I think the issue is with the combination of exclude_states and remove_repeats. The states are excluded before the repeats are filtered out. This means thatif you exclude “off” and the state changes from “on” to “off” and back to “on”, you will lose the second “on” state. Is this what you are seeing? I may be able to avoid this by changing the order of processing to this:
Exclude unknown states
Remove duplicates if option set
Exclude states defined in exclude_states
Unfortunately this will mean that “unknown” will always be filtered out, regardless of the exclude_states option.
Yep that’s it. Except I don’t just lose the second ‘on’ I lose both. I only want to see one.
e.g. someone moving around in a room will cause many PIR ‘on’ / ‘off’ states, I only want to see the latest ‘on’. Then if they move to another room and move around there the top of the feed should be a single ‘on’ for that room.
As a test I tried removing exclude_sates and enabling remove_repeats and all I see now is repeats due to the show_history (as expected). This is exactly what I want - but without the ‘clear’ states.
It definitely has something to do with the interaction you are talking about. It’s just that it’s being a bit overzealous and not just removing the second ‘on’ state but both ‘on’ states.
Can you try this with the new beta version, 0.2.10b3, and let me know if it is now working for you?
You may need to wait a short time or do a hard refresh of the page after updating to the new version for the updated logic to take effect due to caching.
What does it look like without the exclude_states? Does it show Clear states between the Detected states? In that case, I think the change in the order of processing so that the states are filtered after repeats are excluded means that the states aren’t being treated as repeats.
I notice that in your original comment you said:
if I enable remove_repeats for an entity it also removes the most recent entry as well.
The remove_repeats logic actually keeps the earliest entry (over the previous day) rather than the latest. If you try rolling back to the previous beta version, do you see the missing entries if you scroll down to the bottom of the feed? If so, I may be able to add an option to change this so it keeps the latest instead if this would help.
It also looks like the issue is partly related to the the sensitivity of the specific sensors and how often they are switching between Detected and Clear. Could these be smoothed out it any way, such as using a template binary sensor?
It may be possible to have an option in the card which filters out states which repeat within a period of time (e.g. if it changes to Detected, then Clear, then Detected within a 5 minute period) but this would be quite complicated to implement.
That’s the problem. It wasnt. It was removing every trace of an entity that had a duplicate entry in the feed. Now it’s not removing anything though.
They are wired PIRs. They come on for 3sec. minimum. Pretty smooth. No bouncing contacts, that’s just me waving my arms in front of the sensor repeatedly to test for duplicates.
I think max_item_count (which you have set to 20) may be the cause of this issue. Since the processing of remove_repeats happens before applying the max_item_count (which was a newer feature) the earliest Detected event for that entity may have not have been one of the 20 most recent events and been cut off. Can you try with the previous beta, but without that option set (or with it set to a higher value) and see if that is the cause of your issue?
If it is, I don’t know the best way to deal with that (other than potentially an option to control how much of the history to use, so you could just display the last 6 or 12 hourse, for example).
I have just published a new beta release 0.2.10b4, with a new option keep_latest (and also the filtering logic reverted to the original order). This option will keep both the newest and oldest occurrence when removing duplicates, use it like this:
Just as a heads up for anyone who is doing an update from a previous version using HACS…
I suddenly found my “home-feed-card” giving me the “red box of death” error in lovelace. I pulled out my hair a bit trying to figure out why because I had not changed anything with this recently.
Then I realized that the file name in the installation directory has changed. Since that has changed then the entry in the resources section now needs changed from: “…/home-feed-card.js” to “…/lovelace-home-feed-card.js”.
I’m not sure when this changed or if it was announced here (I must have missed it) but changing the entry in the resources section fixed it.
I don’t know exactly when this happened, but I think it may have been caused by a change to HACS rather than this card. The filename has always been lovelace-home-feed-card.js but HACS used to strip the lovelace- part when downloading it, but this is no longer happening.
Maybe I’ll have to check all of my other lovelace components to see if the others that started with “lovelace-” did the same thing. I haven’t noticed anything obvious tho aside from your card.
Either way it’s fixed now so just wanted to put that out there in case anyone else had the same issue.
I’m working on a new version which is refactored to use LitElement. I’ve updated to 0.98 and this version seems to display correctly.
This isn’t yet ready for a release yet, as there are some styling issues (such as the position of the dismiss button on notifications), but if you are willing to accept that, you can try it out by installing from the dev branch in HACS.
Edit: I have fixed the styling issues with this, so it is now released as 0.2.11b1
EDIT: Not conclusive but I think this card may be causing excessive CPU use.
Portainer showed the home assistant container responsible. Restarting HA did not change the excessive CPU use. Deleting my two home feed cards did. Coincidence? IDK.
