Lovelace: forked daapd card
This card is very niche, I made it mostly to cover my own needs, but thought I would share it anyway, hopefully someone can find it useful!
A lovelace card for Home Assistant to control a forked daapd instance.
This card allow you to control your forked daapd instance through Home Assistant.
The following controls are available: master volume
, play/pause
, next/previous
, on/off
, output selection
, individual output volume
Prerequisite
- Forked daapd built with websocket support.
- Forked daapd setup as an media_player (mpd component) in Home Assistant
Install
Simple install
- Copy
forked-daapd-card.js
into yourconfig/www
”folder. - Add a reference to the
inside yourui-lovelace.yaml
resources:
- url: /local/forked-daapd-card.js?v=0.0.1
type: module
Install using git
- Clone this repository into your
config/www
folder using git.
git clone https://github.com/kalkih/forked-daapd-card.git
- Add a reference to the card in your
ui-lovelace.yaml
resources:
- url: /local/forked-daapd-card/forked-daapd-card.js?v=0.0.1
type: module
Updating
- Locate your
inconfig/www
or wherever you ended up storing it. - Replace it with the latest version of forked-daapd-card.js.
- Add the new version number to the end of the cards reference url in your
ui-lovelace.yaml
like below.
resources:
type: module
If you went the git clone
route, just run git pull
from inside your config/www/forked-daapd-card/
directory, to get the latest version of the code. Then add the new version number to the end of the card reference url in your ui-lovelace.yaml
like below.
resources:
type: module
Using the card
Options
Name | Type | Default | Since | Description |
type | string | required | v0.0.1 |
custom:forked-daapd-card . |
entity | string | required | v0.0.1 | The entity_id of your forked-daapd media_player (mpd) in home assistant. |
ip | string | required | v0.0.1 | Set the IP address of your forked-daapd server. |
port | number | 3689 | v0.0.1 | Set the port of your forked-daapd server. |
ws_port | number | 3688 | v0.0.1 | Set the websocket port of your forked-daapd server. |
name | string | optional | v0.0.1 | Set a custom friendly_name which is displayed beside the icon. |
icon | string | optional | v0.0.1 | set a custom icon from any of the available mdi icons. |
outputs | list | optional | v0.0.1 | If you want to only show specific outputs, include the id of each one in the list. |
- You can find the outputs ids by accessing
http://<forked-daapd-ip>:<port>/api/outputs
Example usage
Normal
- type: "custom:forked-daapd-card"
entity: media_player.multiroom_audio
ip: "192.168.1.5"
Show only specified outputs
ip: "192.168.1.5"
outputs:
- "225176710053082"
- "962995053492"
- "24918234768"
Getting errors?
Make sure you have javascript_version: latest
in your configuration.yaml
under frontend:
Make sure you have the latest versions of forked-daapd-card.js
If you have issues after updating the card, try clearing your browser cache.
License
This project is under the MIT license.
