Thank you, I’ll share it soon. I actually purchased the Nest Hello after the API change was made. I use the badnest integration which doesn’t require a Nest dev account.
Oh my god, thank you. Not just for releasing you config in the future but for letting me know about badnest. I didn’t even know it was a thing!
I don’t understand. Can you explain?
Thanks! That did the trick for me!
Is it possible to use template instead of value
e.g
color_thresholds:
- value: ‘{{ states(’‘sensor.min_kwh_idag’’) | float }}’
color: green - value: ‘{{ states(’‘sensor.max_kwh_idag’’) | float }}’
color: red - value: 21.5
color: “#c0392b”
Please format your pasted code.
It is only possible with something like this:
I’m showing bar charts to track activities like so:
based on these
- platform: history_stats
name: fridge open for
entity_id: binary_sensor.fridge_contact
state: 'on'
type: time
start: '{{ now().replace(hour=0, minute=0, second=0) }}'
end: '{{ now() }}'
name: tv playing for
entity_id: media_player.shieldtv
state: 'playing'
type: time
end: '{{ now() }}'
so that’s great, but when I hover over the far right column (today), it shows the “real” value for how long the TV has been on today:
I can’t sort out the discrepancy.
heres the yaml for the cards
entities:
- entity: sensor.fridge_open_for
name: Fridge Open For
hours_to_show: 168
name: Fridge Door Open
group_by: date
icon: 'mdi:fridge'
show:
fill: fade
state: true
icon: true
graph: bar
type: 'custom:mini-graph-card'
entities:
- entity: sensor.watching_tv_for
hours_to_show: 168
group_by: date
icon: 'mdi:youtube-tv'
show:
fill: fade
state: true
icon: true
graph: bar
Sellerone:
if you put deaths on a different axis you can see the trend more clearly
also if you sort by date it will smooth out the graph significantly:
entities:
- entity: sensor.canada_coronavirus_current
unit: Infected
- entity: sensor.canada_coronavirus_recovered
unit: Recovered
- entity: sensor.canada_coronavirus_deaths
show_state: true
unit: dead
y_axis: secondary
hours_to_show: 168
name: Covid-19 Infections in Canada (7 days)
group_by: date
show:
fill: fade
state: true
Thanks for the suggestion, I changed to the group_by: date (I forgot that), regarding the deaths on a secondary axis I don’t agree too much because, as per you graph, it looks like the deaths are as much as the infectet.
But for the smoothness of it yes, that it is something I wanted to fix but I forgot to change that option, thanks!
I think you need to add “points: false” to the “show:” list if you don’t want to have the “mouse-over” functionality
I’m having a strange problem for the last few versions that I can’t seem to figure out. This code used to work fine:
entities:
- entity: sensor.current_power_use
points_per_hour: 3
unit: W
show:
labels: true
color_thresholds:
- value: 2000
color: '#0FE8DD'
- value: 4000
color: '#65E80F'
- value: 6000
color: '#E8AC0F'
- value: 10000
color: '#E8350F'
Lately though, it gives me this error:
Cannot assign to read only property '0' of object '[object Array]'
I can resolve the error by removing all but one of the color_thresholds:
members.
Any idea what I’m doing wrong?
I have a problem with the group_by: date function. When I want to plot gas consumption for the past 7 days (168 hrs) it always has value ‘0’ for the first day. When I switch to 6 days (144 hrs) I have the same issue.
Am I doing something wrong? This is my configuration:
- type: custom:mini-graph-card
name: Gas (7 days)
icon: mdi:fire
entities:
- entity: sensor.daily_gas
aggregate_func: max
color: "#0da035"
group_by: date
hours_to_show: 168
hour24: true
decimals: 1
animate: true
show:
graph: bar
labels: true
name: Gas (6 days)
icon: mdi:fire
entities:
aggregate_func: max
color: "#0da035"
group_by: date
hours_to_show: 144
hour24: true
decimals: 1
animate: true
show:
graph: bar
labels: true
I have history data retention already set to 8 days but that is not solving it.
recorder:
purge_keep_days: 8
Update the card, HA 0.106.0 introduced a breaking change.
Known issue
D’oh! Thanks for that, I had updated the HACS card, but there was another button to “install” or “deploy” or something like that which I failed to notice at first!
Thanks for putting me straight!
Fantastic addon! I really love how smooth and well everything looks, and it has so much configuration options I have one question that documentation was not able to answer (from my searches). Is it possible to disable title/name change when hovering over measure points? Here is quick example:
I manually assign title of the card/graph but it changes to the sensor name when hovering over data points. I know that that might be the desired behavior but still I would prefer to have control over it and disable this function if possible. Any ideas are welcome
Try to use the same name for your card and your entity:
name: Air Purifier Pro
entities:
- entity: sensor.home_aqi
Maaan! It works! I can’t imagine I didn’t think about something as simple as this:) Thank you
There is one flaw. When you show two entities like so:
you can’t actually name both the same way
Anyone else seeing Attempted to assign to readonly property
errors? I’ve been having these since updating to the new version of the card. Error was occurring on 0.107.7 and 0.108.0.
