Ah, I see now that I had an extra ’ in there. Will try removing that.
@RomRider no luck unfortunately, the background-color property is omitted from the html output altogether, so it seems it doesn’t receive the default value or something. Looks like this atm:
<decluttering-card class="element" style="top: 53.3406%; left: 3.0976%; width: 78.7843%; height: auto;"></decluttering-card>
Does that work? Isn’t it supposed to be:
state_attr('[[entity]]', 'color_temp')
If you run your template in the template parser from the dev tools replacing just [[entity]]
with the real entity, does it work?
When running it in the template parser, I get the following back:
Result type: string
'[[color7]]'
So it seems to send it back, but it doesn’t pick up the default value as it seems
@RomRider When setting it as:
background-color: '#000000'
directly it seems to work, so I think the problem lies with the
background-color: |
Have tried the following four variants:
|, |-, >, >- without success
Got a question regarding card-mod.
I cannot use card-mod INSIDE a decluttering-card if the card represents entity row, like ‘multiple-entity-row’ or ‘hui-element + sensor-entity’.
Of course I would use decluttering-card with a simple entity row (like in “Entity card”) but it is not possible unfortunately.
For ‘multiple-entity-row’ or ‘hui-element + sensor-entity’ I can use card-mod - but inside a decluttering-card it stops working.
Example:
- With “:host” - doesn’t work:
decluttering_templates:
decl_test_entity_row:
card:
type: 'custom:multiple-entity-row'
entity: '[[SENSOR]]'
style: |
:host {
color: red !important;
- Tried a longer way - doesn’t work:
card:
style:
decluttering-card:
multiple-entity-row:
hui-generic-entity-row: |
.entities-row .state-entity {
Code:
The second one might work with:
card:
style:
Is it possible to add a list of entities into the decluttering card?
Would like to pass specific entities into the decluttering to make use in e.g. custom:auto-entities
This example gives me the error “Entities need to be an array”. Also tried to remove - before [[list]] but that results in broken yaml format.
example:
list_of_things:
card:
type: entities
entities:
- entity: input_select.mode_room_[[mode]]
- [[list]]
Then to fill the list
- type: custom:decluttering-card
template: list_of_things
variables:
- mode: livingroom
- list:
- light.livingroom_footlamp
- light.vardagsrum_tak
Tried this version too - did not work unfortunately.
Thank you so much for your effort. As I want to continue working with UI Lovelace mode I think you card is the way to reduce and reuse my code. However, it is not working and I am looking for same help. My piece of code is the following:
title:
element:
type: state-label
prefix: Salón
entity: sensor.placeholder
tap_action:
action: none
hold_action:
action: none
style:
top: 9.15%
left: 25.4%
color: '#bcbebf'
font-family: SF Text
font-size: 2.4vw
font-weight: 500
max-width: 1px
cursor: default
title: Casa
- title: test
path: test
panel: true
badges: []
cards:
- type: picture-elements
image: /local/background.png
elements:
- type: 'custom:decluttering-card'
template: title
Am I doing sth wrong?
Can you please explain what is not working?
PS:
cards:
this above should be an array:
cards:
Sorry. Copy&paste trouble. I defined as array and I edited my original post. My “not working” means I cannot see “Salón” text as expected (color, position, style). If don’t use your card, it works. The code is:
title: Casa
- title: test
path: test
panel: true
badges: []
cards:
elements:
- type: state-label
prefix: Salón
tap_action:
action: none
hold_action:
action: none
style:
top: 9.15%
left: 25.4%
color: '#bcbebf'
font-size: 2.4vw
font-weight: 500
max-width: 1px
cursor: default
I had a similar error when using it within picture-elements. The problem for me was the style attribute. It does not work when this is whithin the template of the decluttering card. So remove this from the template and add the style tag where you would use the decluttering card.
If I do it as you said, I have to copy&paste this style in each decluttering card I would use and that is what I want to avoid
I need to correct myself. It might be a bug in the decluttering card, but for me it works also with style, but only if I define a default value even if I do not use this variable later. Without the default, I get the same error.
You should do a minimal working example and increase it iteratively. I have this:
decluttering_templates: !include decluttering.yaml
And in the decluttering.yaml:
lcars_button_engineering:
default:
opacity: 0.6
element:
type: image
image: /local/lcars/engineeringButton.svg
tap_action:
action: navigate
navigation_path: "/lcars-ui/1"
style:
top: 12%
left: 76.5%
width: 15%
opacity: "[[opacity]]"
In one lovelace yaml file, I use it as follows:
image: /local/lcars/engineeringInterfaceSmall.svg
elements:
template: lcars_button_engineering
Again, the key for me was to add the default section, although it should be optional. Hope that helps.
Yeah! Thx you so much. It is working right now!
Interesting, I’m going to look into that but I’m surprised
Thanks @RomRider! I really appreciate your work! Be aware that this happens only when using it in picture elements.
I am using Lovelace in GUI editor mode (not sure if I am using a correct definition).
Have a lot of decluttering templates.
I want to split these templates into separate files.
Is it possible to do something like this:
!include name_of_template_1.yaml
!include name_of_template_2.yaml
!include name_of_template_3.yaml
title: Home
- path: default_view
title: Home
icon: 'mdi:home'
Tried it in a raw editor but got an error.
Including files is only supported in yaml mode.
