Thank you!
After looking at my other tabs, I realized the issue only appears when I use the ‘vertical-stack-in-card’. Here’s a screenshot showing no issues when separated normally.
Thank you!
I love the design of this and have been able to duplicate most of it, however struggling with the y_axis. I’m guessing your using ‘state_map’? I’ve tried this without luck. Any chance you can share you Lovelace code?
I am interested aswell
I created a template sensor to pull the ‘hvac_action’ attribute from the thermostat. If heating, value 1 is output. If idle or otherwise, value 0 is output. With this new sensor, the graph can easily display the on/off status. I believe it’s possible using the state_map feature but this was something that provided me with more flexibility due to my different heating systems (hvac_action output - ‘Heat’, ‘heating’, ‘idle’, ‘off’, etc…)
family_heating:
friendly_name: "Family Heating"
value_template: >-
{% if states.climate.family_room.attributes.hvac_action == 'idle' %}
0
{% elif states.climate.family_room.attributes.hvac_action == 'heating' %}
1
{% elif states.climate.family_room.attributes.hvac_action == 'off' %}
0
{% endif %}
Here is my code from the ‘mini-graph-card’ under the thermostat. I used the state_map feature to label the On/Off status:
- cards:
- align_state: center
entities:
- entity: sensor.dining_room_temperature
- entity: sensor.office_temperature
- entity: sensor.living_room_temperature
- entity: sensor.dining_heating
color: white
show_legend: true
show_line: false
show_points: false
y_axis: secondary
- entity: sensor.mitsubishi_heating
color: gray
show_legend: true
show_line: false
show_points: false
y_axis: secondary
group: true
hours_to_show: 4
line_width: 3
points_per_hour: 9
show:
extrema: false
fill: fade
icon: false
labels: hover
labels_secondary: hover
state: false
state_map:
- label: 'Off'
value: '0'
- label: 'On'
value: '1'
type: 'custom:mini-graph-card'
type: horizontal-stack
Hi, where does the height property go and what is the syntax I can use? Thanks!
This is an example of one of my configs:
- type: custom:mini-graph-card
more_info: false
group: false
height: 0
line_width: 4
hour24: true
hours_to_show: 168
points_per_hour: 0.25
aggregate_func: max
group_by: date
animate: false
decimals: 0
align_state: left
show:
icon: true
state: true
graph: line
fill: false
points: false
legend: false
extrema: false
labels: false
As you can see I have the option “height: 0” there, that’s the option you can use, the defcault value is 150, so if you want a “higher” card, just change it to something higher than 150 until you find the right dimension for you.
Just keep in mind that “height” option is for the line graph, not the whole card.
For the whole card maybe you need to use card-mod, not sure, surely @kalkih knows better
Does anyone know how to transpose ‘on’ and ‘off’ values as 1 and 0 values on a graph without having to create a template sensor?
I got it working somehow…
Perhaps a cycle of the supplying sensor did it?
nice indeed!
what sensor do you use for the air quality? Been looking for a VOC sensor myself, and have only found the https://www.robbshop.nl/mh9-co2-monitor and couple that to my Zwave hub. It does not show VOC in Mqtt though but only the CO2 ppm. Would be interested how you integrated this into HA.
I use the Foobot which has an integration. Found one on eBay for lower than retail. Important to note the CO2 “sensor” they advertise is useless since it’s derived from the air quality and VOC sensor.
Hi!
I want to be able to change the fill color and opacity but I am stuck!
I am using card-mod but cant’ make it work.
entities:
- sensor.humedad_living_2
style: |
.line--fill {
fill: red;
stroke: red;
animation: 0 !important;
opacity: 1 !important;
Can someone tell me what am I doing wrong?
Thanks!
Hi, I’m trying to get the ‘horizontal stack’ card setup, but I get the following error, when entering the code in lovelace:
Error:
Cannot read property 'setConfig' of undefined
Code:
- type: horizontal-stack
cards:
- type: 'custom:mini-graph-card'
entities:
- sensor.kitchen_sensor_temperature
line_color: blue
line_width: 8
font_size: 75
entities:
line_color: '#e74c3c'
line_width: 8
font_size: 75
entities:
line_color: var(--accent-color)
line_width: 8
font_size: 75
Help would be appreciated, thanks!
Try change:
to:
- entity: sensor.kitchen_sensor_temperature
Doesn’t make a difference, I’m afraid.
If you mean the UI Editor, remove the dash and the 2 spaces intend.
cards:
entities:
line_color: blue
line_width: 8
font_size: 75
entities:
line_width: 8
font_size: 75
entities:
line_width: 8
font_size: 75
This should do it:
style: |
.fill--rect {
fill: red;
opacity: 1;
Brilliant, working now thanks!
Hi at all, i’m using Mini Graph Card and all is working very well!!! Please, someone could point me to the right direction on how to include this graph in Tilboard theme?? [TileBoard - New dashboard for Homeassistant] I wanna open MiniGraph Card insted of standard history graph that comes to tileboard.
thanks a lot.
Do you have ESPHome setup on your installation?
If so this is a good one:
