Lovelace: Decluttering Card
Is there any way to use a template but omit certain variables that are part of the template? In other words, when I am creating a card, do I have the option to use “some” of the variables? If so, how do I structure the card? TIA!
Just omit them? Or, use a default value if not set?
Yes, a default value can be set. Not sure omitting works without using the default and other code to handle it.
I’d like to omit one of the variables that’s in the template.
Not sure that really works by default. The whole idea is to set variables (or defaults).
So, you may need added code to handle the ‘omitted’ variable.
Hi
i have found this post, i have issues with my icon , i wanit to change based on the state, so i did like your example, i removed the intent, but it doesnt provide me an icon? what am i missing here?
i dont see any error on the console
            template: button
            variables:
              - entity: cover.velux_links
              - name: Velux Links
              #- icon: window-shutter
              - icon: >-
                  {% if is_state('cover.velux_links','open') %}
                  window-shutter-open
                  {% else %}
                  window-shutter
                  {% endif %}
if i do like below, i indeed see this error
          - type: custom:decluttering-card
            template: button
            variables:
              - name: Velux Links
              - icon: >-
                    window-shutter-open
                  {% else %}
                    window-shutter
                  {% endif %}
also workaround doesnt work:
              - icon: "
                    window-shutter-open
                  {% else %}
                    window-shutter
                  {% endif %}
ONly this works when i put it static:
            template: button
            variables:
              - name: Velux Links
My card template is like below:
card:
  type: custom:button-card
  deep_press: false
  icon: 'mdi:[[icon]]'
With more and more recent emphasis on tooling for building things in the UI, is anyone aware of anything on the HA roadmap allowing “include” or something similar in the “storage”-based dashboards?
I like being able to drag-and-drop chunks, and see quick previews of what I’m messing with, but I also want to not have to repeat myself all over the place, and make minor changes in multiple places because it’s all copy/paste.
I don’t even know how to search for this kind of thing in the Issues on Github. I assume it would be in the “frontend” repo?
Keywords like “dashboard”, “yaml”, “storage”, and “include” show up in far too many items for totally unrelated reasons. :smiley:
I’d love to see some additional means of reusing dashboard elements built into Lovelace.
In the meantime, I forked decluttering card to add support for the visual editor so it’s a little easier to make templates for cards, rows, and other elements wherever I need them.
I’m hoping that my changes will be merged upstream eventually but for now feel free to use my fork if you find it useful.
Hi, need some help. I successfully used decluttering card for full card templates but here for an element it doesn’t work.
Here is what I want to achieve:
type: custom:mushroom-chips-card
chips:
  - type: template
    tap_action:
      action: toggle
    icon: mdi:lightbulb
    entity: light.test1
  - type: template
    tap_action:
      action: toggle
    icon: mdi:lamp
    entity: light.test2
  - type: template
    tap_action:
      action: toggle
    icon: mdi:vacuum
    entity: automation.start_vacuum
Pic:
So I made this:
decluttering_templates:
  test:
    element:
      type: template
      tap_action:
        action: toggle
      icon: mdi:lamp
      entity: light.test2
chips:
  - type: template
    tap_action:
      action: toggle
    icon: mdi:lightbulb
    entity: light.test1
    template: test
  - type: template
    tap_action:
      action: toggle
    icon: mdi:vacuum
But I obtain this:
It insert a blank space between the first and third element…
I have missed something ?
Thank for your help.
i just wonder about the whole state of the decluttering card? Is this card “official” depricated?
Why would that question be asked? I don’t see anything that would make me think that.
I don’t think you can get a decluttering template under a mushroom card. You can just make a new template for mushroom chips…
template:
  chips_template:
    card:
      chips:
        - type: template
          tap_action:
            action: toggle
          icon: '[[icon_1]]'
          entity: '[[entity_1]]'
        - type: template
          tap_action:
            action: toggle
          icon: '[[icon_2]]'
          entity: '[[entity_2]]'
        - type: template
          tap_action:
            action: toggle
          icon: '[[icon_3]]'
          entity: '[[entity_3]]'
card:
template: chips_template
variables:
  - icon_1: mdi:lamp
  - entity_1: light.office_lamp_bulb
  - icon_2: mdi:lightbulb
  - entity_2: light.office_ripple_mood_light
  - icon_3: mdi:robot
  - entity_3: automation.guest_mode_notify
Agree. Decluttering card is a card. Not a chip.
Hello everyone,
just found out that Decluttering Card is exactly what I am searching for.
However, I just don’t get it how to install it.
I’ve downloaded the custom card from HACS and I do see some new files:
I went to the Lovelace frontend I want to add the cards and pressed:
There I added the following lines on top before the “views” node:
resources:
  - url: /local/decluttering-card.js
    type: module
  valve_template:
    card:
      entity: '[[valve_name]]'
      icon: mdi:heating-coil
Then I tried to test the template and add a custom card:
template: valve_template
variables:
  - valve_name: switch.wb_ventil_fb
and get:
I’ve read so much articles and tutorials but I still have no idea what I am missing. I know that there is or was something like the lovelace-ui.yaml but as far as I understand, this is just optional if I don’t want to add the template directly in the Raw-Configuration Editor.
I am wondering if the path /local/decluttering-card.js may be incorrect? I do see this file in vs-code unter a different path. But no idea how to define this path correctly.
And maybe it’s also something about this ressource manager:
where JS Modules can be added.
Again same problem: No idea how to define the path.
Hope someone can give me the missing hint. I really want this feature. :wink:
PS:
Just found the js file under ressources.
Maybe I have a different problem?
you are using storage mod, you don’t have to set resources to yaml. resources is automatically added via hacs.
remove this
resources:
    type: module
Did you ever come up with a solution to this?
I solved it with decluttering + custom-button (custom-button is “transparent”). You can change both the main card, and the items, and you can have individual condition for each item.
  1. Decluttering template:
Code
  my_entities_plus:
    default:
      - CARD:
          type: entities
          entities: '[[[ return variables.z_items; ]]]'
      - ITEMS: []
    card:
      show_icon: false
      show_name: false
      show_state: false
      styles:
        card:
          - border: none
          - margin: 0
          - padding: 0
        grid:
          - grid-template-areas: |
              "inner_card"
      tap_action:
        action: none
      variables:
        items: '[[ITEMS]]'
        z_items: |
            let x = variables.items.filter(el => typeof el.js_cond === typeof undefined || el.js_cond);
            x.map(el => {if (el.js_cond) delete el.js_cond; return el});
            return x;
      custom_fields:
        inner_card:
          card: '[[CARD]]'
  1. Examples
a) empty entities card (pointless but works)
template: my_entities_plus
b) entities card redefined (templated title), with 2 rows/ITEMS; second row shows only if last digit of sun elevation is an even number; it’s done by defining optional field for that entity: js_cond with javascript code that should return true or false.
variables:
  - CARD:
      type: entities
      entities: "[[[ return variables.z_items; ]]]"
      title: "[[[ return states['sun.sun'].state ]]]"
  - ITEMS:
      - entity: sun.sun
        name: "[[[ return states['sun.sun'].attributes.elevation; ]]]"
      - entity: sensor.sun_next_dawn
        js_cond: "
            let x = `${states['sun.sun'].attributes.elevation}`;
            let lastDigit = parseInt(x.slice(-1));
            return lastDigit % 2 === 0;
c) CARD changed to heading card, ITEMS are now badges
variables:
  - CARD:
      type: heading
      badges: "[[[ return variables.z_items; ]]]"
      heading: "[[[ return `hosting ${variables.z_items.length} items!`; ]]]"
  - ITEMS:
      - entity: sun.sun
        name: "[[[ return `${states['sun.sun'].attributes.elevation}`; ]]]"
        state_content: name
      - entity: sun.sun
        state_content: name
I tried to add a decluttering card template in my configuration.yaml for testing. But I get a configuration warniung.
Integration ‘decluttering_templates’ not found.
What’s missing or that’s my fault. Was using HACS for the installation of decluttering-cards
Best regards Christian
  1. For yaml-mode dashboard - this.
  2. For storage-mode dashboards - all templates should be added in “raw config editor”:
Hi
I’m trying to wrap my head around this card, and particularly the case where I need to override values on some of the instances of a template. For example, let’s say that sometimes I want to display the entity’s own name, and sometimes I need to override it. I tested these scenarios:
  • The template doesn’t have a name variable defined: adding name: XXX to the decluttering card instance doesn’t work. It gets ignored.
  • The template does have a name variable: if I don’t put a value in the card instance, the card name shows [[name]].
So it seems that to override some names, I must define name as a variable, and define it for all the instances. Is this correct, or is there a better way?
I see that templates can have a default defined. Is it a fixed hardcode value, or can it carry forward the entity’s own value?
Thanks for any assistance.
Hi guys,
I have the following simplified decluttering template, with card-mod which is not working as a decluttering card, but if I use it as a regular card it works fine.
I need the vertical-stack-in-card as there is stuff before the horizontal stack, this is just a simplified version.
Please help!
decluttering card template:
  decluttering_test:
    card:
      type: custom:vertical-stack-in-card
      cards:
        - type: custom:mod-card
          card:
            type: horizontal-stack
            cards:
              - type: entity
                entity: sun.sun
              - type: entity
                entity: sun.sun
              - type: entity
                entity: sun.sun
              - type: entity
                entity: sun.sun
              - type: entity
                entity: sun.sun
      card_mod:
        style:
          ha-card:
            mod-card:
                hui-horizontal-stack-card $: |
                  div#root hui-card > * {
                    display: flex;
                    flex-direction: column;
                    --ha-card-border-width: 0px !important;
                    margin-bottom: 5px !important;
                    margin-top: -5px !important;
                  div#root > :first-child > * {
                    margin-left: 4px !important;
                  div#root > :last-child > * {
                    margin-right: 4px !important;
                  hui-horizontal-stack-card {
                    --horizontal-stack-card-gap: 2px;
                  ha-card {
                    box-shadow: var(--ha-card-box-shadow);
                    border: var(--ha-card-border-color,var(--divider-color,#e0e0e0)) solid var(--ha-card-border-width,1px);
                    background: var(--ha-card-background,var(--card-background-color,#fff));
decluittering card:
template: decluttering_test
kép
regular card:
cards:
    card:
      cards:
        - type: entity
          entity: sun.sun
        - type: entity
          entity: sun.sun
        - type: entity
          entity: sun.sun
        - type: entity
          entity: sun.sun
        - type: entity
          entity: sun.sun
card_mod:
  style:
    ha-card:
      mod-card:
              display: flex;
            ha-card {
kép
