Suggest you to check with a stock history-graph card first since “32767” value is rather familiar to me.
Also, define lower_bound for mini-graph-card.
Also, “value” is a “start” value, not a “stop” value.
Also, suggest for testing to use SIMPLE and CLEAR colors like “red”, “green” instead of these hex colors to avoid confusing about “greenish blueish”.
Well, I found the Problem, 32767 is the max possible value for an sensor in HA. It seems it only takes int16. So The Problem lies with the integration delivering a Value bigger than that I guess.
But the result is still not showing the line graph for the elevation, but it shows the value at the top, which indicates the entity sun.sun and its attribute elevation are available.
looking at the labels - both (max and min) are 0 (zero) - makes me thinking that there is something to be done.
I’ve used several browsers on my PC, even in privacy mode; I cleared the cache more than once.
and I used the companion app on Android.
The situation remains the same, no line for sun elevation.
I checked the developer tools as well, but I am not too familiar with them. In the console I didn’t notice anything related to the mini-graph card. There were some messages about bubble-card and the decluttering card though
When you view the history for the sun sensor, does it plot the main state? In other words, have you perhaps excluded the sun sensor from your recorder?
Do not have any “climate” entities in my setup.
Is that “local_temperature” an attribute inside a “climate” entity?
If yes - use an “attribute” option, it is described in Docs for mini-graph-card.
Could someone help me with this layout issue? I’ve nested the graph inside the entities card so I can match the title text to my theme - only issue is the extra padding which I can’t seem to remove:
If I uncheck this padding it looks good:
Result:
I tried to use card_mod but it’s not having an effect:
Hi guys,
I have this card and I would like to make some changes, I would like to change the highlighted information to temperature instead of humidity, however, to do this I have to change the order of the graphics, but if I do that, the color codes do not work, I would also like to remove data at the edges of lines when selected
