Lovelace: Decluttering Card
Assume this is your “dashboards” file:
dashboards:
  lovelace-main:
    mode: yaml
    title: System
    icon: mdi:xxxxxxxxxxxx
    show_in_sidebar: true
    require_admin: false
    filename: lovelace/lovelace-system.yaml
  lovelace-climate:
    mode: yaml
    title: Climate
    filename: lovelace/lovelace-climate.yaml
And these are your files for each dashboard:
### lovelace/lovelace-system.yaml
  - !include views/system/view11.yaml
  - !include views/system/view12.yaml
  - !include views/system/view13.yaml
  - !include views/system/view14.yaml
### lovelace/lovelace-climate.yaml
  - !include views/climate/view21.yaml
  - !include views/climate/view22.yaml
  - !include views/climate/view23.yaml
  - !include views/climate/view24.yaml
Everything is inside this tree structure:
.storage
  |_ ...
  |_ ...
lovelace
  |_ views
  |    |_ climate
  |    |    |_ view11.yaml
  |    |    |_ view12.yaml
  |    |    |_ view13.yaml
  |    |    |_ view14.yaml
  |    |_ system
  |         |_ view21.yaml
  |         |_ view22.yaml
  |         |_ view23.yaml
  |         |_ view24.yaml
  |_ lovelace-climate.yaml
  |_ lovelace-system.yaml
configuration.yaml
Now add a new folder “decluttering-templates” for your templates and create any tree structure inside (like “these templates are for climate only”):
lovelace
  |_ decluttering-templates
  |     |_ common
  |     |     |_ template11.yaml
  |     |     |_ template12.yaml
  |     |     |_ template13.yaml
  |     |_ network
  |           |_ template21.yaml
  |           |_ template22.yaml
  |           |_ template23.yaml
  |_ views
        |_ ...
Each file may be 1 decluttering template:
my_template:
  default:
  card:
or several templates (like “a bit different representations of same card”):
my_template_1:
  default:
  card:
my_template_2:
  default:
  card:
And place this string into each file for each dashboard:
decluttering_templates: !include_dir_merge_named templates-decluttering/
Now ALL your dashboards are sharing same templates.
Note: splitting config described here.
Thanks you!
So I can import decluttering templates only if I use “mode: yaml”? I can’t import a decluttering template file if I use this mode?
In storage mode you only may use templates defined in a “raw yaml editor”.
If you have 3 dashboards in storage mode - then the same template you need to put into each “raw yaml editor”.
Ok, thank you so much for your help!
Hey guys, if I have '[[var]]' in the decluttering template, passing a string like '14' works fine (right card), but passing '{{states("sensor.buienradar_temperature_1d")}},' produces the JSON parse error in the left card.
Then I found that passing '{{states(''sensor.buienradar_temperature_1d'')}},' (i.e. with two single apostrophes '' around the sensor name instead of one double apostrophe ") does not return this error but works as expected.
So everything works for me now but just wanted to notify here and/or ask why this behavior occurs?
I also have another question. Why is this code not working? It just returns the jinjia template as string.
type: custom:decluttering-card
template: weather_now_template
variables:
  - secondary: >-
      {% set buienalarm = states(''sensor.buienalarm_precipitation'')|float %}
      {% set owm = states(''sensor.openweathermap_rain'')|float %}
      {% if (buienalarm + owm)/2 > 0 %}
      {{min([buienalarm, owm])|round(1)}} tot {{max([buienalarm, owm])|round(1)} mm/h
      {{states(''sensor.openweathermap_cloud_coverage'')}}% bewolkt
If I add newlines between each line in the template, I get a JSON parse error ‘unterminated string’.
so its not possible to use the same decluttering templates for multiple dashboards?
ups… I should read the whole comment. Thanks a lot for the explanation!
Edit: Sad that it’s not really worth to dive into this card, as everything seems to slow down if this card is used. Plus there have not been any updates for almost 3 years now…
It would declutter my code so much, but those are deal breakers imo
decluttering does not evaluate templates unfortunately. it only passes strings.
explain please? can not state the same experience on this side, using a rather extended frontend, and some serious decluttering going on.
Maybe you have another issue at hand?
now that is true. otoh, there have been no real issues to solve and it keeps doing its job nicely
I noticed this while using the tap_action: more-info popup. The popup is slowed down by a second if using decluttering card. That’s what scared me
Right, I see.
not using that myself, so I couldn’t respond to that really, but are you sure there’s nothing else in that card config that might cause the delay? The decluttering card really only ‘rewrites’ the yaml, and once that is loaded shouldn’t be any different than writing the card without it.
Note I say ‘shouldnt’… ofc there is always the exception to the rule :wink:
I only tested this with custom mushroom cards. But the delay is definitely not there if I use them regularly. Would you mind to test this on your environment?
sure.
paste you’re yaml here, and I can have a look
Thanks for the reply, that is too bad really. I wanted to show a mushroom card with a simple string on one lovelace page, but showing the template on another page. I guess there’s now way around this unless decluttering card gets an update?
I can confirm, I have a simple camera card with more-info popup which shows instantly, and multiple declutter cards in a stack-in-card (so different card, but same popup) where the popup shows with a slight delay. I’d say it’s almost unnoticeable (can’t be more than 0.3 seconds), but when compared to the popup of the camera card there is definitely a difference.
Have terrible experience with camera cards and especially the more info myself, but also without the decluttering card so that might be another issue. See this post
On the template , give us an idea in yaml what you would like and we can see.
Maybe it’s just taking it 1 step earlier in the yaml rebuild sequence
I guess I just found the issue. The delay is only happening if double_tap_action is defined in the card. if not it just pops up right away. That is great news as I can now use the decluttering card :smiley:
I don’t have a lovelace-ui.yaml, I guess because I only edit my lovelace from the UI itself. I added decluttering_templates: in the raw configuration editor, on the same level as views:, but the card I added says No card type configured. Anyone have any idea?
No code = no ideas (
Start of my raw lovelace config:
iron-overlay-backdrop-background-color: rgba(41,128,185,0.25)
swipe_nav:
  animate: swipe
  prevent_default: true
  swipe_amount: 30
  wrap: true
  my_first_template:
    default:
      - icon: fire
    card:
      type: custom:button-card
      icon: mdi:[[icon]]
  - theme: Backend-selected
    icon: mdi:home
    panel: false
    path: home
    title: Home
    visible:
etc.......
Test card:
  template: my_first_template
  variables:
    - name: Test Button
    - icon: arrow-up
This is the error I see if it helps any more:image
Is this a screenshot from UI editor?
Try to remove the leading “-“.
