Lovelace Entity Filter card Header toggle
When assigning a title to an Entity Filter Card, a header toggle appears.
Is it possbile to remove this.
I tried “show_header_toggle: false” but this has no effect.
Are you using an entities card or an entity filter?
show_header_toggle is option on the entities card
It would help if you publish your configuration for this.
Hi Cyn, I am using an Entity Filter card, but I managed to get it to work, as I had the line in the wrong place…
How did you remove it? My entity filter card also has a header toggle, I don’t know why. It suddenly appeared after an earlier HA upgrade.
Via the GUI you can switch on/off the header toggle on normal entities cards, but there is no toggle for the entity filter card.
See my config entry, you need to use the editior:
card:
show_header_toggle: false <<<<<<<<<<<<<<<<<<<<<<<<<<
title: Switches
entities:
  • entity: switch.bathroom_lights
  • entity: switch.bathroom_blinds
state_filter:
  • ‘on’
  • ‘off’
    type: entity-filter
