].state)
I just reread the docs, what you have should have worked if it was going to work. I havenā€™t look much at the template support before today :man_shrugging:
The localize function doesnā€™t take a state string as an argument, it takes:
  • For binary_sensor
    state.${entity.entity_id.split('.')[0]}.${entity.attributes.device_class}.${entity.state}
  • For everything else:
    state.${entity.entity_id.split('.')[0]}.default.${entity.state}
so for your template:
hass.localize(`state.${entity.entity_id.split('.')[0]}.${entity.attributes.device_class}.${entity.state}`)
Hey folks,
Iā€™m thinking about introducing 2 new features:
  • Templating for all the fields: this would deprecate *_template, but Iā€™d introduce [[ javascript_code ]] for all the field
  • Adding support for as many extra fields as you want, on top of name, label and state, and youā€™d be able to add them to button by playing with the grid style.
What do you think?
needless to say: +1!
please doā€¦
at least, or maybe begin, adding templates for icon: :wink:
@iantrich Indeed, in a template.
@RomRider Ahh i see. Using your example i was able to create this monstrosity by playing with the grid
What i have done is i put the label in the upper right corner and made a multiline name_template using several divs
    styles:
      grid:
        - grid-template-areas: '"i l" "n n"'
        - grid-template-columns: 1fr 1fr
        - grid-template-rows: 1fr min-content
    name_template: >
      var state = hass.localize(`state.${entity.entity_id.split('.')[0]}.${entity.state}`);
      return '<div>AC</div>' +
             '<div style="font-size: 11px;">' + (state ? state : entity.state ) + '</div>' +
             '<div style="font-weight: normal; font-size: 10px;">' + states['sensor.ac_power'].state + ' kW</div>';
This sounds like a great idea. It would make my previous example a lot easier
At the moment I use anchors to define a green and red state that can be used within either the on or off state of a button, depending on requirements:
anchors:
  custom_button_state_red: &custom_button_state_red
    color: rgb(71,39,45) #Red
    styles:
      label:
        - color: rgb(220,69,121)
      icon:
  custom_button_state_green: &custom_button_state_green
    color: rgb(49,68,42) #Green
    styles:
      label:
        - color: rgb(134,219,85)
      icon:
button_card_templates:
  security:
    color_type: card
    show_name: true
    show_icon: true
    show_last_changed: true
    tap_action:
      action: more-info
    styles:
      label:
        - font-size: 10px
      card:
        - border-radius: 10px
      name:
        - font-size: 15px
      grid:
        - grid-template-areas: '"i n" "i l"'
        - grid-template-columns: min-content min-content
        - grid-template-rows: auto auto auto auto
        - width: min-content
        - grid-gap: 0px 2px
  security_windows:
    template: security
    state:
      - value: "on"
        icon: mdi:window-open
        <<: *custom_button_state_red
      - value: "off"
        icon: mdi:window-closed
        <<: *custom_button_state_green
  security_camswitch:
    template: security
    tap_action:
      action: toggle
    state:
      - value: "on"
        icon: mdi:power-plug
      - value: "off"
        icon: mdi:power-plug-off
Is there a way to do the same thing with Configuration Templates so that I can ditch anchors? I canā€™t see a way to do this using the cascading nature of template, nor can I figure out if or how ID would work in this instance?
If anchors are the best way to do this (I prefer having a single place to change all colours), Iā€™m happy to leave things as they are.
Hi Iā€™m trying format time as ā€œXX agoā€ with templates as your screenshot but it shows long timestamp:
1
This shows long format:
name_template: >-
  return entity.last_changed
This shows empty line:
name_template: >
  return entity.state.substr(0, entity.state.length-11)
Please advice
Tried with show_last_changed it works but it overrides label, possible to have it all? label, name and last changed
sure, this is my button:
      - type: custom:button-card
        template: horizontal-filler
        template: button_motion
        entity: binary_sensor.laundry_motion_sensor
        tap_action:
          action: call-service
          service: switch.toggle
          service_data:
            entity_id: switch.laundry_motion_sensor_switch
using this template button_motion:
button_motion:
  template: button_body
  tap_action:
    action: more-info
    haptic: light
  hold_action:
    action: more-info
    haptic: success
#  styles:
#    name:
#      - text-overflow: unset
#      - white-space: unset
#      - word-break: break-word
#      - box-shadow: 0px 0px 2px 1px
  state:
    - value: 'on'
      styles:
        card:
          - color: red
        name:
          - color: black
        icon:
          - color: red
    - operator: template
      value: >
        return entity.attributes.on === true
      styles:
        card:
          - color: '#555B65'
        icon:
          - color: 'green'
        state:
          - color: 'green'
    - operator: default
      styles:
        card:
          - color: '#555B65'
          - opacity: 0.8
        icon:
          - color: '#555B65'
using this button_body:
button_body:
  color: auto
  aspect_ratio: 1/1
  show_state: true
  show_label: true
  styles:
    icon:
      - color: var(--local-color)
    lock:
      - color: red
    card:
      - border-radius: 6px
      - background-color: ivory
      - padding-left: 5px
    name:
      - text-align: start
      - justify-self: start
      - font-weight: bold
      - font-family: Helvetica
      - font-size: 13px
    label:
      - text-align: start
      - font-size: 11px
    state:
      - text-align: start
      - font-size: 11px
      - text-transform: capitalize
      - font-weight: bold
    grid:
      - grid-template-areas: '"i" "n" "s" "l"'
      - grid-template-rows: 1fr min-content min-content
    img_cell:
      - justify-content: start
      - align-items: start
Hi there,
Iā€™m using buttons to open and close shutters through service calls. I would like to set the icon color according to a MQTT payload so I can have different colors when the shutter is moving or stopped.
The code below calls a shutter close service but I have a fixed color on the buttons, I suppose I should add some template on a ā€œstates:ā€ section to then define the colors, but Iā€™m a bit confused about how to do that, as I havenā€™t yet completely understood templating.
                show_name: false
                entity: cover.janela
                icon: mdi:arrow-down
                tap_action:
                  service: cover.close_cover
                  service_data:
                    entity_id: cover.janela
Can someone offer any help?
Thank you.
Tales
If you have the states for moving/stopped available, you can, for example add something like this:
                    entity: script.cover_og_bad_open
                    icon: mdi:arrow-up-thick
                    show_name: false
                    tap_action:
                      service: cover.open_cover
                      service_data:
                        entity_id: cover.og_bad
                    styles:
                      card:
                        - background-color: rgba(0, 0, 0, 0.0)
                    state:
                        value: >
                          return states['cover.og_bad'].attributes.current_position == 100
                        color: var(--my-icon-off)
                      - value: 'on'
                        color: var(--my-green)
                      - operator: default
                        color: white
This is the open button of a cover.
It is grey (disabled), when the cover is fully open (100%), white (enabled) when under 100% and green when moving.
