The beta isn’t working for any of my configurations, all graphs are blank. Went from 1 graph not working to all graphs not working.
The fix for the storage quota issue didn’t make it into the beta release, can probably do a new release today.
Ah ok, I can live with the issue for a while so no rush.
v0.4.3-beta2
Another beta release, make sure to clear cache if you have issues loading the new version
CHANGED
Redesign of line point hover (#99)
Moved to localForage for caching (#96) - (@bramkragten)
FIXED
Interpolate color for out of bound thresholds (#91)
Error when localStorage quota was exceeded (#95, #97)
So far, it appears to fix the issue. I’ll keep you posted. The whole page loads much faster now as well.
Great!
Yeah we should now be able to cache a lot more history data after changing to indexedDB as storage, thanks @Bram_Kragten!
Edit: What’s up with your humidity graph btw? the line color / fill doesn’t match, could be a bug, mind sending me the config?
Sure, never really noticed it to be honest. It uses anchors
anchors
# Main rounded border style
mainstyle: &mainstyle
type: 'custom:card-modder'
style:
border-radius: 20px
# Entities heading
entities_card_no_headers: &entities_card_no_headers
type: entities
show_header_toggle: off
# Basic transparent style meant for vertical-stack-in-card
transparent_background: &transparent_background
style:
--ha-card-background: "rgba(0, 0, 0, 0.0)"
--ha-card-box-shadow: 'none'
# Rounded transparent style ment for vertical-stack-in-card
bordered_inset_style: &bordered_inset_style
style:
border-radius: 5px
margin: 5px
# Temperature colors and levels.
mg_inside_temperature: &mg_inside_temperature
type: custom:mini-graph-card
hours_to_show: 24
points_per_hour: 1
line_width: 2
show:
#extrema: true
fill: true
color_thresholds:
- value: 65
color: "#3498db"
- value: 70
color: "#f39c12"
- value: 75
color: "#E45E65"
# Humidity colors & levels
mg_humidity: &mg_humidity
hours_to_show: 24
points_per_hour: 1
show:
#extrema: true
fill: true
color_thresholds:
- value: 30
color: "#3498db"
- value: 60
color: "#f39c12"
- value: 80
color: "#E45E65"
# basic graph, not sure what to name it
mg_basic: &mg_basic
hours_to_show: 24
points_per_hour: 1
show:
fill: true
full card
- id: multisensor_1
<<: *mainstyle
card:
<<: *entities_card_no_headers
entities:
- type: section
label: Master Bathroom Aeotec Multisensor 6
- type: custom:vertical-stack-in-card
cards:
- type: horizontal-stack
cards:
- <<: *transparent_background
card:
type: picture
image: /local/images/devices/aeotec_multisensor6_2.png
- <<: *bordered_inset_style
card:
<<: *mg_inside_temperature
entities:
- sensor.ms_temperature
cards:
card:
<<: *mg_humidity
entities:
- sensor.ms_humidity
card:
<<: *mg_basic
entities:
- sensor.ms_luminance
looks amazing !, would you mind share the code for the all page?
looks amazing !, would you mind share the full code in github If you have one.
@yoni3210 @Abeksis I’m working towards getting my config up on github as we speak. I am very close to having it posted. I will update you when it’s up. As always, it’s a moving target. I’ll probably post it monday because I can never meet my goals.
Thanks! The new caching has fixed my issues with graphs not displaying, although seems a bit less responsive now on some of the graphs with more data? That might be the hover action though.
The new hover action is great though, would it be possible to expand this to show only the one line when hovering over an entry in the legend?
Hmm, shouldn’t affect performance noticeable overall, but it will of course be a bit more demanding on the browser than before when you hover / un-hover points.
About the legend, absolutely, great idea.
Hi everybody! I’m new here, as wells as to HassIO, so please excuse me if I ask something obvious!..
This card looks awesome and seems exactly what I need. However I still can’t figure out how to install it - the instructions on github says first to get into config/www folder, but where to find it and how to get into it?! Any advise is very much appreciated, thanks a lot in advance
Search for the highlighted words “latest release” and you will find the file to download it and place into the proper folder.
Then follow the rest of the instruction to have it work.
Hey!
Maybe these instructions can be of help, mixed with the instructions on GitHub
Or perhaps this guide
In regards to the location of the configuration folder, check this docs/configuration.
Let me know if you have any further questions.
Hi @kalkih! Thanks a lot, the reddit instruction about Google calendar pointed the way for me, the keywords were
you should see a folder called /www/ , if not create it
So I’ve created the config/www folder, downloaded the mini-graph-card-bundle.js file. The same reddit guide pointed that since I don’t have the ui-lovelace.yaml file I have to use the raw config editor - so I pasted the three resources lines from github instructions there, on top. Restarted Home Assistant, and… nothing!! Please help, what should I do next to use the card?
Thank you very much in advance
The percentage for some strange reason not centered
,any idea why ?
Config:
- type: custom:mini-graph-card
labels: true
align_state: center
icon: mdi:harddisk
show:
extrema: true
label: true
points: true
entities:
- entity: sensor.disk_use_percent_home
line_color: '#6d19b2'
- entity: sensor.home_assistant_v2_db
line_color: '#0899ce'
hours_to_show: 24
points_per_hour: 1
labels: true
align_state: center
icon: mdi:pihole
entities:
- entity: sensor.pi_hole_ads_blocked_today
name: Ads Blocked Today
- entity: sensor.pi_hole_dns_queries_today
name: Dns Queries Today
- entity: sensor.pi_hole_dns_unique_clients
name: Dns unique clients
It works!! It was a small typo in the url! Thank you everybody for help!
Yeah, I think I know what the issue is, nothing you can do about it, will fix in the next release.
