Lovelace Card Mod w Conditional Color Formatting
I am trying to make some changes to a Ring Camera lovelace card that incorporates other entities with color based statuses at the bottom of the preview. I’ve gotten everything to work except the colors, and I can’t figure it out for the life of me.
type: grid
square: false
columns: 1
cards:
  - type: entities
    title: Entryway
    show_header_toggle: false
    state_color: true
    entities:
      - entity: siren.downstairs_siren
      - entity: sensor.aarlo_battery_level_newcastle_left_alley
        name: Arlo Left Alleyway Camera Battery
  - type: custom:mod-card
    card:
      type: picture-glance
      title: Front Doorbell Live Camera
      entities:
        - entity: binary_sensor.main_entrance_door
        - entity: lock.front_door_lock
        - entity: sensor.front_door_lock_battery
          card_mod:
            style: |
              :host {
                --icon-primary-color:
                  {% if states('sensor.front_door_lock_battery')|int >= 50 %} green
                  {% elif states('sensor.front_door_lock_battery')|int >= 25 %} orange
                  {% else %} red
                  {% endif %} !important;
              ha-icon {
                --mdc-icon-size: 24px;  # Adjust as necessary
                color: var(--icon-primary-color) !important;
              ha-icon {
      camera_image: camera.front_doorbell_live_camera
      camera_view: live
      show_state: true
      show_name: false
      aspect_ratio: 4x3
    card_mod:
      style: |
        ha-card .entities {
          justify-content: flex-end !important;  # Align entities to the right
          gap: 16px !important;  # Increase spacing between icons
          padding-right: 16px !important;  # Add more padding to the right
I have a battery that I want to change colors along with a lock status. I’ve gone into the HTML and noticed that there is a CSS style override called --icon-primary-color that basically makes all the entities white and guessed that’s what I need to change to control the color for what I want to do. Just working on the battery color at the moment but no matter what I do, I can’t get a value written conditionally to the icon-primary-color. I can hard code a color to it, but it obviously changes all icon colors. Using the HACS version of card-mod along with the front-end installation as recommended by the card-mod documentation as well, and can get colors to change if I don’t do conditional formatting, which makes me think it’s what I’m stuck on.
Any ideas on what I’m missing? Thanks!
checkout this guide for everything card_mod related.
but this should work.
    card:
      entities:
        - entity: sensor.garden_battery_2
      card_mod:
        style:
          div:nth-child(4):
            ha-icon-button ha-state-icon:
                ha-icon:
                    ha-svg-icon {
                      {% set battery = states('sensor.diner_battery') | int %}
                      {% if battery < 35 %}
                        color: red !important;
                      {% elif battery < 50 %}
                        color: orange !important;
                      {% elif battery < 70 %}
                        color: yellow !important;
                      {% else %}
                        color: green !important;
                      {% endif %}
What for this line is?
I just used his code, and updated the card_mod part. and reposted. :blush:
Thank you!!! I would have never figured this part out. So there are multiple entities that I’d like to color code. Could I just duplicate the card-mod code for each entity I want to color and use the ha-svg-icon template code you wrote?
just duplicate for each entity remembering to change which child your targeting
            div:nth-child(1):
                  ha-icon:
            div:nth-child(2):
                  ha-icon:
Thanks. This worked, sort of. I was able to get the color working for two icons on the card, but when I try to add it for a 3rd icon, the color seems to randomly apply to another icon I’m not trying to reference. See below (different card)
type: grid
square: false
columns: 1
cards:
  - type: entities
    title: Back Yard
    state_color: true
    entities:
      - entity: sensor.aarlo_battery_level_newcastle_right_side
        name: Arlo Right Side Fence Camera Battery
    card:
      title: Back Yard Live Camera
      camera_image: camera.back_yard_live_camera
      camera_view: live
      entities:
        - entity: binary_sensor.backyard_entry_door
          name: Rear Entry Door
        - entity: lock.back_door_lock
          name: Back Door Lock
        - entity: sensor.back_door_lock_battery
          name: Back Door Lock Battery
        - entity: light.back_yard_light
        - entity: switch.back_yard_siren
      card_mod:
        style:
          .box:
            display: flex;
            flex-direction: column;
            align-items: flex-end;
            position: absolute;
            bottom: 10px;
            right: 10px;
            gap: 10px;
          .box div:
            display: flex;
            align-items: center;
          .box div span:
            font-size: 12px; /* Small font size for descriptions */
            color: white; /* Adjust color as needed */
          div:nth-child(1):
                ha-icon:
                    ha-svg-icon {
                      {% if is_state('binary_sensor.backyard_entry_door', 'off') %}
                      {% else %}
                      {% endif %}
          div:nth-child(2) ha-icon-button ha-state-icon:
              ha-icon:
                  ha-svg-icon {
                    {% if is_state('lock.back_door_lock', 'locked') %}
                    {% else %}
                    {% endif %}
          div:nth-child(3) ha-icon-button ha-state-icon:
              ha-icon:
                  ha-svg-icon {
                    {% set battery = states('sensor.back_door_lock_battery') | int %}
                    {% else %}
                    {% endif %}
    card_mod:
      style: |
        ha-card .entities {
          justify-content: flex-end !important;  /* Align entities to the right */
          gap: 10px !important;  /* Increase spacing between icons */
          padding-right: 50px !important;  /* Add more padding to the right */
For example, if I pick (1) for the child, it colors the light instead of the backyard entry door. And no matter what child I pick, it never colors the back door lock battery. I’m also using some code here to put some text underneath the icons and space them out a bit but nothing is happening. Any ideas on either of these issues? Thanks again for your help getting me this far.
You are not separating the box divisions
for example…
card_mod:
  style:
    .box div:nth-child(3):
      div:nth-child(1):
            ha-icon:
                ha-svg-icon {
                  color: green;
      div:nth-child(2):
            ha-icon:
                ha-svg-icon {
                  color: red;
      div:nth-child(3):
            ha-icon:
                ha-svg-icon {
                  color: yellow;
      div:nth-child(4):
            ha-icon:
                ha-svg-icon {
                  color: blue;
Check out this specific post in @Ildar_Gabdullin guide…
that’s on me I completely overlooked the .box div
that @LiQuid_cOOled has provided above
Thanks to @Frosty and @LiQuid_cOOled for the tips. Got it working with the .box divisions. Thank you both so much. I hate to bother you, but I have one more issue…
I read through that link that was sent with all of the tips and tricks on the css styles, but I couldn’t find any place where it showed how to correct icon spacing. Also, tried adding the state text under the icon using the examples I found in the link, to no avail. I am using the experimental “sections” view, could that have anything to do with the state text not showing up under the icons? Oddly enough, I have 2 other cards where the state text is there, but somehow not on one.
type: grid
square: false
columns: 1
cards:
  - type: entities
    title: Back Yard
    state_color: true
    entities:
    card:
      camera_view: live
      entities:
          show state: true
          show state: true
          show state: true
      card_mod:
        style:
          .box div:nth-child(2):
            div:nth-child(1):
                  ha-icon:
                      ha-svg-icon {
                        {% else %}
                        {% endif %}
            div:nth-child(2):
                  ha-icon:
                      ha-svg-icon {
                        {% else %}
                        {% endif %}
            div:nth-child(3):
                  ha-icon:
                      ha-svg-icon {
                        {% else %}
                        {% endif %}
    card_mod:
      style: |
        ha-card {
          --mdc-icon-size: 23px;
         .box .row: |
            .wrapper .state {
              color: white;
It’s show_state: true not show state: true You are missing the underscore.
Thank you. Lots of little issues that just seem to evade me sometimes :man_facepalming: Appreciate the help! As soon as I get this icon spacing part figured out, my cards will finally be ready. Thanks again for all of your help!
Can you provide more detail on the icon spacing? Maybe a picture and the code. I should be able to assist.
Capture
If you can see the photo, I’d like to move the siren and light icons on the right side closer to the battery %, because they’re cut off on the HA mobile app. I’d also like to reduce the size, space and position of the “Back Yard Live Camera” text as it’s taking up too much space. It would also be cool if I could put the entity name above the colored icons and control their size so it lines up with the icons as well.
Code here:
type: grid
square: false
columns: 1
cards:
  - type: entities
    title: Back Yard
    state_color: true
    entities:
    card:
      camera_view: live
      entities:
          show_state: true
          show_state: true
          show_state: true
          show_state: true
          show_state: true
      card_mod:
        style:
            div:nth-child(1):
                  ha-icon:
                      ha-svg-icon {
                        {% else %}
                        {% endif %}
            div:nth-child(2):
                  ha-icon:
                      ha-svg-icon {
                        {% else %}
                        {% endif %}
            div:nth-child(3):
                  ha-icon:
                      ha-svg-icon {
                        {% else %}
                        {% endif %}
    card_mod:
      style: |
        ha-card {
         .box .row: |
            .wrapper .state {
              color: white;
We will have to incorporate the following code with yours to get both the icon and state to shift
.box div:nth-child(2) div:nth-child(4) {
           margin-left: -10px; }
     div:nth-child(5) {
Where do I put that code? Into the style section at the bottom, or part of the div:nth-child code above it?
I’ll have it in a few. Rewriting the card-mod code.
Test this
card_mod:
        style: |
          .box div:nth-child(2) div:nth-child(5) {
          .box div:nth-child(2) div:nth-of-type(1) ha-icon-button ha-state-icon {
            color: {{ 'red' if is_state('binary_sensor.backyard_entry_door', 'off') else 'green' }};}
          .box div:nth-child(2) div:nth-of-type(2) ha-icon-button ha-state-icon {
            color: {{ 'green' if is_state('lock.back_door_lock', 'locked') else 'red' }};}
          .box div:nth-child(2) div:nth-of-type(3) ha-icon-button ha-state-icon {
              {% set battery = states('sensor.back_door_lock_battery') | int(0) %}
                        {% else %}
                        {% endif %}
Tried it and it didn’t do anything. One thing I noticed is that the code text outlined in blue when I got it going. Tried changing the number of pixels it shifted and no change. Do I need to remove or change any of the code above the style section?
    card_mod:
      style: |
        ha-card {
             margin-left: -20px; }
                        {% else %}
                        {% endif %}
Place the ha-card code at the bottom
      card_mod:
        style: >
          { color: {{ 'red' if is_state('binary_sensor.backyard_entry_door',
          { color: {{ 'green' if is_state('lock.back_door_lock', 'locked') else
          'red' }};}
          { {% set battery = states('sensor.back_door_lock_battery') | int(0) %}
            {% else %}
            {% endif %}
          ha-card {
           --mdc-icon-size: 23px !important;
I have tested the code using my own entities/icons and it works
