As long as you are able to connect to your forked daapd instance with ssl it should be possible, with a few changes in the code http:// to https:// and ws:// to wss://.
There was a build option for forked daapd for SSL support, not sure if it is still supported though, we couldn’t find it in the docs.
Any ideas on a similar component that might be a good starting point for something like this?
I wouldn’t mind having a bit of a hack at creating a component like this. But I haven’t played with websockets before, which look to work a lot better than periodically polling the API (which I’m currently doing with sensors) to get similar functionality.
so I have duckdns domain, if I was to install nginx would I be able to redirect https:// to http:// for certain ports and still access my HA on https:// ?
installing nginx, would it cause any issues with my duckdns domain, ssl etc?
As I see there is already a docker image.
Anybody did try to create a hassio add-on yet for forked-daapd? I had mine running on a separate pi but the sd card just crapped out… And of course it would be great to just have forked-daapd as an add-on and not need to install it on a separate rpi…
Yes, most likely won’t work, you could easily edit the source to make it SSL compatible but I don’t think forked-daapd supports wss, so wouldn’t make a difference.
I had my home assistant set up behind an nginx SSL proxy, so I could connect to my home assistant frontend without SSL while on LAN, and because of this bypass the SSL issues.
I seem to be seeing a similar problem - I cannot select sources/destinations from the card, none show up. I do however see the track title, which presumably it’s pulling from fork-daapd, so I think the connection is there?
Running the curl check from my hassio instance for websockets, seems to pass:
I also have the below in the frontend configuration:
javascript_version: latest
But unfortunately I end up with no speaker selection. Screenshot attached. I’ve tried manually specifying the output sources, gained from the /api/output
Unable to see anything in the browser console logs either
EDIT: Not using SSL, deffo websockets support:
[ LOG] main: Forked Media Server Version 26.5 taking off
[ LOG] main: Built with:
[ LOG] main: - ffmpeg
[ LOG] main: - iTunes XML
[ LOG] main: - MPD
[ LOG] main: - Device verification
[ LOG] main: - Websockets
[ LOG] main: - ALSA
[ LOG] main: - Webinterface
Ok, I found my problem. When I ran forked-daapd in the foreground, I saw the below when trying to use the card:
httpd: Web interface request to ‘/api/outputs’ denied: Incorrect password
Not actually a password issue, but my trusted networks in forked-daapd I’d specified in CIDR format “x.x.x.x/24”, when looking at the example it just wants “x.x.x”.
Many thanks, this is the missing link for me - now using librespot piped into forked-daapd, I can control spotify from Home Assistant directly.
