Lovelace: mini graph card
Thanks! nevertheless there is still a large unused space above the graph. :frowning: (wouldn’t mind some 10ish pixels, but … (highest green part is 100%)
Try it here:
I am trying to create a view with 8 graphs for a tablet.
The graphs are divided into four rows and 2 columns using vertical and horizontal stacks.
The layout fits, but the graphs are way too big, so you have to scroll down the page.
How do I get it adjusted so that all graphs are displayed on one page?
Start with playing with fonts & graph’s height - there are native card’s options for these things.
If it is not enough - some alterations may be done by card-mod which is a bit more difficult way, so start with the 1st step.
have no idea how… can you give some examples?
type: vertical-stack
cards:
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.processor_use
    entities:
    font_size: 30
    font_size_header: 25
    height: 30
thank you , that helps!
Hi, Do you have the code to recreate this? I’d love to have it as my header card for all my rooms. I’ve searched a small way back through the thread but can’t find it.
This is achieved by card-mod. Try playing with it. Try, learn, make mistakes, try - this is the Way.
I have tried and I am also learning but struggling to replicate it. I’m using card mod already via custom stack in cards.
States are placed inside a flex. You may place the 2nd state to the left. Then place them both above the graph.
Icons are tricky. A possible way is to add them as images (not icons) to ā€œ:beforeā€ pseudo classes.
Google in card-mod thread for examples.
Thanks, I’m getting there, just trying to decide whether to leave the chip cards in top right or move them to bottom left.
You added another card overlayed?
It’s a combination of horizontal stacks and vertical stacks with card mod to move things a bit closer together.
I see. By using a stack you may overlay cards.
Suggest to post your code here for people who are interested.
How can I show the name of the second entity above the state, similar to how the primary entity shows its name? Using .states--secondary::before added some text above the second state, and I’d be fine with the same formatting of the primary state name, but if I try before on the primary state it messes with the alignment:
    line_width: 3
    lower_bound: 10
    upper_bound: 30
    show:
      min: true
      icon: false
      legend: false
      fill: fade
    color_thresholds:
      - value: 25
        color: red
      - color: orange
      - value: 15
        color: blue
    entities:
      - entity: climate.back_room_radiator
        attribute: current_temperature
        unit: °C
        show_state: true
        attribute: temperature
        unit: °C
        show_state: true
        color: mediumpurple
Hello all,
I have found the example of how to display additional information on the card. I would like to display the battery status in form of an icon. Has anyone done this before?
How can I call a service by tap action option? I’m trying to call input_select.select_option service but it fails although in developer tools, calling this service is working. What am I missing?
Here is my card:
entities:
  - entity: sensor.consum_total_apartament_power
    name: Putere Consumata Apartament
    color: '#4caf50'
hours_to_show: 24
line_width: 3
font_size: 50
animate: true
show:
  icon: false
  state: true
  legend: true
  fill: fade
tap_action:
  action: call-service
  service: input_select.select_option
    option: consum_apart
    entity_id: input_select.input_select_minimalist_ui
According to Docs as usual.
Some custom cards have ā€œaction dataā€ a bit different than a standard one. Not to mention a a difference between ā€œservice callā€ in different standard cards & ā€œservice callā€ in other places.
Similarly to my last question, how can I prefix each state separately? Using .states.flex .state .state__value.ellipsis::before { as per this example applies the same prefix to both states
Updated that post.
