Lovelace: Decluttering Card
Hi I´m trying to use this card but i dont know why this error show up.
Any suggest?
- template: my_first_template
  type: 'custom:decluttering-card'
  variables:
    - entity_1: sensor.watts
Good morning , after the core update the cards got black
header:
  card:
    content: |
      # [[content]]
    style:
        ha-card {
          --paper-card-background-color: none !important;
          box-shadow: none !important;
      ha-markdown:
          h1 {
            font-size: 20px;
            font-weight: bold;
            font-family: Helvetica;
            color: rgba(0, 0, 0, 0.6);
            letter-spacing: '-0.01em';
    type: markdown
Someone had same issue ?ù
thank
fixed adding this line
        background: var( --ha-card-background, rgba(241, 243, 249, 0) );
--paper-card-background-color is deprecated, it’s in the release notes of the 0.113 version. :wink:
Thanks so much , i totally missed it.
Now another issue is the popup card , they do not popup anymore…
Im trying to use the dcluttering card to simplify some of my YAML that contains but I am getting the following error message returned:
 'undefined is not an object (evaluating 'a.length)'
Not withstanding any daft mistakes with indent problems, I am wondering if the declutter card supports the custom mini-graph-card as everything works upto that point?
Any thoughts or help appreciated!
Heres the template:
  sensor_template:
    card:
      type: custom:vertical-stack-in-card
      title: '[[title_1]]'
      cards:
        - type: horizontal-stack
          cards:
            - type: custom:mini-graph-card
              entity: '[[entity_1]]'
              line_color: blue
              line_width: 8
              font_size: 75
              show:
                extrema: true
Heres how I call it:
      - type: custom:decluttering-card
        template: sensor_template
        variables:
          - title_1: Test Card
          - entity_1: sensor.lpmultisensor_6_1
Fixed it - my bad - had entity: ‘[[whatever]]’ instead of
entities:
  - '[[whatever]]'
Is there a way to use this in storage mode? I have one dashboard in yaml mode and the rest are created from the UI. Can this be used in the storage mode dashboards?
@daphatty can u share you yaml please?
Hi @RomRider
please help me out, Ive been trying to works this out using numerous variations but cant get it to work… no matter what I try, a string gets passed to my button, instead of a state (of a sensor with that string as entity_id…)
here’s what I use for decluttering template:
     cards:
       - type: custom:button-card
         template: button_meterget
         triggers_update: switch.[[id]]
         entity: script.[[id]]_meterget_power
         variables:
           sensor: sensor.[[id]]_actueel
         entity: script.[[id]]_meterget_usage
         variables:
           sensor: sensor.[[id]]_totaal
         entity: script.[[id]]_meterget_state
         variables:
           sensor: sensor.[[id]]_state
using this button-card template:
button_meterget:
  template: button_force_body
  show_label: true
      function capitalizeFirstLetter(string) {
      return string.charAt(0).toUpperCase() + string.slice(1).toLowerCase();
      var id = entity.entity_id.split('_').pop(-1);
      console.log(id);
      return capitalizeFirstLetter(id);
  icon: >
      var id = entity.entity_id.split('_meterget')[0].split('.')[1];
      return states['switch.' + id].attributes.icon;
  label: >
      return states[variables.sensor].state;
the main card config is this:
    template: force_switches
    variables:
      - id: tv_library
      - on-icon: wifi
      - off-icon: wifi-off
everything works, except the label…:
Ive also tried it without the variable for the ‘sensor’, but it made no difference.
Could you spot what I am doing wrong here…?
seems to have kicked in after all!
cool.
Question left for now: is it expected that I need to add the sensor to the triggering triggers_update: field
          triggers_update:
            - switch.[[id]]
            - sensor.[[id]]_actueel #<---- needs this to update on the button, while it is in the config below ?
          variables:
thanks for having a look!
also, when using the above d
Yes, because you define it in a variable, variables are just arbitrary strings/javascript templates so I can’t know what you put there.
I have this decluttering template that I use for 5 cards:
  sonos_master:
    default:
      font-size: 20px
    card:
      entity: binary_sensor.sonos_master_[[speaker]]
      tap_action:
        action: call-service
        service: input_select.select_option
        service_data:
          entity_id: input_select.sonos_master
          option: media_player.sonos_[[speaker]]
      styles:
        name:
          - font-size: '[[font-size]]'
      template: input_button_thick_name
      type: 'custom:button-card'
It incorporates this button card template:
  input_button_thick_name:
    color_type: card
    show_icon: false
    state:
      - value: 'on'
        styles:
          name:
            - color: var(--secondary-background-color)
    styles:
      card:
        - transform: scale(0.95)
        - background-size: 100% 100%
        - border-style: solid
        - border-width: 2px
        - border-color: var(--primary-color)
        - height: 60px
      name:
        - color: white
        - font-size: 20px
        - font-variant: small-caps
I want to use the same decluttering template for a 6th card but I need to incorporate some additional code (below) to lock the card and change a format. Is it worth trying to code this into a template or should I just bypass the decluttering template and use the raw code?
        lock:
          enabled: >
            [[[ return states['sensor.harmony_activity_living_room'].state === 'Watch Fire TV' || states['sensor.harmony_activity_living_room'].state === 'Watch Live TV' ]]]
          exemptions: []
        state:
          - operator: template
            styles:
              card:
                - border-color: var(--disabled-text-color)
              name:
                - color: var(--disabled-text-color)
            value: >
I have this working fine for YAML mode, but when I try to add it into the UI editor, I get this - any ideas?
If you are using the UI to configure a dashboard, you have to add the templates at the beginning in the raw editor of your dashboard. Templates are dashboard based.
Why not add a second template with that only to your button-card and set the templates as a decluttering variable? A variable in decluttering card can be a list :wink:
# Decluttering:
sonos_master:
  default:
    bt_templates:
      - input_button_thick_name
    font-size: 20px
  card:
    tap_action:
      service_data:
    styles:
      name:
    template: '[[bt_templates]]'
# Button-card
input_button_tick_name_lock:
  lock:
    enabled: >
    exemptions: []
  state:
      styles:
        card:
        name:
      value: >
And just add the 2 templates for that specific button through the decluttering bt_templates variable
Thank you! Didn’t realize I could do that. In my YAML dashboard, I had this config below - which has a ton of other templates in it. However, I get an error when I use the “!include” command in the raw config editor - is it not a valid option in the raw config editor? Googling it, I can’t find anyone else with the issue.
decluttering_templates:
   !include decluttering_templates/decluttering_templates.yaml
No you can’t include in the raw config editor. :confused:
Need some help with my setup.
A have an Entity card with ‘multiple-entity-row’.
Here is a part of this card:
Every row is describing a driving time from Place_X to Place_Y for a Person_Z (using a Yandex Maps platform, https://github.com/custom-components/sensor.yandex_maps).
The row contains:
  • name of person;
  • traffic jam’s rate;
  • an ‘mdi:car’ icon (green, yellow, red - depends on jam’s rate);
  • driving time;
  • a link to a route’s map.
Here is a code (just for 2 people and 1 place):
type: 'custom:config-template-card'
variables:
  - '''ildar'''
  - '''irina'''
  - 'states["sensor.yandex_time_home_" + vars[0]]'
  - 'states["sensor.yandex_time_home_" + vars[1]]'
entities:
  - '${vars[2].entity_id}'
  - '${vars[3].entity_id}'
card:
  type: entities
  entities:
    - type: 'custom:multiple-entity-row'
      entity: '${vars[2].entity_id}'
      entities:
        - entity: '${vars[2].entity_id}'
          attribute: jamsrate
          unit: ''
        - entity: sensor.test_empty_value
          unit: false
          icon: 'mdi:car'
          styles:
            '--paper-item-icon-color': >-
              ${ parseFloat(vars[2].attributes["jamsrate"]) <= 3 ? "green" :
              (parseFloat(vars[2].attributes["jamsrate"]) <= 6 ? "yellow" :
              "red") }
          unit: ''
          styles:
            width: 60px
            text-align: center
          unit: false
          icon: 'mdi:link'
          tap_action:
            action: url
            url_path: '${ vars[2].attributes["mapurl"] }'
          styles:
            '--paper-item-icon-color': cyan
      name: '${states["person." + vars[0]].attributes["friendly_name"]}'
      unit: ''
      icon: ''
      toggle: false
      show_state: false
      state_header: ''
      secondary_info: last-changed
      entity: '${vars[3].entity_id}'
      entities:
        - entity: '${vars[3].entity_id}'
          attribute: jamsrate
          unit: ''
          unit: false
          icon: 'mdi:car'
          styles:
              ${ parseFloat(vars[3].attributes["jamsrate"]) <= 3 ? "green" :
              (parseFloat(vars[3].attributes["jamsrate"]) <= 6 ? "yellow" :
              "red") }
          unit: ''
          styles:
            width: 60px
            text-align: center
          unit: false
          icon: 'mdi:link'
          tap_action:
            action: url
            url_path: '${ vars[3].attributes["mapurl"] }'
          styles:
      name: '${states["person." + vars[1]].attributes["friendly_name"]}'
      unit: ''
      icon: ''
      toggle: false
      show_state: false
      state_header: ''
Since I want to have this row for several routes and several persons, I need to repeat the same code for each case.
That is why I decided to use a decluttering card.
The template:
  decl_travel_time__person:
    card:
      entities:
        - '[[SENSOR_TRAVEL_TIME]]'
        - '[[SENSOR_PERSON]]'
      card:
        type: entities
        entities:
            entity: '[[SENSOR_TRAVEL_TIME]]'
            entities:
              - entity: '[[SENSOR_TRAVEL_TIME]]'
                attribute: jamsrate
                unit: ''
                unit: false
                icon: 'mdi:car'
                styles:
                    ${parseFloat(states['[[SENSOR_TRAVEL_TIME]]'].attributes["jamsrate"])
                    <= 3 ? "green" :
                    (parseFloat(states['[[SENSOR_TRAVEL_TIME]]'].attributes["jamsrate"])
                    <= 6 ? "yellow" : "red") }
                unit: ''
                styles:
                  width: 60px
                  text-align: center
                unit: false
                icon: 'mdi:link'
                tap_action:
                  action: url
                  url_path: '${states[''[[SENSOR_TRAVEL_TIME]]''].attributes["mapurl"]}'
                styles:
            unit: ''
            icon: ''
            toggle: false
            show_state: false
            state_header: ''
The card:
type: 'custom:stack-in-card'
title: ''
mode: vertical
cards:
  - type: 'custom:decluttering-card'
    template: decl_travel_time__person
    variables:
      - SENSOR_TRAVEL_TIME: sensor.yandex_time_home_ildar
      - SENSOR_PERSON: person.ildar
    variables:
      - SENSOR_TRAVEL_TIME: sensor.yandex_time_home_irina
      - SENSOR_PERSON: person.irina
How it is displayed:
First I got rid of box_shadow:
    card:
      entities:
      card:
        type: entities
        style: |
          ha-card {
            box-shadow: 0px 0px 0px 0px;
        entities:
But there is a bigger spacing between rows - let’s compare with an original setup:
Can anyone help me to make this spacing smaller - like a spacing between entities in the Entities card?
Update:
I found a thing which made me happy!
This magic decluttering-card can be used as an entity row - not only as a whole card!
In this case I can use something like this:
type: entities
title: ''
entities:
    variables:
    variables:
But for my particular case I will have to put this “entity rows” inside config-template-card - to use a templating feature.
First of all: thank you for an amazing HA card, just what I have always needed!
I’m facing a problem that I hope that someone with more YAML knowledge than me could help me with. I have this decluttering_template, with a couple of default values:
smart-light:
  default:
    - color1: '#000'
    - color2: '#222'
    - color3: '#444'
  element:
    type: image
    image: '[[image-url]]'
    entity: '[[entity]]'
    style:
      top: '[[top]]'
      left: '[[left]]'
      width: '[[width]]'
      height: auto
      background-color: |
        {% set temp = 'states['[[entity]]'].attributes.color_temp %}
        {% if temp <= 190 %}
          '[[color1]]'
        {% elif temp <= 227 %}
          '[[color2]]'
        {% elif temp <= 264 %}
          '[[color3]]'
        {% else %}
        'transparent'
        {% endif %}
    action: none
    tap_action:
      action: none
    hold_action:
      action: none
The background-color part of the style block is where my problem is. Have tried changing:
background-color: |
to:
background-color: |-
and
background-color: >
…but without luck. Unfortunately, the YAML is not strong with this one.
I’m a javascript developer myself and had this as a javascript function in my main full dashboard view at first, but since it’s being reused a lot I wanted to break it out.
I’m using Config Template Card to write JS in lovelace, but since the above code is an image element inside a picture elements card, I can’t use the config template card within my decluttering template, which was my inital idea.
Throwing this out here and hope that a YAML Yoda walks by and spot my obvious mistakes :slight_smile:
Thank you in advance!
// Jens.
Why do you have jinja2 in your card? This is just not possible.
Edit: This is with card-mod right?
Edit2:
This should work
      background-color: |
        {% set temp = states['[[entity]]'].attributes.color_temp %}
          '[[color1]]'
          '[[color2]]'
          '[[color3]]'
        {% else %}
        'transparent'
        {% endif %}
Hey, thanks for your reply!
The thing is, the structure of my files is this:
  • A dashboard with a yaml config for the view with the card-mod card containing a picture-element card.
  • An !include with the decluttering templates
  • Decluttering template called within an image element child of the picture element card
So, since I can’t use the config template with variables set within my decluttering template (since the picture element card only supports elements, not card), I need to write it with jinja2 (which I apparently wrongly referred to as YAML).
In your solution above, I don’t see a difference to my code which doesn’t seem to work? Or have I missed something?
