Lovelace: Button card
The king is dead. Long live @RomRider
So Iā€™d like to change the ā€˜lockā€™ duration from 5 seconds to 1 or 2 seconds. I tried this but it doesnā€™t work:
              - type: custom:button-card
                entity: input_boolean.alarmgaragedoor
                icon: mdi:security
                color_type: icon
                lock: true
                styles:
                  lock:
                    - -webkit-animation-duration: 1s
                    - animation-duration: 1s
                    - -webkit-animation-fill-mode: both
                    - animation-fill-mode: both
                    - margin: unset
                state:
                  - value: 'off'
                    color: var(--paper-item-icon-color)       # rgb(54, 95, 140)
                  - value: 'on'
                    color: var(--secondary-text-color)        # rgb(251, 210, 41)
                show_state: false
                tap_action:
                  action: call-service
                  service: input_boolean.toggle
                  service_data:
                    entity_id: input_boolean.alarmgaragedoor
I just copied in the default style for lock and put it in what looked like the correct format but did I screw up?
Unfortunately that will not work, the lock is handled in javascript and the 5 seconds are hard-coded, itā€™s not an animation, itā€™s 2 animations + a delay between both.
If youā€™re interested in the code: https://github.com/custom-cards/button-card/blob/9ef93a2a350176d9d1e86adee9d86908ff13a270/src/button-card.ts#L776-L793
Well thatā€™s a pityā€¦
I just logged a Feature Request for this.
once again you were right. I forgot I have double setups for Lovelace and legacy. I meant to say the legacy tiles works correct. It uses this:
          - entity: device_tracker.life360_name
            style_template: >
              if (state === 'home' || state === 'not_home') return 'background-image: url(\"/local/tiles/family/name_' + state + '.png\")';
              return 'background-color: #643aac;background-image: url(\"/local/tiles/family/name_' + entities['sensor.name_location_picture'].state + '.png\")';
            more_info: group.name
and this jinja template sensor for state, since I couldnā€™t get my head around creating 1 template for all, had to make a dedicated image template for the non home/not_home states (zones):
        value_template: >
          {% set state = states('device_tracker.life360_name') %}
          {{ state|replace(' ','_')| lower }}
so jinja does it for all occurrencesā€¦ no javascript
pretty much every language but javascript does it for all occurrences. Javascript had to be that guy.
Hi there
Iā€™m struggling to make button_card_templates: work, can someone please shed some light? Gotta be something simple that I canā€™t see.
What is ui-lovelace-card.yaml? Never saw another reference to this file.
I built a view using the example on the documentation but that also donā€™t work:
title: Home
resources:
  - url: /local/button-card.js
    type: module
  header:
    styles:
      card:
        - padding: 5px 15px
        - background-color: var(--paper-item-icon-active-color)
      name:
        - text-transform: uppercase
        - color: var(--primary-background-color)
        - justify-self: start
        - font-weight: bold
      label:
        - font-weight: bold
  header_red:
    template: header
    styles:
      card:
        - background-color: '#FF0000'
  - title: "Test View"
    icon: mdi:wrench
    cards:
        template: header_red
        name: "My Test Header"
This is what is rendered:
Thanks for any hint.
Tales Maschio
That looks like a caching issue. Clear your cache or add ?v=12345 at the end of your resource URL to validate. Also verify that you are using the latest version.
Solved. Awesome, thank you!
Revamped my weather card a bit and itā€™s gotten pretty slick, albeit an awful looking configuration :slight_smile:
    layout: icon_label
    color: auto
    aspect_ratio: 1/1
    tap_action:
      action: more-info
      haptic: light
    show_state: false
    show_label: true
    styles:
      grid:
        - grid-template-rows: 42px auto 42px
        - grid-template-columns: 42px auto
      card:
        - border-radius: 15px
        - margin: 5px 5px 0px 0px
        - padding: 0px 0px
      icon:
        - height: 30px
        - width: 30px
      name:
        - padding: 0px 10px
        - font-size: 10px
      label:
        - padding: 7px
        - font-size: 11px
        - font-weight: bold
        - font-family: Helvetica
    entity: weather.dark_sky
    label_template: >
      var options = { hour: 'numeric', minute: 'numeric' };
      var sunrise_date = new Date(states['sun.sun'].attributes.next_rising);
      var sunrise_time = sunrise_date.toLocaleDateString("en-US", options).split(",")[1];
      var sunset_date = new Date(states['sun.sun'].attributes.next_setting);
      var sunset_time = sunset_date.toLocaleDateString("en-US", options).split(",")[1];
      return '<div align="left">' +
                '<div style="font-weight: normal; font-size: 10px; margin-top: 0px;">' +
                  '<ha-icon icon="mdi:weather-sunset-up" style="width: 12px; color: #f4e842; padding-bottom: 4px;"></ha-icon> ' +
                  sunrise_time +
                '</div>' +
                '<div style="font-weight: normal; font-size: 10px; margin-top: -10px;">' +
                  '<ha-icon icon="mdi:weather-sunset-down" style="width: 12px; color: #f4e842; padding-bottom: 4px;"></ha-icon> ' +
                  sunset_time +
                '</div>' +
              '</div>';
    name_template: >
      var degree = 45;
      var angle = entity.attributes.wind_bearing + 22.5;
      var direction = (angle >= 0 * degree && angle < 1 * degree) ? "N" :
        (angle >= 1 * degree && angle < 2 * degree) ? "NE" :
        (angle >= 2 * degree && angle < 3 * degree) ? "E" :
        (angle >= 3 * degree && angle < 4 * degree) ? "SE" :
        (angle >= 4 * degree && angle < 5 * degree) ? "S" :
        (angle >= 5 * degree && angle < 6 * degree) ? "W" :
        (angle >= 6 * degree && angle < 7 * degree) ? "NW" : "N";
      return '<div align="left" style="padding-top: 40px;">' +
              '<div style="font-size: 11px;">' + entity.attributes.temperature + 'Ā°F - ' + entity.attributes.forecast[0].temperature + 'Ā°F / ' + entity.attributes.forecast[0].templow + 'Ā°F</div>' +
              '<div style="font-weight: normal; font-size: 10px; margin-top: -5px;">' +
                '<ha-icon icon="mdi:water" style="width: 12px; color: #03a9f4; padding-bottom: 2px;"></ha-icon> ' +
                (entity.attributes.forecast[0].precipitation || 0) + ' in' +
              '</div>' +
                '<ha-icon icon="mdi:weather-windy" style="width: 12px; color: #03a9f4; padding-bottom: 2px;"></ha-icon> ' +
                direction + ' ' + (entity.attributes.wind_speed || 0) + ' mph ' +
              '</div>' +
                '<ha-icon icon="mdi:water-percent" style="width: 12px; color: #03a9f4; padding-bottom: 2px;"></ha-icon> ' +
                (entity.attributes.pressure || 0) + ' %' +
              '</div>' +
            '</div>';
    icon: mdi:weather-sunny
    state:
      - value: clear-night
        icon: mdi:weather-night
      - value: cloudy
        icon: mdi:weather-cloudy
        styles:
          card:
            - box-shadow: 0px 0px 10px 3px purple
          icon:
            - color: purple
      - value: overcast
        icon: mdi:weather-cloudy-arrow-right
        styles:
          card:
          icon:
            - color: purple
      - value: fog
        icon: mdi:weather-fog
        styles:
          card:
          icon:
            - color: purple
      - value: hail
        icon: mdi:weather-hail
        styles:
          card:
            - box-shadow: 0px 0px 10px 3px white
          icon:
            - color: white
      - value: lightning
        icon: mdi:weather-lightning
        styles:
          card:
            - box-shadow: 0px 0px 10px 3px #03a9f4
          icon:
            - color: #03a9f4
      - value: lightning-rainy
        icon: mdi:weather-lightning-rainy
        styles:
          card:
          icon:
            - color: #03a9f4
      - value: partlycloudy
        icon: mdi:weather-partlycloudy
      - value: pouring
        icon: mdi:weather-pouring
        styles:
          card:
          icon:
            - color: #03a9f4
      - value: rainy
        icon: mdi:weather-rainy
        styles:
          card:
          icon:
            - color: #03a9f4
      - value: snowy
        icon: mdi:weather-snowy
        styles:
          card:
          icon:
            - color: white
      - value: snowy-rainy
        icon: mdi:weather-snowy-rainy
        styles:
          card:
          icon:
            - color: white
      - value: sunny
        styles:
          card:
            - box-shadow: 0px 0px 10px 3px yellow
          icon:
            - color: yellow
      - value: windy
        icon: mdi:weather-windy
      - value: windy-variant
        icon: mdi:weather-windy-variant
amazing button,i love it,just one thingā€¦u have the attribute pression instead of humidity at name_templates.
congratulations to the creator of this card and all community that bring new ideas,im really very glad with this card in my configuration,thanks lot to all
Thanks for catching that :+1:
This looks pretty cool, I might use some of it to replace the simple-weather-card as I would love to use as less custom-cards as possible (this isnā€™t easy though).
The simple-weather-card was my starting point for it :wink:
HI
how can i add timer ( count down ) to button?
If you have a timer entity, you should just have to add it as the entity for the card
like that?
          - type: "custom:button-card"
            icon: mdi:air-filter
            color_type: icon
            color: 'var(--accent-color)'
            entities:
              - input_boolean.air_cleaner
              - timer.air_cleaner
            tap_action:
              action: toggle
            hold_action:
              action: more-info
Thereā€™s no entities config, just entity
So I thought Iā€™d try to recreate the old badges sensor icons we had from the old ui and this is small I can get it without looking crappy but on mobile is cuts them off. Is there a way to be able to scroll with my finger? or does anyone who has done this before have any tips?
You know badges still exist?
Anyways, to get a scrolling ā€˜rowā€™, you need to integrate a custom card that scrolls.
