Lovelace: mini graph card
Did you check the docs?
You’ll need to use the ApexCharts card.
I checked the docs and did not see this feature that’s why I wrote here in case I missed something.
Indeed, I did it with apexcharts but a like mini graph card so if there is a possibility I’d be happy to go back to mini.
You cannot create a stacked look with mini-graph.
I am trying to show a statistics-like graph that displays max, median, min out of x different sensors. Both min and max values should only be displayed with a very thin line (or maybe not be shown at all - only the bands around the median), while the median should be more pronounced. And then the legend should only be displayed for the median.
I tried this:
type: custom:mini-graph-card
decimals: 1
entities:
  - entity: sensor.sensors_max
    color: orange
    show_legend: false
  - entity: sensor.sensors_median
    color: red
    line_width: 3
    show_fill: false
    show_legend: true
  - entity: sensor.sensors_min
    color: orange
    show_legend: false
line_width: 1
hours_to_show: 12
card_mod:
  style: |
    mask:nth-of-type(2) .fill {
      opacity: 1 !important;
      animation: none;
    .fill--rect:nth-of-type(2) {
      fill: var(--card-background-color);
This ended up looking like this:
2 questions:
  • why does the 2nd show_legend: false make all legends disappear?
  • why doesn’t the line_width: 3 for the median change it’s width?
Any help would be much appreciated.
You better to post a link to a source post where you took this code - for consistency.
It should not affect at all since this option could be defined on a card’s level only.
Regarding the fill-option, I went with this post as a blueprint.
Thanks for clarifying this. Maybe I could just show the min and max graph ind the same color and opaqueness as the filled area?
My main problem however is the inconsistency in legends. Why can I hide 1, but not 2 out of 3?
I am not getting the issue.
If you mean “make max/min graphs less vivid” - you can just hide lines:
Suggest to re-test; and a legend is displayed only if a number of entities to be “legended” >= 2.
Trying to use the mini-graph-card for my home built rain sensor
It’s based on this project:
https://www.reddit.com/r/3Dprinting/comments/16azwxr/3d_printed_diy_zigbee_rain_sensor_based_on_aqara/
A dual tipping bucket monitored by a magnetic door contact that flips to 0 or 1 (or wet and dry in my code) (code for platform- and template sensors below)
If I summarize the number of flips for last day, it is 27, that corresponds to 14.2 mm of rain, so that looks to be correct
But - the hourly graph doesn’t give the same when I summarize it!
I had expected the last four hours to show sum up to the same as last 24h (as it has not been raining for a couple of days, so nothing from yesterday should be able to affect it.
# Regnsensor platform sensor rain/24h
  - platform: history_stats
    name: "Regn Contact Flips/Dry"
    entity_id: binary_sensor.regn_contact
    state: "off"
    type: count
    start: "{{ now() - timedelta(hours=24)}}"
    end: "{{ now() }}"
    name: "Regn Contact Flips/Wet"
    state: "on"
    type: count
    end: "{{ now() }}"
    #unavailable
    name: "Regn Contact Flips/unavailable"
    state: "unavailable"
    type: count
    end: "{{ now() }}"
# Regnsensor platform sensor rain/h
    name: "Regn Contact Flips/Dry_hour"
    state: "off"
    type: count
    start: "{{ now() - timedelta(hours=1)}}"
    end: "{{ now() }}"
    name: "Regn Contact Flips/Wet_hour"
    state: "on"
    type: count
    end: "{{ now() }}"
    #unavailable
    name: "Regn Contact Flips/unavailable_hour"
    type: count
    end: "{{ now() }}"
template:
#Template Regnsensor rain/24h
  - sensor:
      - name: Rainfall [day]
        state_class: measurement
        unique_id: rainfall_day
        unit_of_measurement: mm
        icon: mdi:weather-pouring
        state: >-
          {% set count = (states('sensor.regn_contact_flips_dry') | int(0)) + (states('sensor.regn_contact_flips_wet') | int(0)) - (states('sensor.regn_contact_flips_unavailable') | int(0)) -1 %}
          {% if count < 0 %}
            {% set count = 0 %}
          {% endif %}
          {% set mm = count * 0.52615 %}
          {% if count >= 0 %}
            {{ mm|round(1, 'floor') }}
          {% endif %}
#Template Regnsensor rain/h
  - sensor:
      - name: Rainfall [hour]
        unique_id: rainfall_hour
        state: >-
          {% set count = (states('sensor.regn_contact_flips_dry_hour') | int(0)) + (states('sensor.regn_contact_flips_wet_hour') | int(0)) - (states('sensor.regn_contact_flips_unavailable_hour') | int(0)) -1 %}
          {% if count < 0 %}
            {% set count = 0 %}
          {% endif %}
          {% if count >= 0 %}
          {% endif %}
(the -1 for “set count” is because the sensor looks to present itself with status on every reboot and that looks to count as well)
The code for my lovelace card looks like this
square: false
type: grid
cards:
  - type: custom:mini-graph-card
    icon: mdi:weather-rainy
    aggregate_func: max
    hours_to_show: 24
    group_by: hour
    show:
      graph: bar
      fill: true
      icon: false
    color_thresholds:
      - value: 100
        color: '#8a111e'
      - value: 50
        color: '#c7311c'
      - value: 25
        color: '#fc5a43'
      - value: 10
        color: '#fc8582'
      - value: 5
        color: '#fbab3e'
      - value: 2
        color: '#ebf438'
      - value: 1
        color: '#79cf3f'
      - value: 0.5
        color: '#24cbcc'
      - value: 0.2
        color: '#3296de'
      - value: 0
        color: '#373737'
    entities:
      - entity: sensor.rainfall_hour
        state_adaptive_color: false
    aggregate_func: avg
    hours_to_show: 360
    group_by: date
    show:
      graph: bar
      fill: true
      icon: false
    color_thresholds:
      - value: 100
        color: '#8a111e'
      - value: 50
        color: '#c7311c'
      - value: 25
        color: '#fc5a43'
      - value: 10
        color: '#fc8582'
      - value: 5
        color: '#fbab3e'
      - value: 2
        color: '#ebf438'
      - value: 1
        color: '#79cf3f'
      - value: 0.5
        color: '#24cbcc'
      - value: 0.2
        color: '#3296de'
      - value: 0
        color: '#373737'
    entities:
      - entity: sensor.rainfall_day
columns: 1
title: Regnmätare
What is it I don’t understand or have missunderstood?
Why doesn’t hours sum up to the same value as last 24h?
Edit/Add:
Today (day after) the 24h graph doesn’t make any sense to me…
Only 7.84 yesterday (showed above 15 when I went to bed around 23/11pm yesterday and 8.11 for today…while Rain/day shows as 1.5mm…!?
The hourly graph shows it has not been raining since 18/6pm yesterday…why does the daily grahp shows 8.11 for 12am-11.59pm today!?
Hi, I was wondering if there’s a way to convert a temperature graph from F to C? I see that you can change the unit and then also add a value factor field, but that won’t quite do it for temperature. What’s the best way to achieve this?
Did you check if the sensor itself has the option? That would be the cleanest of course; but not sure what you’re looking to do…
@Ildar_Gabdullin thanks for all the work on trying to get people to help customize the card
Would you know (I think legend is the way to go here, but struggling to keep them in one line) how to put the Min and Max to the right of the current temp to use the div row?
I read through the thread on "mini-graph-card" & "history-graph": using a decluttering template - #16 by Ildar_Gabdullin but didn’t find anything exactly like it
Current
would like
Code
type: vertical-stack
cards:
    icon: mdi:temperature-celsius
    decimals: 1
    line_width: 2
    hours_to_show: 24
    points_per_hour: 1
    hour24: true
    show:
      labels: true
      icon: false
    entities:
      - entity: sensor.gr_sensor_1_temperature
        show_points: false
    color_thresholds:
      - value: 16
        color: '#251ab9'
      - value: 17
        color: '#0f28e5'
      - value: 18
        color: '#007eff'
      - value: 19
        color: '#00aaf9'
      - value: 20
        color: '#00cc9e'
      - value: 22
        color: '#59E442'
      - value: 21
        color: '#7fd206'
      - value: 23
        color: '#97bf00'
      - value: 24
        color: '#aaac00'
      - value: 25
        color: '#b89700'
      - value: 26
        color: '#c18200'
      - value: 27
        color: '#c86c00'
      - value: 28
        color: '#ca5400'
      - value: 29
        color: '#c93905'
      - value: 30
        color: '#c4161e'
    card_mod:
      style: |
        .header {
          padding-bottom: 0px;
        .graph__legend {
          margin-top: -45px;
          justify-content: end;
        ha-card {
          border-radius: var(--ha-card-border-radius, 4px) var(--ha-card-border-radius, 4px) 0px 0px ;
  - type: history-graph
    hours_to_show: 24
    refresh_interval: 0
    entities:
      - entity: sun.sun
    card_mod:
      style: |
        .content {
          padding: 0px !important;
          margin-left: -20px;
          margin-top: -35px
        ha-card {
          overflow: hidden;
          margin-top: -8px;
          border-radius: 0px 0px var(--ha-card-border-radius, 4px) var(--ha-card-border-radius, 4px);
card_mod:
  style: |
    ha-card {
      overflow: visible !important;
Thanks in advance!
IMHO - a template sensor with a proper conversion.
You seem to use another my technics “Combining `history-graph` & `mini-graph-card” which I usually do not recommend since it gives very unstable results.
As for presenting “min” & “max” like you want - I do not have an example how to achieve it.
Right, but since there’s no time axis, I think your solution is a brilliant and only approach, I haven’t found any other way to show a time axis since the X Axis was rejected
I’ll see if I can chew on the css, thanks!!
Better to say - “not implemented yet”.
Dear All
I would like to know if possible add “CPU usage” or allign position between 2 graph.
cards:
  - type: custom:bubble-card
    card_type: pop-up
    hash: '#wlc'
    icon: phu:proxmox
  - type: grid
    columns: 1
    square: false
    cards:
        card_type: separator
        name: Cisco Wireless LAN Controller
        icon: /local/loghi/cisco-logo.png
        styles: |
          .separator-container div:last-child {
            opaticy: 1|important;
  - type: vertical-stack
    cards:
      - square: false
        columns: 4
        type: grid
        cards:
          - type: custom:button-card
            card_mod:
              style: |
                ha-card {
                  border-radius: 10px;
                  box-shadow: 10px;
                  background-position: center;
            entity: button.qemu_wlc8_10_185_109_riavvia
            show_state: false
            show_name: true
            show_label: true
            show_icon: true
            styles:
              card:
                - background-size: contain
                - background-repeat: no-repeat
                - background-position: center
              icon:
                - width: 27%
                - margin-top: 1%
            card_mod:
              style: |
                ha-card {
                  box-shadow: 10px;
            entity: button.qemu_wlc8_10_185_109_ferma
            show_state: false
            show_name: true
            show_label: true
            show_icon: true
            styles:
              card:
              icon:
                - width: 27%
                - margin-top: 1%
            card_mod:
              style: |
                ha-card {
                  box-shadow: 10px;
            entity: button.qemu_wlc8_10_185_109_spegni
            show_state: false
            show_name: true
            show_label: true
            show_icon: true
            styles:
              card:
              icon:
                - width: 27%
                - margin-top: 1%
            card_mod:
              style: |
                ha-card {
                  box-shadow: 10px;
            entity: button.qemu_wlc8_10_185_109_avvia
            show_state: false
            show_name: true
            show_label: true
            show_icon: true
            styles:
              card:
              icon:
                - width: 27%
                - margin-top: 1%
      - square: false
        columns: 2
        type: grid
        cards:
            card_mod:
              style: |
                ha-card {
                  background: var(--paper-card-background-color);
                  box-shadow: 10px;
                  font-weight: bold;
                  opacity: 0.8;
            entities:
              - entity: sensor.qemu_dns_server_100_cpu_usata
                color: '#14ff8d'
            height: 200
            hours_to_show: 1
            points_per_hour: 60
            update_interval: 200
            animate: true
            aggregate_func: max
            line_width: 2
            smoothing: true
            font_size: 65
            lower_bound: 100
            font_size_header: 9
            show:
              average: true
              extrema: true
            tap_action: none
            card_mod:
              style: |
                ha-card {
                  box-shadow: 10px;
                  font-weight: bold;
                  opacity: 0.8;
            entities:
              - entity: sensor.qemu_dns_server_100_memoria_usata
                color: '#14ff8d'
              - entity: sensor.qemu_dns_server_100_memoria_libera
                color: '#0293fa'
            height: 200
            hours_to_show: 1
            points_per_hour: 10
            update_interval: 20
            aggregate_func: max
            animate: true
            line_width: 2
            smoothing: true
            font_size: 65
            font_size_header: 9
            show:
              average: true
              extrema: true
            tap_action: none
I love this card, but have just one small issue that I’m hoping can easily be resolved.
On the graph there are min/max values but due to the size of my cards, they don’t quite fit. Is there a way to resolve this? The card is being used on a grid mode dashboard.
Example:
Here is my code:
entities:
  - sensor.weather_temperature
show:
  labels: true
  icon: true
hours_to_show: 24
points_per_hour: 1
color_thresholds:
  - value: 90
    color: '#f31212'
  - value: 80
    color: '#f34a12'
  - value: 76
    color: '#f38212'
  - value: 74
    color: '#f3c612'
  - value: 72
    color: '#c2f312'
  - value: 70
    color: '#3bf312'
  - value: 67
    color: '#12f37b'
  - value: 65
    color: '#12f3dc'
  - value: 60
    color: '#12b7f3'
  - value: 55
    color: '#12d1f3'
  - value: 40
    color: '#1273f3'
  - value: 0
    color: '#1219f3'
What you may try - adding a padding to the card by card-mod. Do not ask me how, will not give a ready example and cannot; use other card-mod examples as a staring point.
You could also try setting the overflow property on the card to visible using card_mod, or setting a z-index value as well - anything higher than 1 should normally work.
It worked for me to solve a similar issue at least.
Is there any way I could convince you to show me how I would do that with the card yaml that I posted above. I’ve spent the better part of today trying to figure out how to use Card-Mod and I just don’t get it.
